iPad Air 6 13" Screen Replacement
    1. iPad Air 6 13" Screen Replacement, Safety precautions: step 1, image 1 of 1
      • Allow your iPad's battery to fully drain before starting this repair. A charged battery may catch fire if damaged during the repair.
      • Unplug any cables and fully shut down your iPad.
      • This guide is written with the iPad in portrait orientation.
      Ask FixBot
    2. iPad Air 6 13" Screen Replacement, Cracked screen preparation: step 2, image 1 of 1
      • Glass shards can complicate disassembly—or worse, cause injury. If your iPad has a cracked screen, follow this step.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • Apply strips of packing tape to the cracked glass until the whole screen is covered—this will help keep the glass contained and allow the suction cup to stick to the screen.
      • Only cover the glass itself—don't stick any tape to the frame.
      Ask FixBot
    1. iPad Air 6 13" Screen Replacement, Anti-Clamp instructions: step 3, image 1 of 3 iPad Air 6 13" Screen Replacement, Anti-Clamp instructions: step 3, image 2 of 3 iPad Air 6 13" Screen Replacement, Anti-Clamp instructions: step 3, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Position the suction cups on the right edge near the volume buttons—one on the top and one on the bottom. Make sure the arms don't block the volume buttons.
      • Place an object under your iPad so it rests level between the suction cups.
      • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
      Ask FixBot
    2. iPad Air 6 13" Screen Replacement: step 4, image 1 of 3 iPad Air 6 13" Screen Replacement: step 4, image 2 of 3 iPad Air 6 13" Screen Replacement: step 4, image 3 of 3
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups and realign the arms.
      Ask FixBot
    3. iPad Air 6 13" Screen Replacement: step 5, image 1 of 3 iPad Air 6 13" Screen Replacement: step 5, image 2 of 3 iPad Air 6 13" Screen Replacement: step 5, image 3 of 3
      • Use a hair dryer or heat gun to heat the screen area between the suction cups until it's slightly too hot to touch.
      • For complete instructions on how to heat with a hair dryer, check out this guide.
      • Improper use of a heat gun can destroy the screen and/or battery—review this guide for instructions. To prevent screen damage, keep your heat source moving rather than focused on one spot.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick no deeper than 3 mm when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
      • Don't crank more than half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Remove the Anti-Clamp and skip the next two steps.
      Ask FixBot
    4. iPad Air 6 13" Screen Replacement, Suction handle instructions: step 6, image 1 of 3 iPad Air 6 13" Screen Replacement, Suction handle instructions: step 6, image 2 of 3 iPad Air 6 13" Screen Replacement, Suction handle instructions: step 6, image 3 of 3
      • The next two steps show how to use a suction handle to create an initial gap.
      • Use a hair dryer or heat gun to heat the top-right corner of the screen until it's slightly too hot to touch.
      • Apply a suction handle to the right edge of the screen above the volume buttons.
      Ask FixBot
    5. iPad Air 6 13" Screen Replacement: step 7, image 1 of 3 iPad Air 6 13" Screen Replacement: step 7, image 2 of 3 iPad Air 6 13" Screen Replacement: step 7, image 3 of 3
      • Pull up on the suction handle with firm, constant pressure to create a gap under the screen.
      • The adhesive holding the screen in place is very strong. If you're having a hard time, be patient, apply more heat, and try again.
      • Insert an opening pick into the gap, no deeper than 3 mm.
      Ask FixBot
    6. iPad Air 6 13" Screen Replacement, Separate the top edge adhesive: step 8, image 1 of 1
      • Heat the entire top edge of the iPad until it's slightly too hot to touch.
      Ask FixBot
    7. iPad Air 6 13" Screen Replacement: step 9, image 1 of 3 iPad Air 6 13" Screen Replacement: step 9, image 2 of 3 iPad Air 6 13" Screen Replacement: step 9, image 3 of 3
      • Insert another opening pick under the top-right corner of the screen.
      • Slide the pick along the top edge to separate the adhesive, making sure not to insert it deeper than 6 mm.
      • If you’re having trouble, apply more heat—not more force.
      • Leave the pick inserted in the corner to prevent the adhesive from resealing.
      Ask FixBot
    8. iPad Air 6 13" Screen Replacement, Left edge information: step 10, image 1 of 2 iPad Air 6 13" Screen Replacement, Left edge information: step 10, image 2 of 2
      • Before you separate the left edge, note the following:
      • Four screen cables run along the left edge. Don't insert your pick deeper than 2 mm near the cables to avoid damaging them.
      • The adhesive widens between the cables. You may need to slice slightly deeper in these areas to separate the adhesive.
      • The second image shows where the screen cables sit relative to the iPad's bottom edge. Measure and mark these areas with tape, and work carefully around them in the next step.
      Ask FixBot
    9. iPad Air 6 13" Screen Replacement, Separate the left edge adhesive: step 11, image 1 of 3 iPad Air 6 13" Screen Replacement, Separate the left edge adhesive: step 11, image 2 of 3 iPad Air 6 13" Screen Replacement, Separate the left edge adhesive: step 11, image 3 of 3
      • Heat the left edge of the iPad until it's slightly too hot to touch.
      • Insert another opening pick under the top-left corner of the screen.
      • Slide the pick along the left edge to separate the adhesive.
      • Don't insert the pick deeper than 2 mm near the screen cables to avoid damaging the screen.
