iPad 9 LTE Logic Board Replacement
    1. iPad 9 LTE Logic Board Replacement, Remove the SIM card tray: step 1, image 1 of 3 iPad 9 LTE Logic Board Replacement, Remove the SIM card tray: step 1, image 2 of 3 iPad 9 LTE Logic Board Replacement, Remove the SIM card tray: step 1, image 3 of 3
      • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole.
      • Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
      • Remove the SIM card tray.
      Ask FixBot
    1. iPad 9 LTE Logic Board Replacement, Heat the left edge: step 2, image 1 of 1
      • Power down your iPad before beginning the repair.
      • Heat an iOpener and apply it to the left edge of the iPad for two minutes.
      Ask FixBot
    2. iPad 9 LTE Logic Board Replacement, Screen removal information: step 3, image 1 of 3 iPad 9 LTE Logic Board Replacement, Screen removal information: step 3, image 2 of 3 iPad 9 LTE Logic Board Replacement, Screen removal information: step 3, image 3 of 3
      • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
      • Front camera
      • Ambient light sensors
      • Antennas
      • Display cables
      Ask FixBot
    3. iPad 9 LTE Logic Board Replacement, Anti-Clamp instructions: step 4, image 1 of 3 iPad 9 LTE Logic Board Replacement, Anti-Clamp instructions: step 4, image 2 of 3 iPad 9 LTE Logic Board Replacement, Anti-Clamp instructions: step 4, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Place an object under your iPad so it rests level between the suction cups.
      • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
      • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
      • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
      Ask FixBot
    4. iPad 9 LTE Logic Board Replacement: step 5, image 1 of 3 iPad 9 LTE Logic Board Replacement: step 5, image 2 of 3 iPad 9 LTE Logic Board Replacement: step 5, image 3 of 3
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    5. iPad 9 LTE Logic Board Replacement: step 6, image 1 of 2 iPad 9 LTE Logic Board Replacement: step 6, image 2 of 2
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
      • For complete instructions on how to use a hair dryer, check out this guide.
      • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
      • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next step.
      Ask FixBot
    6. iPad 9 LTE Logic Board Replacement, Insert an opening pick: step 7, image 1 of 3 iPad 9 LTE Logic Board Replacement, Insert an opening pick: step 7, image 2 of 3 iPad 9 LTE Logic Board Replacement, Insert an opening pick: step 7, image 3 of 3
      • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
      • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
      • Insert an opening pick into the gap between the digitizer and the frame.
      Ask FixBot
    7. iPad 9 LTE Logic Board Replacement, Separate the left adhesive: step 8, image 1 of 3 iPad 9 LTE Logic Board Replacement, Separate the left adhesive: step 8, image 2 of 3 iPad 9 LTE Logic Board Replacement, Separate the left adhesive: step 8, image 3 of 3
      • Insert a second opening pick into the gap you just created.
      • Slide the pick toward the bottom-left corner of the iPad to separate the adhesive.
      • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
      • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
      Ask FixBot
    8. iPad 9 LTE Logic Board Replacement: step 9, image 1 of 3 iPad 9 LTE Logic Board Replacement: step 9, image 2 of 3 iPad 9 LTE Logic Board Replacement: step 9, image 3 of 3
      • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
      Ask FixBot
    9. iPad 9 LTE Logic Board Replacement: step 10, image 1 of 3 iPad 9 LTE Logic Board Replacement: step 10, image 2 of 3 iPad 9 LTE Logic Board Replacement: step 10, image 3 of 3
      • Slide the first opening pick towards to top-left corner of the iPad to separate the adhesive.
      • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
      Ask FixBot
    10. iPad 9 LTE Logic Board Replacement, Heat the top edge: step 11, image 1 of 1
      • Heat an iOpener and apply it to the top edge of the iPad for two minutes.
      Ask FixBot
    11. iPad 9 LTE Logic Board Replacement, Separate the top left adhesive: step 12, image 1 of 3 iPad 9 LTE Logic Board Replacement, Separate the top left adhesive: step 12, image 2 of 3 iPad 9 LTE Logic Board Replacement, Separate the top left adhesive: step 12, image 3 of 3
      • Rotate the pick around the top-left corner of the iPad to separate the adhesive.
      • Only insert the pick up to 7 mm to avoid damaging the ambient light sensor.
