iPad 9 Logic Board Replacement
    1. iPad 9 Logic Board Replacement, Heat the left edge: step 1, image 1 of 1
      • Be sure to power off your iPad before you begin your repair.
      • Heat an iOpener and apply it to the left edge of the iPad for two minutes.
      Ask FixBot
    2. iPad 9 Logic Board Replacement, Screen removal information: step 2, image 1 of 3 iPad 9 Logic Board Replacement, Screen removal information: step 2, image 2 of 3 iPad 9 Logic Board Replacement, Screen removal information: step 2, image 3 of 3
      • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
      • Front camera
      • Antennas
      • Display cables
      • Ambient light sensors
      Ask FixBot
    3. iPad 9 Logic Board Replacement, Anti-Clamp instructions: step 3, image 1 of 3 iPad 9 Logic Board Replacement, Anti-Clamp instructions: step 3, image 2 of 3 iPad 9 Logic Board Replacement, Anti-Clamp instructions: step 3, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Place an object under your iPad so it rests level between the suction cups.
      • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
      • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
      • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
      Ask FixBot
    4. iPad 9 Logic Board Replacement: step 4, image 1 of 3 iPad 9 Logic Board Replacement: step 4, image 2 of 3 iPad 9 Logic Board Replacement: step 4, image 3 of 3
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    5. iPad 9 Logic Board Replacement: step 5, image 1 of 2 iPad 9 Logic Board Replacement: step 5, image 2 of 2
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
      • For complete instructions on how to use a hair dryer, check out this guide.
      • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
      • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next step.
      Ask FixBot
    6. iPad 9 Logic Board Replacement, Insert an opening pick: step 6, image 1 of 3 iPad 9 Logic Board Replacement, Insert an opening pick: step 6, image 2 of 3 iPad 9 Logic Board Replacement, Insert an opening pick: step 6, image 3 of 3
      • This step shows how to open the iPad using a suction handle.
      • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
      • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
      • Insert an opening pick into the gap between the digitizer and the frame.
      Ask FixBot
    7. iPad 9 Logic Board Replacement, Separate the left adhesive: step 7, image 1 of 3 iPad 9 Logic Board Replacement, Separate the left adhesive: step 7, image 2 of 3 iPad 9 Logic Board Replacement, Separate the left adhesive: step 7, image 3 of 3
      • Insert a second opening pick into the gap you just created.
      • Slide the pick towards the bottom-left corner of the iPad to separate the adhesive.
      • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
      • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
      Ask FixBot
    8. iPad 9 Logic Board Replacement: step 8, image 1 of 3 iPad 9 Logic Board Replacement: step 8, image 2 of 3 iPad 9 Logic Board Replacement: step 8, image 3 of 3
      • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
      Ask FixBot
    9. iPad 9 Logic Board Replacement: step 9, image 1 of 3 iPad 9 Logic Board Replacement: step 9, image 2 of 3 iPad 9 Logic Board Replacement: step 9, image 3 of 3
      • Slide the first opening pick towards the top-left corner of the iPad to separate the adhesive.
      • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
      Ask FixBot
    10. iPad 9 Logic Board Replacement, Heat the top edge: step 10, image 1 of 1
      • Heat an iOpener and apply it to the top edge of the iPad for two minutes.
      Ask FixBot
    11. iPad 9 Logic Board Replacement, Separate the top left adhesive: step 11, image 1 of 3 iPad 9 Logic Board Replacement, Separate the top left adhesive: step 11, image 2 of 3 iPad 9 Logic Board Replacement, Separate the top left adhesive: step 11, image 3 of 3
      • Rotate the pick around the top-left corner of the iPad to separate the adhesive.
      Ask FixBot
    12. iPad 9 Logic Board Replacement, Separate the top adhesive: step 12, image 1 of 3 iPad 9 Logic Board Replacement, Separate the top adhesive: step 12, image 2 of 3 iPad 9 Logic Board Replacement, Separate the top adhesive: step 12, image 3 of 3
      • Slide the opening pick along the top edge of the iPad, stopping just before you reach the front camera.
      • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
      Ask FixBot
    13. iPad 9 Logic Board Replacement: step 13, image 1 of 3 iPad 9 Logic Board Replacement: step 13, image 2 of 3 iPad 9 Logic Board Replacement: step 13, image 3 of 3
      • Pull the pick out until only the tip is between the digitizer and the frame.