      Ask FixBot
    10. iPad Air 6 13" Screen Replacement, Separate the bottom edge adhesive: step 12, image 1 of 3 iPad Air 6 13" Screen Replacement, Separate the bottom edge adhesive: step 12, image 2 of 3 iPad Air 6 13" Screen Replacement, Separate the bottom edge adhesive: step 12, image 3 of 3
      • Heat the bottom edge until it's slightly too hot to touch.
      • Insert an opening pick under the bottom-left corner of the screen.
      • Slide the pick along the bottom edge to separate the adhesive, making sure not to insert it deeper than 6 mm.
      Ask FixBot
    11. iPad Air 6 13" Screen Replacement, Right edge information: step 13, image 1 of 2 iPad Air 6 13" Screen Replacement, Right edge information: step 13, image 2 of 2
      • Before you separate the right edge, note the following:
      • The adhesive contours around the front sensor components and the magnets.
      • There's a front microphone cable close to the front camera. Don't insert your pick deeper than 2 mm around this area to avoid damaging the cable.
      Ask FixBot
    12. iPad Air 6 13" Screen Replacement, Separate the right edge adhesive: step 14, image 1 of 3 iPad Air 6 13" Screen Replacement, Separate the right edge adhesive: step 14, image 2 of 3 iPad Air 6 13" Screen Replacement, Separate the right edge adhesive: step 14, image 3 of 3
      • Heat the right edge (the edge with the front camera) until it's slightly too hot to touch.
      • Insert an opening pick under the bottom-right corner of the screen.
      • Slide the pick along the right edge to separate the adhesive, making sure not to insert it deeper than 2 mm near the front microphone.
      Ask FixBot
    13. iPad Air 6 13" Screen Replacement, Pivot the screen: step 15, image 1 of 3 iPad Air 6 13" Screen Replacement, Pivot the screen: step 15, image 2 of 3 iPad Air 6 13" Screen Replacement, Pivot the screen: step 15, image 3 of 3
      • Don't try to remove the screen yet, as several fragile ribbon cables still connect it to the iPad. Take care not to strain the cables as you work.
      • Carefully pivot the top-left corner of the screen down to reveal the front microphone connector cover on the right edge (near the front camera).
      • If the screen feels stuck, heat the stuck areas and use an opening pick to carefully separate the residual adhesive.
      • Grab the top-left and bottom-right corners of the screen.
      Ask FixBot
    14. iPad Air 6 13" Screen Replacement, Remove the front microphone cover: step 16, image 1 of 1
      • Use a JIS 00 screwdriver to remove the 1.2 mm‑long screw securing the front microphone cover.
      • Small iFixit Phillips bits are designed to work with JIS screws. You can try Phillips drivers from other manufacturers, but you risk stripping the screw.
      Ask FixBot
    15. iPad Air 6 13" Screen Replacement: step 17, image 1 of 1
      • Remove the front microphone cover.
      Ask FixBot
    16. iPad Air 6 13" Screen Replacement, Disconnect the front microphone connector: step 18, image 1 of 2 iPad Air 6 13" Screen Replacement, Disconnect the front microphone connector: step 18, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the front microphone connector.
      • During reassembly, this can be tricky to reconnect. Use tweezers to align the connector and press gently until it clicks. Don't force it, or you'll damage the connector.
      Ask FixBot
    17. iPad Air 6 13" Screen Replacement, Flip the screen over: step 19, image 1 of 3 iPad Air 6 13" Screen Replacement, Flip the screen over: step 19, image 2 of 3 iPad Air 6 13" Screen Replacement, Flip the screen over: step 19, image 3 of 3
      • Slowly lift the right edge of the screen and flip it over itself, while moving the left edge over to keep the cables from straining.
      • Lay the flipped screen on the iPad, being careful not to strain the connected cables.
      Ask FixBot
    1. iPad Air 6 13" Screen Replacement, Remove the screen connector cover: step 20, image 1 of 2 iPad Air 6 13" Screen Replacement, Remove the screen connector cover: step 20, image 2 of 2
      • Use a JIS 00 screwdriver to remove the four 1.2 mm‑long screws securing the screen connector cover.
      Ask FixBot
    2. iPad Air 6 13" Screen Replacement: step 21, image 1 of 1
      • Remove the screen connector cover.
      Ask FixBot
    3. iPad Air 6 13" Screen Replacement, Disconnect the screen: step 22, image 1 of 2 iPad Air 6 13" Screen Replacement, Disconnect the screen: step 22, image 2 of 2
      • Use the point of a spudger to pry up and disconnect one of the screen press connectors.
      Ask FixBot
    4. iPad Air 6 13" Screen Replacement: step 23, image 1 of 3 iPad Air 6 13" Screen Replacement: step 23, image 2 of 3 iPad Air 6 13" Screen Replacement: step 23, image 3 of 3
      • Use a spudger to pry and disconnect the remaining three screen press connectors.
      Ask FixBot
    5. iPad Air 6 13" Screen Replacement, Reassembly tip: step 24, image 1 of 2 iPad Air 6 13" Screen Replacement, Reassembly tip: step 24, image 2 of 2
      • To reattach press connectors during reassembly, carefully align and press down on one side until it clicks into place, then repeat on the other side.
      • Don't press down in the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    6. iPad Air 6 13" Screen Replacement, Remove the screen: step 25, image 1 of 1
      • Remove the screen.
      • During reassembly, follow this guide to install replacement screen adhesive.
      Ask FixBot
After your repair, calibrate a genuine replacement screen using Apple's Repair Assistant.
Arthur Shi
351,098 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 82
Past 30 Days: 138
All Time: 142