      Ask FixBot
    12. iPad 9 LTE Logic Board Replacement, Separate the top adhesive: step 13, image 1 of 3 iPad 9 LTE Logic Board Replacement, Separate the top adhesive: step 13, image 2 of 3 iPad 9 LTE Logic Board Replacement, Separate the top adhesive: step 13, image 3 of 3
      • Slide the opening pick along the top edge of the iPad, stopping just before you reach the front camera.
      • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
      Ask FixBot
    13. iPad 9 LTE Logic Board Replacement: step 14, image 1 of 3 iPad 9 LTE Logic Board Replacement: step 14, image 2 of 3 iPad 9 LTE Logic Board Replacement: step 14, image 3 of 3
      • Pull the pick out until only the tip is between the digitizer and the frame.
      • Slide the pick above the front camera to separate the adhesive.
      • Leave the pick near the right side of the front camera before continuing.
      Ask FixBot
    14. iPad 9 LTE Logic Board Replacement: step 15, image 1 of 3 iPad 9 LTE Logic Board Replacement: step 15, image 2 of 3 iPad 9 LTE Logic Board Replacement: step 15, image 3 of 3
      • Re-insert the pick and slide it towards the top-right corner of the iPad to completely separate the top adhesive.
      • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
      Ask FixBot
    15. iPad 9 LTE Logic Board Replacement, Heat the right edge: step 16, image 1 of 1
      • Heat an iOpener and apply it to the right edge of the iPad for two minutes.
      Ask FixBot
    16. iPad 9 LTE Logic Board Replacement, Separate the top right adhesive: step 17, image 1 of 3 iPad 9 LTE Logic Board Replacement, Separate the top right adhesive: step 17, image 2 of 3 iPad 9 LTE Logic Board Replacement, Separate the top right adhesive: step 17, image 3 of 3
      • Rotate the pick around the top-right corner of the iPad to separate the adhesive.
      • Only insert the pick up to 4 mm to avoid damaging the ambient light sensor.
      Ask FixBot
    17. iPad 9 LTE Logic Board Replacement, Separate the right adhesive: step 18, image 1 of 3 iPad 9 LTE Logic Board Replacement, Separate the right adhesive: step 18, image 2 of 3 iPad 9 LTE Logic Board Replacement, Separate the right adhesive: step 18, image 3 of 3
      • Insert a new opening pick and slide it to the middle of the iPad's right edge.
      • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding once you reach three inches from the bottom of the iPad.
      Ask FixBot
    18. iPad 9 LTE Logic Board Replacement, Heat the bottom edge: step 19, image 1 of 1
      • Heat an iOpener and apply it to the bottom edge of the iPad for two minutes.
      Ask FixBot
    19. iPad 9 LTE Logic Board Replacement, Separate the bottom left adhesive: step 20, image 1 of 3 iPad 9 LTE Logic Board Replacement, Separate the bottom left adhesive: step 20, image 2 of 3 iPad 9 LTE Logic Board Replacement, Separate the bottom left adhesive: step 20, image 3 of 3
      • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
      • Don't fully rotate the pick around the corner, as you may damage the antenna.
      • The third image shows the bottom-left antenna underneath the digitizer.
      • Leave the pick in the corner before moving to the next step.
      Ask FixBot
    20. iPad 9 LTE Logic Board Replacement, Separate the bottom adhesive: step 21, image 1 of 3 iPad 9 LTE Logic Board Replacement, Separate the bottom adhesive: step 21, image 2 of 3 iPad 9 LTE Logic Board Replacement, Separate the bottom adhesive: step 21, image 3 of 3
      • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
      • Slide the pick over the antenna, stopping just before the home button.
      • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
      • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
      • Leave the pick to the left of the home button before continuing.
      Ask FixBot
    21. iPad 9 LTE Logic Board Replacement: step 22, image 1 of 3 iPad 9 LTE Logic Board Replacement: step 22, image 2 of 3 iPad 9 LTE Logic Board Replacement: step 22, image 3 of 3
      • Insert an opening pick into the gap you just created.
      • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
      Ask FixBot
    22. iPad 9 LTE Logic Board Replacement: step 23, image 1 of 3 iPad 9 LTE Logic Board Replacement: step 23, image 2 of 3 iPad 9 LTE Logic Board Replacement: step 23, image 3 of 3
      • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
      • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
      • Leave the pick to the right of the home button before continuing.