      • Slide the pick above the front camera to separate the adhesive.
      • Leave the pick near the right side of the front camera before continuing.
      Ask FixBot
    14. iPad 9 Logic Board Replacement: step 14, image 1 of 3 iPad 9 Logic Board Replacement: step 14, image 2 of 3 iPad 9 Logic Board Replacement: step 14, image 3 of 3
      • Re-insert the pick and slide it towards the top-right corner of the iPad to completely separate the top adhesive.
      • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
      Ask FixBot
    15. iPad 9 Logic Board Replacement, Heat the right edge: step 15, image 1 of 1
      • Heat an iOpener and apply it to the right edge of the iPad for two minutes.
      Ask FixBot
    16. iPad 9 Logic Board Replacement, Separate the top right adhesive: step 16, image 1 of 3 iPad 9 Logic Board Replacement, Separate the top right adhesive: step 16, image 2 of 3 iPad 9 Logic Board Replacement, Separate the top right adhesive: step 16, image 3 of 3
      • Rotate the pick around the top-right corner of the iPad to separate the adhesive.
      Ask FixBot
    17. iPad 9 Logic Board Replacement, Separate the right adhesive: step 17, image 1 of 3 iPad 9 Logic Board Replacement, Separate the right adhesive: step 17, image 2 of 3 iPad 9 Logic Board Replacement, Separate the right adhesive: step 17, image 3 of 3
      • Insert a new opening pick and slide it to the middle of the iPad's right edge.
      • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding once you reach 3 inches from the bottom of the iPad.
      Ask FixBot
    18. iPad 9 Logic Board Replacement, Heat the bottom edge: step 18, image 1 of 1
      • Heat an iOpener and apply it to the bottom edge of the iPad for two minutes.
      Ask FixBot
    19. iPad 9 Logic Board Replacement, Separate the bottom left adhesive: step 19, image 1 of 3 iPad 9 Logic Board Replacement, Separate the bottom left adhesive: step 19, image 2 of 3 iPad 9 Logic Board Replacement, Separate the bottom left adhesive: step 19, image 3 of 3
      • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
      • Don't fully rotate the pick around the corner, as you may damage the antenna.
      • The third image shows the bottom-left antenna underneath the digitizer.
      • Leave the pick in the corner before moving to the next step.
      Ask FixBot
    20. iPad 9 Logic Board Replacement, Separate the bottom adhesive: step 20, image 1 of 3 iPad 9 Logic Board Replacement, Separate the bottom adhesive: step 20, image 2 of 3 iPad 9 Logic Board Replacement, Separate the bottom adhesive: step 20, image 3 of 3
      • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
      • Slide the pick over the antenna, stopping just before the home button.
      • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
      • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
      • Leave the pick to the left of the home button before continuing.
      Ask FixBot
    21. iPad 9 Logic Board Replacement: step 21, image 1 of 3 iPad 9 Logic Board Replacement: step 21, image 2 of 3 iPad 9 Logic Board Replacement: step 21, image 3 of 3
      • Insert an opening pick into the gap you just created.
      • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
      Ask FixBot
    22. iPad 9 Logic Board Replacement: step 22, image 1 of 3 iPad 9 Logic Board Replacement: step 22, image 2 of 3 iPad 9 Logic Board Replacement: step 22, image 3 of 3
      • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
      • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
      • Leave the pick to the right of the home button before continuing.
      Ask FixBot
    23. iPad 9 Logic Board Replacement, Heat the right edge: step 23, image 1 of 1
      Ask FixBot
    24. iPad 9 Logic Board Replacement: step 24, image 1 of 2 iPad 9 Logic Board Replacement: step 24, image 2 of 2
      • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with a pick. Don't be afraid to stop and reheat.
      • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
      • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
      Ask FixBot
    25. iPad 9 Logic Board Replacement: step 25, image 1 of 2 iPad 9 Logic Board Replacement: step 25, image 2 of 2
      • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
      • Throughout the remaining steps, try not to touch the back side of the glass or the surface of the LCD with your fingers—any fingerprints can be tough to clean off.