      Ask FixBot
    23. iPad 9 LTE Logic Board Replacement, Heat the right edge: step 24, image 1 of 1
      Ask FixBot
    24. iPad 9 LTE Logic Board Replacement: step 25, image 1 of 2 iPad 9 LTE Logic Board Replacement: step 25, image 2 of 2
      • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with an opening pick. Don't be afraid to stop and reheat.
      • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
      • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
      Ask FixBot
    25. iPad 9 LTE Logic Board Replacement: step 26, image 1 of 2 iPad 9 LTE Logic Board Replacement: step 26, image 2 of 2
      • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
      Ask FixBot
    26. iPad 9 LTE Logic Board Replacement, Separate the right adhesive: step 27, image 1 of 3 iPad 9 LTE Logic Board Replacement, Separate the right adhesive: step 27, image 2 of 3 iPad 9 LTE Logic Board Replacement, Separate the right adhesive: step 27, image 3 of 3
      Ask FixBot
    27. iPad 9 LTE Logic Board Replacement: step 28, image 1 of 2 iPad 9 LTE Logic Board Replacement: step 28, image 2 of 2
      • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
      • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
      • Be mindful of the display cables when reassembling the iPad. Make sure they are folded properly underneath the LCD screen to prevent any damage.
      Ask FixBot
    1. iPad 9 LTE Logic Board Replacement, Remove the LCD: step 29, image 1 of 3 iPad 9 LTE Logic Board Replacement, Remove the LCD: step 29, image 2 of 3 iPad 9 LTE Logic Board Replacement, Remove the LCD: step 29, image 3 of 3
      Buy
      • Use tweezers, or your fingers, to remove any tape covering the LCD screws.
      Ask FixBot
    2. iPad 9 LTE Logic Board Replacement, Unfasten the LCD screen: step 30, image 1 of 2 iPad 9 LTE Logic Board Replacement, Unfasten the LCD screen: step 30, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the four 4.2 mm screws securing the LCD screen.
      Ask FixBot
    3. iPad 9 LTE Logic Board Replacement, Separate the LCD's adhesive: step 31, image 1 of 2 iPad 9 LTE Logic Board Replacement, Separate the LCD's adhesive: step 31, image 2 of 2
      • The LCD is lightly adhered to the frame.
      • Insert a spudger between the frame and the top-right portion of the LCD.
      • Pry slowly with the spudger to separate the adhesive.
      Ask FixBot
    4. iPad 9 LTE Logic Board Replacement: step 32, image 1 of 2 iPad 9 LTE Logic Board Replacement: step 32, image 2 of 2
      • Repeat the previous step for the top-left portion of the LCD.
      Ask FixBot
    5. iPad 9 LTE Logic Board Replacement, Reposition the LCD screen: step 33, image 1 of 3 iPad 9 LTE Logic Board Replacement, Reposition the LCD screen: step 33, image 2 of 3 iPad 9 LTE Logic Board Replacement, Reposition the LCD screen: step 33, image 3 of 3
      • Don't attempt to fully remove the LCD during this step, as it's still connected by a flex cable.
      • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
      • Flip the LCD like a page in a book, lifting near the camera and turning it over the home button end of the frame.
      • Lay the LCD on a clean, soft, lint-free surface to allow access to the display cables.
      Ask FixBot
    6. iPad 9 LTE Logic Board Replacement, Disconnect the battery: step 34, image 1 of 2 iPad 9 LTE Logic Board Replacement, Disconnect the battery: step 34, image 2 of 2
      • Use a Phillips screwdriver to remove the 2.3 mm-long screw securing the battery connector to the logic board.
      Ask FixBot
    7. iPad 9 LTE Logic Board Replacement, Battery connector information: step 35, image 1 of 3 iPad 9 LTE Logic Board Replacement, Battery connector information: step 35, image 2 of 3 iPad 9 LTE Logic Board Replacement, Battery connector information: step 35, image 3 of 3
      • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
      • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
      Ask FixBot
    8. iPad 9 LTE Logic Board Replacement, Disconnect the battery: step 36, image 1 of 3 iPad 9 LTE Logic Board Replacement, Disconnect the battery: step 36, image 2 of 3 iPad 9 LTE Logic Board Replacement, Disconnect the battery: step 36, image 3 of 3
      • Be careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
      • Ensure that the iFixit logo on the battery blocker is facing up.