      Ask FixBot
    26. iPad 9 Logic Board Replacement, Separate the right adhesive: step 26, image 1 of 3 iPad 9 Logic Board Replacement, Separate the right adhesive: step 26, image 2 of 3 iPad 9 Logic Board Replacement, Separate the right adhesive: step 26, image 3 of 3
      Ask FixBot
    27. iPad 9 Logic Board Replacement: step 27, image 1 of 2 iPad 9 Logic Board Replacement: step 27, image 2 of 2
      • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
      • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
      • Be mindful of the display cables when reassembling the iPad. Make sure they are folded properly underneath the LCD screen to prevent any damage.
      Ask FixBot
    1. iPad 9 Logic Board Replacement, Remove the LCD: step 28, image 1 of 2 iPad 9 Logic Board Replacement, Remove the LCD: step 28, image 2 of 2
      Magnetic Project Mat
      $19.95
      Buy
      • Use a Phillips screwdriver to remove the four 4.2 mm-long screws securing the LCD to the frame.
      • Remove any tape obscuring the LCD screws.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPad.
      Ask FixBot
    2. iPad 9 Logic Board Replacement, Flip the LCD over: step 29, image 1 of 3 iPad 9 Logic Board Replacement, Flip the LCD over: step 29, image 2 of 3 iPad 9 Logic Board Replacement, Flip the LCD over: step 29, image 3 of 3
      • Don't attempt to fully remove the LCD during this step, as it's still connected by several cables at the home button end.
      • Only lift the LCD from the front-facing camera end.
      • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
      • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the frame.
      • Lay the LCD down onto a clean, soft, lint-free surface to allow access to the display cables.
      Ask FixBot
    3. iPad 9 Logic Board Replacement, Disconnect the battery: step 30, image 1 of 2 iPad 9 Logic Board Replacement, Disconnect the battery: step 30, image 2 of 2
      • Use a Phillips screwdriver to remove the 2.3 mm-long screw securing the battery connector to the logic board.
      Ask FixBot
    4. iPad 9 Logic Board Replacement, Battery connector information: step 31, image 1 of 3 iPad 9 Logic Board Replacement, Battery connector information: step 31, image 2 of 3 iPad 9 Logic Board Replacement, Battery connector information: step 31, image 3 of 3
      • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
      • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
      Ask FixBot
    5. iPad 9 Logic Board Replacement, Disconnect the battery: step 32, image 1 of 3 iPad 9 Logic Board Replacement, Disconnect the battery: step 32, image 2 of 3 iPad 9 Logic Board Replacement, Disconnect the battery: step 32, image 3 of 3
      • Follow the instructions carefully if you're isolating the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
      • Ensure that the iFixit logo on the battery blocker is facing up.
      • Slide the battery blocker underneath the logic board's battery connector at a 35 degree angle.
      • Don't push the battery blocker underneath the connector with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery instead.
      • The battery blocker or playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at about a 15 degree angle.
      • Leave the battery blocker in place as you work.
      Ask FixBot
    6. iPad 9 Logic Board Replacement, Unfasten the display cable bracket: step 33, image 1 of 2 iPad 9 Logic Board Replacement, Unfasten the display cable bracket: step 33, image 2 of 2
      • Use a Phillips screwdriver to remove the three 1.4 mm-long screws securing the display cable bracket.
      Ask FixBot
    7. iPad 9 Logic Board Replacement, Remove the display cable bracket: step 34, image 1 of 2 iPad 9 Logic Board Replacement, Remove the display cable bracket: step 34, image 2 of 2
      • Remove the display cable bracket.
      Ask FixBot
    8. iPad 9 Logic Board Replacement, Disconnect the LCD: step 35, image 1 of 2 iPad 9 Logic Board Replacement, Disconnect the LCD: step 35, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the LCD cable press connector.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    9. iPad 9 Logic Board Replacement, Remove the LCD: step 36, image 1 of 2 iPad 9 Logic Board Replacement, Remove the LCD: step 36, image 2 of 2
      • Remove the LCD completely and rest it face down on a clean, soft, lint-free surface.
      Ask FixBot
    1. iPad 9 Logic Board Replacement, Disconnect the home button: step 37, image 1 of 2 iPad 9 Logic Board Replacement, Disconnect the home button: step 37, image 2 of 2
      Buy
      • Use a pair of tweezers to peel off the tape covering the home button cable ZIF connector.
      Ask FixBot
    2. iPad 9 Logic Board Replacement: step 38, image 1 of 2 iPad 9 Logic Board Replacement: step 38, image 2 of 2
      • Use a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the home button cable ZIF connector.