      • Slide the battery blocker underneath the logic board's battery connector at a 35 degree angle.
      • Don't push the battery blocker underneath the connector with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery instead.
      • The battery blocker or playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at about a 15 degree angle.
      • Leave the battery blocker in place as you work.
      Ask FixBot
    9. iPad 9 LTE Logic Board Replacement, Unfasten the display cable bracket: step 37, image 1 of 2 iPad 9 LTE Logic Board Replacement, Unfasten the display cable bracket: step 37, image 2 of 2
      • Use a Phillips screwdriver to remove the three 1.4 mm-long screws securing the display cable bracket.
      Ask FixBot
    10. iPad 9 LTE Logic Board Replacement, Remove the display cable bracket: step 38, image 1 of 2 iPad 9 LTE Logic Board Replacement, Remove the display cable bracket: step 38, image 2 of 2
      • Remove the display cable bracket.
      Ask FixBot
    11. iPad 9 LTE Logic Board Replacement, Disconnect the LCD: step 39, image 1 of 2 iPad 9 LTE Logic Board Replacement, Disconnect the LCD: step 39, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the LCD cable press connector.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    12. iPad 9 LTE Logic Board Replacement, Remove the LCD: step 40, image 1 of 2 iPad 9 LTE Logic Board Replacement, Remove the LCD: step 40, image 2 of 2
      • Remove the LCD completely and rest it face down on a clean, soft, lint-free surface.
      Ask FixBot
    1. iPad 9 LTE Logic Board Replacement, Disconnect the home button: step 41, image 1 of 2 iPad 9 LTE Logic Board Replacement, Disconnect the home button: step 41, image 2 of 2
      Buy
      • Use a pair of tweezers to peel off the tape covering the home button cable ZIF connector.
      Ask FixBot
    2. iPad 9 LTE Logic Board Replacement: step 42, image 1 of 2 iPad 9 LTE Logic Board Replacement: step 42, image 2 of 2
      • Use a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the home button cable ZIF connector.
      Ask FixBot
    3. iPad 9 LTE Logic Board Replacement: step 43, image 1 of 2 iPad 9 LTE Logic Board Replacement: step 43, image 2 of 2
      • Use a pair of tweezers to pull the home button ribbon cable straight out of the ZIF connector.
      Ask FixBot
    4. iPad 9 LTE Logic Board Replacement, Disconnect the display cables: step 44, image 1 of 3 iPad 9 LTE Logic Board Replacement, Disconnect the display cables: step 44, image 2 of 3 iPad 9 LTE Logic Board Replacement, Disconnect the display cables: step 44, image 3 of 3
      • Use the flat end of a spudger to pry up and disconnect the two digitizer cable press connectors.
      • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
      Ask FixBot
    5. iPad 9 LTE Logic Board Replacement, Remove the buffer block: step 45, image 1 of 3 iPad 9 LTE Logic Board Replacement, Remove the buffer block: step 45, image 2 of 3 iPad 9 LTE Logic Board Replacement, Remove the buffer block: step 45, image 3 of 3
      • Use the flat end of a spudger to pry up the buffer block near the bottom-right corner of the iPad.
      • Take care not to puncture or tear the home button ribbon cable.
      • Remove the buffer block.
      Ask FixBot
    6. iPad 9 LTE Logic Board Replacement: step 46, image 1 of 3 iPad 9 LTE Logic Board Replacement: step 46, image 2 of 3 iPad 9 LTE Logic Board Replacement: step 46, image 3 of 3
      • The home button cable is secured with some light adhesive.
      • Use a pair of tweezers to peel the home button cable away from the frame.
      Ask FixBot
    7. iPad 9 LTE Logic Board Replacement, Remove the front panel assembly: step 47, image 1 of 3 iPad 9 LTE Logic Board Replacement, Remove the front panel assembly: step 47, image 2 of 3 iPad 9 LTE Logic Board Replacement, Remove the front panel assembly: step 47, image 3 of 3
      Polyimide Tape
      $9.95
      Buy
      • Remove the front panel assembly.
      • Use an opening pick to cut away any residual adhesive that may still be connecting the front panel assembly to the frame.
      • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit replacement digitizers come with the proper insulation and should not require the addition of any tape.
      • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
      • The insulation is not visible to the naked eye and is different from the foam dust barrier strips found on many iPads.
      • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
      • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
      Ask FixBot
    1. iPad 9 LTE Logic Board Replacement, Remove the upper bracket tape: step 48, image 1 of 2 iPad 9 LTE Logic Board Replacement, Remove the upper bracket tape: step 48, image 2 of 2
      • Carefully peel the LCD buffer tape from the upper component bracket.
      Ask FixBot
    2. iPad 9 LTE Logic Board Replacement, Unfasten the upper component bracket: step 49, image 1 of 2 iPad 9 LTE Logic Board Replacement, Unfasten the upper component bracket: step 49, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the five screws securing the the upper component bracket:
      • Three 1.4 mm-long screws
      • Two 1.9 mm-long screws
      Ask FixBot
    3. iPad 9 LTE Logic Board Replacement, Remove the upper component bracket: step 50, image 1 of 2 iPad 9 LTE Logic Board Replacement, Remove the upper component bracket: step 50, image 2 of 2
      • Use the pointed end of a spudger to lift up the upper component bracket until you can grip it with your fingers.
      Ask FixBot
    4. iPad 9 LTE Logic Board Replacement: step 51, image 1 of 3 iPad 9 LTE Logic Board Replacement: step 51, image 2 of 3 iPad 9 LTE Logic Board Replacement: step 51, image 3 of 3
      • Use your fingers to peel the upper component bracket away from the tape.
      • Remove the upper component bracket.
      Ask FixBot
    1. iPad 9 LTE Logic Board Replacement, Disconnect the left ambient light sensor: step 52, image 1 of 3 iPad 9 LTE Logic Board Replacement, Disconnect the left ambient light sensor: step 52, image 2 of 3 iPad 9 LTE Logic Board Replacement, Disconnect the left ambient light sensor: step 52, image 3 of 3
      • Peel off any tape covering the left ambient light sensor's ZIF connector.
      Ask FixBot
    2. iPad 9 LTE Logic Board Replacement: step 53, image 1 of 2 iPad 9 LTE Logic Board Replacement: step 53, image 2 of 2
      • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the left ambient light sensor's ZIF connector.
      Ask FixBot
    3. iPad 9 LTE Logic Board Replacement: step 54, image 1 of 2 iPad 9 LTE Logic Board Replacement: step 54, image 2 of 2
      Buy
      • Use a pair of tweezers to carefully pull the left ambient light sensor cable straight out of the ZIF connector.
      Ask FixBot
    4. iPad 9 LTE Logic Board Replacement, Remove the left ambient light sensor: step 55, image 1 of 2 iPad 9 LTE Logic Board Replacement, Remove the left ambient light sensor: step 55, image 2 of 2
      • The left ambient light sensor is lightly adhered to the frame.
      • Use tweezers, or your fingers, to remove the sensor from the frame.
      Ask FixBot
    5. iPad 9 LTE Logic Board Replacement: step 56, image 1 of 2 iPad 9 LTE Logic Board Replacement: step 56, image 2 of 2
      • Use tweezers to remove any adhesive remaining on the frame.
      Ask FixBot
    6. iPad 9 LTE Logic Board Replacement, Disconnect the headphone jack: step 57, image 1 of 2 iPad 9 LTE Logic Board Replacement, Disconnect the headphone jack: step 57, image 2 of 2
      • Peel back any tape covering the headphone jack's press connector.
      Ask FixBot
    7. iPad 9 LTE Logic Board Replacement: step 58, image 1 of 2 iPad 9 LTE Logic Board Replacement: step 58, image 2 of 2
      • Use the flat end of the spudger to pry up and disconnect the headphone jack's press connector.
      Ask FixBot
    8. iPad 9 LTE Logic Board Replacement: step 59, image 1 of 3 iPad 9 LTE Logic Board Replacement: step 59, image 2 of 3 iPad 9 LTE Logic Board Replacement: step 59, image 3 of 3
      • The headphone jack cable is lightly adhered to the frame.
      • Use tweezers, or your fingers, to peel the headphone jack cable up from the frame.
      Ask FixBot
    9. iPad 9 LTE Logic Board Replacement, Unfasten the headphone jack: step 60, image 1 of 2 iPad 9 LTE Logic Board Replacement, Unfasten the headphone jack: step 60, image 2 of 2
      • Use a Phillips screwdriver to remove the 3.3 mm-long screw securing the headphone jack from the frame.