      Ask FixBot
    3. iPad 9 Logic Board Replacement: step 39, image 1 of 2 iPad 9 Logic Board Replacement: step 39, image 2 of 2
      • Use a pair of tweezers to pull the home button ribbon cable straight out of the ZIF connector.
      Ask FixBot
    4. iPad 9 Logic Board Replacement, Disconnect the display cables: step 40, image 1 of 3 iPad 9 Logic Board Replacement, Disconnect the display cables: step 40, image 2 of 3 iPad 9 Logic Board Replacement, Disconnect the display cables: step 40, image 3 of 3
      • Use the flat end of a spudger to pry up and disconnect the two digitizer cable press connectors.
      • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
      Ask FixBot
    5. iPad 9 Logic Board Replacement, Remove the buffer block: step 41, image 1 of 3 iPad 9 Logic Board Replacement, Remove the buffer block: step 41, image 2 of 3 iPad 9 Logic Board Replacement, Remove the buffer block: step 41, image 3 of 3
      • Use the flat end of a spudger to pry up the buffer block near the bottom-right corner of the iPad.
      • Take care not to puncture or tear the home button ribbon cable.
      • Remove the buffer block.
      Ask FixBot
    6. iPad 9 Logic Board Replacement: step 42, image 1 of 2 iPad 9 Logic Board Replacement: step 42, image 2 of 2
      • The home button cable is secured with some light adhesive.
      • Use a pair of tweezers to peel the home button cable away from the frame.
      Ask FixBot
    7. iPad 9 Logic Board Replacement, Remove the front panel assembly: step 43, image 1 of 3 iPad 9 Logic Board Replacement, Remove the front panel assembly: step 43, image 2 of 3 iPad 9 Logic Board Replacement, Remove the front panel assembly: step 43, image 3 of 3
      Polyimide Tape
      $9.95
      Buy
      • Remove the front panel assembly.
      • Use an opening pick to cut away any residual adhesive that may still be connecting the front panel assembly to the frame.
      • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit replacement digitizers come with the proper insulation and should not require the addition of any tape.
      • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
      • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
      • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
      • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
      Ask FixBot
    1. iPad 9 Logic Board Replacement, Unfasten the upper component bracket: step 44, image 1 of 2 iPad 9 Logic Board Replacement, Unfasten the upper component bracket: step 44, image 2 of 2
      • Use a Phillips screwdriver to remove the three 1.4 mm-long screws securing the upper component bracket.
      Ask FixBot
    2. iPad 9 Logic Board Replacement, Remove the upper component bracket: step 45, image 1 of 2 iPad 9 Logic Board Replacement, Remove the upper component bracket: step 45, image 2 of 2
      Buy
      • Use tweezers, or your fingers, to remove the upper component bracket from the frame.
      Ask FixBot
    1. iPad 9 Logic Board Replacement, Disconnect the left ambient light sensor: step 46, image 1 of 3 iPad 9 Logic Board Replacement, Disconnect the left ambient light sensor: step 46, image 2 of 3 iPad 9 Logic Board Replacement, Disconnect the left ambient light sensor: step 46, image 3 of 3
      • Peel off any tape covering the left ambient light sensor's ZIF connector.
      Ask FixBot
    2. iPad 9 Logic Board Replacement: step 47, image 1 of 2 iPad 9 Logic Board Replacement: step 47, image 2 of 2
      • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the left ambient light sensor's ZIF connector.
      Ask FixBot
    3. iPad 9 Logic Board Replacement: step 48, image 1 of 2 iPad 9 Logic Board Replacement: step 48, image 2 of 2
      Buy
      • Use a pair of tweezers to carefully pull the left ambient light sensor cable straight out of the ZIF connector.
      Ask FixBot
    4. iPad 9 Logic Board Replacement, Remove the left ambient light sensor: step 49, image 1 of 2 iPad 9 Logic Board Replacement, Remove the left ambient light sensor: step 49, image 2 of 2
      • The left ambient light sensor is lightly adhered to the frame.
      • Use tweezers, or your fingers, to remove the sensor from the frame.
      Ask FixBot
    5. iPad 9 Logic Board Replacement: step 50, image 1 of 2 iPad 9 Logic Board Replacement: step 50, image 2 of 2
      • Use tweezers to remove any adhesive remaining on the frame.