      Ask FixBot
    10. iPad 9 LTE Logic Board Replacement, Remove the headphone jack: step 61, image 1 of 2 iPad 9 LTE Logic Board Replacement, Remove the headphone jack: step 61, image 2 of 2
      • Use a pair of tweezers to pull the headphone jack out of its enclosure and remove it.
      Ask FixBot
    1. iPad 9 LTE Logic Board Replacement, Disconnect the front camera: step 62, image 1 of 2 iPad 9 LTE Logic Board Replacement, Disconnect the front camera: step 62, image 2 of 2
      • Peel off any tape covering the front camera's ZIF connector.
      Ask FixBot
    2. iPad 9 LTE Logic Board Replacement: step 63, image 1 of 2 iPad 9 LTE Logic Board Replacement: step 63, image 2 of 2
      • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the front camera's ZIF connector.
      Ask FixBot
    3. iPad 9 LTE Logic Board Replacement: step 64, image 1 of 2 iPad 9 LTE Logic Board Replacement: step 64, image 2 of 2
      Buy
      • Use a pair of tweezers to carefully pull the front camera cable straight out of the ZIF connector.
      Ask FixBot
    4. iPad 9 LTE Logic Board Replacement, Heat the front camera: step 65, image 1 of 1
      • Apply a heated iOpener to the top of the iPad for 90 seconds.
      Ask FixBot
    5. iPad 9 LTE Logic Board Replacement, Remove the front camera: step 66, image 1 of 3 iPad 9 LTE Logic Board Replacement, Remove the front camera: step 66, image 2 of 3 iPad 9 LTE Logic Board Replacement, Remove the front camera: step 66, image 3 of 3
      • Insert the flat end of a spudger between the front camera and the frame.
      • Gently pry up to separate the adhesive.
      • If you're having difficulty separating the adhesive, apply more heat and pry at different angles.
      • Use tweezers to remove the front camera from its recess.
      Ask FixBot
    1. iPad 9 LTE Logic Board Replacement, Remove the right cellular antenna screws: step 67, image 1 of 3 iPad 9 LTE Logic Board Replacement, Remove the right cellular antenna screws: step 67, image 2 of 3 iPad 9 LTE Logic Board Replacement, Remove the right cellular antenna screws: step 67, image 3 of 3
      • Use a Phillips screwdriver to remove the three 1.4 mm-long screws securing the cellular antennas to the rear case.
      Ask FixBot
    2. iPad 9 LTE Logic Board Replacement, Disconnect the cellular antennas: step 68, image 1 of 3 iPad 9 LTE Logic Board Replacement, Disconnect the cellular antennas: step 68, image 2 of 3 iPad 9 LTE Logic Board Replacement, Disconnect the cellular antennas: step 68, image 3 of 3
      • Use the pointed end of a spudger to disconnect the right cellular antenna coaxial cable by prying up as close to the connector as possible.
      • Repeat the procedure to disconnect the left antenna cable.
      Ask FixBot
    3. iPad 9 LTE Logic Board Replacement: step 69, image 1 of 3 iPad 9 LTE Logic Board Replacement: step 69, image 2 of 3 iPad 9 LTE Logic Board Replacement: step 69, image 3 of 3
      • Peel the left cellular antenna coaxial cable away from the rear case.
      • Grip the antenna cable by the cable itself and not at its connector. Pulling coaxial cables by their connectors can break them.
      Ask FixBot
    4. iPad 9 LTE Logic Board Replacement: step 70, image 1 of 3 iPad 9 LTE Logic Board Replacement: step 70, image 2 of 3 iPad 9 LTE Logic Board Replacement: step 70, image 3 of 3
      • Use a spudger to pry up and disconnect both cellular antennas' press connectors secured to the logic board.
      Ask FixBot
    5. iPad 9 LTE Logic Board Replacement, Disconnect the rear camera: step 71, image 1 of 2 iPad 9 LTE Logic Board Replacement, Disconnect the rear camera: step 71, image 2 of 2
      • Use the flat end of a spudger to disconnect the rear camera by lifting straight up on the press connector.
      Ask FixBot
    6. iPad 9 LTE Logic Board Replacement, Disconnect the button control cable: step 72, image 1 of 3 iPad 9 LTE Logic Board Replacement, Disconnect the button control cable: step 72, image 2 of 3 iPad 9 LTE Logic Board Replacement, Disconnect the button control cable: step 72, image 3 of 3
      • Peel off any tape covering the button control cable ZIF connector.