      Ask FixBot
    6. iPad 9 Logic Board Replacement, Disconnect the headphone jack: step 51, image 1 of 2 iPad 9 Logic Board Replacement, Disconnect the headphone jack: step 51, image 2 of 2
      • Peel back any tape covering the headphone jack's press connector.
      Ask FixBot
    7. iPad 9 Logic Board Replacement: step 52, image 1 of 2 iPad 9 Logic Board Replacement: step 52, image 2 of 2
      • Use the flat end of the spudger to pry up and disconnect the headphone jack's press connector.
      Ask FixBot
    8. iPad 9 Logic Board Replacement: step 53, image 1 of 3 iPad 9 Logic Board Replacement: step 53, image 2 of 3 iPad 9 Logic Board Replacement: step 53, image 3 of 3
      • The headphone jack cable is lightly adhered to the frame.
      • Use tweezers, or your fingers, to peel the headphone jack cable up from the frame.
      Ask FixBot
    9. iPad 9 Logic Board Replacement, Unfasten the headphone jack: step 54, image 1 of 2 iPad 9 Logic Board Replacement, Unfasten the headphone jack: step 54, image 2 of 2
      • Use a Phillips screwdriver to remove the 3.3 mm-long screw securing the headphone jack from the frame.
      Ask FixBot
    10. iPad 9 Logic Board Replacement, Remove the headphone jack: step 55, image 1 of 2 iPad 9 Logic Board Replacement, Remove the headphone jack: step 55, image 2 of 2
      • Use a pair of tweezers to pull the headphone jack out of its enclosure and remove it.
      Ask FixBot
    1. iPad 9 Logic Board Replacement, Disconnect the front camera: step 56, image 1 of 2 iPad 9 Logic Board Replacement, Disconnect the front camera: step 56, image 2 of 2
      • Peel off any tape covering the front camera's ZIF connector.
      Ask FixBot
    2. iPad 9 Logic Board Replacement, Remove the front camera: step 57, image 1 of 2 iPad 9 Logic Board Replacement, Remove the front camera: step 57, image 2 of 2
      • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the front camera's ZIF connector.
      Ask FixBot
    3. iPad 9 Logic Board Replacement: step 58, image 1 of 2 iPad 9 Logic Board Replacement: step 58, image 2 of 2
      Buy
      • Use a pair of tweezers to carefully pull the front camera cable straight out of the ZIF connector.
      Ask FixBot
    4. iPad 9 Logic Board Replacement, Heat the front camera: step 59, image 1 of 1
      • Apply a heated iOpener to the top of the iPad for 90 seconds.
      Ask FixBot
    5. iPad 9 Logic Board Replacement, Separate the adhesive: step 60, image 1 of 2 iPad 9 Logic Board Replacement, Separate the adhesive: step 60, image 2 of 2
      • Insert the flat end of a spudger between the front camera and the frame.
      • Gently pry up to separate the adhesive.
      • If you're having difficulty separating the adhesive, apply more heat and pry at different angles.
      Ask FixBot
    6. iPad 9 Logic Board Replacement, Remove the front camera: step 61, image 1 of 2 iPad 9 Logic Board Replacement, Remove the front camera: step 61, image 2 of 2
      • Use tweezers to remove the front camera from its recess.
      Ask FixBot
    1. iPad 9 Logic Board Replacement, Disconnect the rear camera: step 62, image 1 of 2 iPad 9 Logic Board Replacement, Disconnect the rear camera: step 62, image 2 of 2
      • Use the flat end of a spudger to disconnect the rear camera by lifting straight up on the press connector.
      Ask FixBot
    2. iPad 9 Logic Board Replacement, Disconnect the button control cable: step 63, image 1 of 3 iPad 9 Logic Board Replacement, Disconnect the button control cable: step 63, image 2 of 3 iPad 9 Logic Board Replacement, Disconnect the button control cable: step 63, image 3 of 3
      • Peel off any tape covering the button control cable ZIF connector.
      Ask FixBot
    3. iPad 9 Logic Board Replacement: step 64, image 1 of 2 iPad 9 Logic Board Replacement: step 64, image 2 of 2
      • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the button control cable ZIF connector.
      Ask FixBot
    4. iPad 9 Logic Board Replacement: step 65, image 1 of 2 iPad 9 Logic Board Replacement: step 65, image 2 of 2
      Buy
      • Use a pair of tweezers to carefully pull the button control cable straight out of the ZIF connector.
      Ask FixBot
    5. iPad 9 Logic Board Replacement, Disconnect the Smart Cover sensor: step 66, image 1 of 2 iPad 9 Logic Board Replacement, Disconnect the Smart Cover sensor: step 66, image 2 of 2
      • Peel off any tape covering the Smart Cover sensor cable ZIF connector.
      Ask FixBot
    6. iPad 9 Logic Board Replacement: step 67, image 1 of 2 iPad 9 Logic Board Replacement: step 67, image 2 of 2
      • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the Smart Cover sensor cable ZIF connector.
      Ask FixBot
    7. iPad 9 Logic Board Replacement: step 68, image 1 of 2 iPad 9 Logic Board Replacement: step 68, image 2 of 2
      • Use a pair of tweezers to carefully pull the Smart Cover sensor cable straight out of the ZIF connector.
      Ask FixBot
    8. iPad 9 Logic Board Replacement, Disconnect the antennas: step 69, image 1 of 3 iPad 9 Logic Board Replacement, Disconnect the antennas: step 69, image 2 of 3 iPad 9 Logic Board Replacement, Disconnect the antennas: step 69, image 3 of 3
      • Use the tip of a spudger to pry up and disconnect the left antenna's coaxial cable.
      • Repeat for the right antenna's coaxial cable.
      • During reassembly, these can be tricky to reconnect. Hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
      Ask FixBot
    9. iPad 9 Logic Board Replacement, Reposition the right antenna cable: step 70, image 1 of 2 iPad 9 Logic Board Replacement, Reposition the right antenna cable: step 70, image 2 of 2
      • Peel up the right antenna cable.
      • Grip the antenna cable by the cable itself and not at its connector. Pulling coaxial cables by their connectors can break them.
      Ask FixBot
    10. iPad 9 Logic Board Replacement, Reposition the left antenna cable: step 71, image 1 of 3 iPad 9 Logic Board Replacement, Reposition the left antenna cable: step 71, image 2 of 3 iPad 9 Logic Board Replacement, Reposition the left antenna cable: step 71, image 3 of 3
      • Peel the left antenna cable away from the frame, along the bottom edge of the iPad.
      Ask FixBot
    11. iPad 9 Logic Board Replacement, Remove the buffer block: step 72, image 1 of 3 iPad 9 Logic Board Replacement, Remove the buffer block: step 72, image 2 of 3 iPad 9 Logic Board Replacement, Remove the buffer block: step 72, image 3 of 3
      • Use the flat end of a spudger to pry up the buffer block at the bottom left corner of the iPad.
      • Use a pair of tweezers to remove the buffer block.
      Ask FixBot
    12. iPad 9 Logic Board Replacement, Disconnect the speakers: step 73, image 1 of 3 iPad 9 Logic Board Replacement, Disconnect the speakers: step 73, image 2 of 3 iPad 9 Logic Board Replacement, Disconnect the speakers: step 73, image 3 of 3
      • Use a pair of tweezers or your fingernail to peel up the tape covering the speaker connectors.
      Ask FixBot
    13. iPad 9 Logic Board Replacement: step 74, image 1 of 3 iPad 9 Logic Board Replacement: step 74, image 2 of 3 iPad 9 Logic Board Replacement: step 74, image 3 of 3
      • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on both the left and right speaker cable ZIF connectors.
      Ask FixBot
    14. iPad 9 Logic Board Replacement: step 75, image 1 of 3 iPad 9 Logic Board Replacement: step 75, image 2 of 3 iPad 9 Logic Board Replacement: step 75, image 3 of 3
      • Use a pair of tweezers to carefully pull the left and right speaker cables straight out of their respective ZIF connectors.
      Ask FixBot
    15. iPad 9 Logic Board Replacement, Disconnect the Smart Connector: step 76, image 1 of 2 iPad 9 Logic Board Replacement, Disconnect the Smart Connector: step 76, image 2 of 2
      • Use the pointed end of a spudger to disconnect the Smart Connector coaxial cable by prying up as close to the connector as possible.
      Ask FixBot
    16. iPad 9 Logic Board Replacement: step 77, image 1 of 2 iPad 9 Logic Board Replacement: step 77, image 2 of 2
      • Use a spudger to pry up and disconnect the Smart Connector cable's connector.
      Ask FixBot
    17. iPad 9 Logic Board Replacement: step 78, image 1 of 2 iPad 9 Logic Board Replacement: step 78, image 2 of 2
      • Use a pair of tweezers to peel back the tape securing the Smart Connector cables to the frame.
      Ask FixBot
    18. iPad 9 Logic Board Replacement, Reposition the Smart Connector cable: step 79, image 1 of 3 iPad 9 Logic Board Replacement, Reposition the Smart Connector cable: step 79, image 2 of 3 iPad 9 Logic Board Replacement, Reposition the Smart Connector cable: step 79, image 3 of 3
      • Peel the Smart Connector cables away from the frame.
      Ask FixBot
    19. iPad 9 Logic Board Replacement, Unfasten the charging port: step 80, image 1 of 2 iPad 9 Logic Board Replacement, Unfasten the charging port: step 80, image 2 of 2
      • Use a Phillips screwdriver to remove the four screws securing the charging port to the frame:
      • Two 1.8 mm-long screws
      • Two 3.2 mm-long screws
      Ask FixBot
    20. iPad 9 Logic Board Replacement, Soften the adhesive: step 81, image 1 of 3 iPad 9 Logic Board Replacement, Soften the adhesive: step 81, image 2 of 3 iPad 9 Logic Board Replacement, Soften the adhesive: step 81, image 3 of 3
      • Heat an iOpener and apply it to the bottom, top, and logic board side of the iPad for thirty seconds in each location.
      Ask FixBot
    21. iPad 9 Logic Board Replacement, Separate the charging port cable's adhesive: step 82, image 1 of 3 iPad 9 Logic Board Replacement, Separate the charging port cable's adhesive: step 82, image 2 of 3 iPad 9 Logic Board Replacement, Separate the charging port cable's adhesive: step 82, image 3 of 3
      • Insert an opening pick under the charging port cable near the charging port and slide it towards the logic board to cut the adhesive.
      Ask FixBot
    22. iPad 9 Logic Board Replacement, Remove the charging port: step 83, image 1 of 2 iPad 9 Logic Board Replacement, Remove the charging port: step 83, image 2 of 2
      • Pull the charging port out of its slot in the frame.
      Ask FixBot
    23. iPad 9 Logic Board Replacement, Remove the logic board: step 84, image 1 of 3 iPad 9 Logic Board Replacement, Remove the logic board: step 84, image 2 of 3 iPad 9 Logic Board Replacement, Remove the logic board: step 84, image 3 of 3
      • Insert an opening pick under the upper arm of the logic board and slide it toward the logic board to cut the adhesive securing it to the frame.
      • Leave the opening pick inserted to keep the adhesive from re-adhering.
      Ask FixBot
    24. iPad 9 Logic Board Replacement: step 85, image 1 of 2 iPad 9 Logic Board Replacement: step 85, image 2 of 2
      • Remove the battery blocker.
      Ask FixBot
    25. iPad 9 Logic Board Replacement: step 86, image 1 of 2 iPad 9 Logic Board Replacement: step 86, image 2 of 2
      • Insert an opening tool near the middle of the logic board and pry up with a slow and steady force to peel it away from the frame.
      • Bending or warping the logic board could lead to permanent damage. If the adhesive feels extra stubborn, apply more heat and try again.
      • If the logic board won't budge, slide an opening pick underneath the bottom edge of the logic board to slice some of the adhesive.
      Ask FixBot
    26. iPad 9 Logic Board Replacement: step 87, image 1 of 2 iPad 9 Logic Board Replacement: step 87, image 2 of 2
      Halberd Spudger
      $2.99
      Buy
      • Use a halberd spudger or an opening pick to slice any remaining adhesive securing the logic board to the frame.
      Ask FixBot
    27. iPad 9 Logic Board Replacement: step 88, image 1 of 2 iPad 9 Logic Board Replacement: step 88, image 2 of 2
      Tesa 61395 Tape
      $8.95
      Buy
      • Remove the logic board.
      • During reassembly, ensure that there are no ribbon cables stuck under the logic board before gluing it down.
      • During reassembly, apply strips of Tesa tape if the original adhesive is too mangled to be reused.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 9 Answers community for help.
2 other people completed this guide.
Alex Diaz-Kokaisl
250,252 Reputation
1,203 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
61,630 Guides authored
0 Guide Comments
Past 24 Hours: 17
Past 7 Days: 89
Past 30 Days: 362
All Time: 13,382