      Ask FixBot
    7. iPad 9 LTE Logic Board Replacement: step 73, image 1 of 2 iPad 9 LTE Logic Board Replacement: step 73, image 2 of 2
      • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the button control cable ZIF connector.
      Ask FixBot
    8. iPad 9 LTE Logic Board Replacement: step 74, image 1 of 2 iPad 9 LTE Logic Board Replacement: step 74, image 2 of 2
      Buy
      • Use a pair of tweezers to carefully pull the button control cable straight out of the ZIF connector.
      Ask FixBot
    9. iPad 9 LTE Logic Board Replacement, Disconnect the Smart Cover sensor: step 75, image 1 of 2 iPad 9 LTE Logic Board Replacement, Disconnect the Smart Cover sensor: step 75, image 2 of 2
      • Peel off any tape covering the Smart Cover sensor cable ZIF connector.
      Ask FixBot
    10. iPad 9 LTE Logic Board Replacement: step 76, image 1 of 2 iPad 9 LTE Logic Board Replacement: step 76, image 2 of 2
      • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the Smart Cover sensor cable ZIF connector.
      Ask FixBot
    11. iPad 9 LTE Logic Board Replacement: step 77, image 1 of 2 iPad 9 LTE Logic Board Replacement: step 77, image 2 of 2
      • Use a pair of tweezers to carefully pull the Smart Cover sensor cable straight out of the ZIF connector.
      Ask FixBot
    12. iPad 9 LTE Logic Board Replacement, Disconnect the SIM card reader: step 78, image 1 of 2 iPad 9 LTE Logic Board Replacement, Disconnect the SIM card reader: step 78, image 2 of 2
      • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the SIM card reader cable ZIF connector.
      Ask FixBot
    13. iPad 9 LTE Logic Board Replacement: step 79, image 1 of 2 iPad 9 LTE Logic Board Replacement: step 79, image 2 of 2
      • Use a pair of tweezers to carefully pull the SIM card reader cable straight out of the ZIF connector.
      Ask FixBot
    14. iPad 9 LTE Logic Board Replacement, Disconnect the antennas: step 80, image 1 of 2 iPad 9 LTE Logic Board Replacement, Disconnect the antennas: step 80, image 2 of 2
      • Insert the pointed end of a spudger under the right antenna cable and lift straight up to disconnect it.
      Ask FixBot
    15. iPad 9 LTE Logic Board Replacement: step 81, image 1 of 3 iPad 9 LTE Logic Board Replacement: step 81, image 2 of 3 iPad 9 LTE Logic Board Replacement: step 81, image 3 of 3
      • Peel up the right antenna cable.
      Ask FixBot
    16. iPad 9 LTE Logic Board Replacement, Disconnect the left antenna: step 82, image 1 of 2 iPad 9 LTE Logic Board Replacement, Disconnect the left antenna: step 82, image 2 of 2
      • Insert the pointed end of a spudger under the left antenna cable and lift straight up to disconnect it.
      Ask FixBot
    17. iPad 9 LTE Logic Board Replacement: step 83, image 1 of 3 iPad 9 LTE Logic Board Replacement: step 83, image 2 of 3 iPad 9 LTE Logic Board Replacement: step 83, image 3 of 3
      • Peel the left antenna cable away from the rear case, along the bottom edge of the iPad.
      Ask FixBot
    18. iPad 9 LTE Logic Board Replacement, Remove the buffer block: step 84, image 1 of 3 iPad 9 LTE Logic Board Replacement, Remove the buffer block: step 84, image 2 of 3 iPad 9 LTE Logic Board Replacement, Remove the buffer block: step 84, image 3 of 3
      • Use the flat end of a spudger to pry up the buffer block at the bottom left corner of the iPad.
      • Use a pair of tweezers to remove the buffer block.
      Ask FixBot
    19. iPad 9 LTE Logic Board Replacement, Disconnect the speakers: step 85, image 1 of 3 iPad 9 LTE Logic Board Replacement, Disconnect the speakers: step 85, image 2 of 3 iPad 9 LTE Logic Board Replacement, Disconnect the speakers: step 85, image 3 of 3
      • Use a pair of tweezers or your fingernail to peel up the tape covering the speaker connectors.
      Ask FixBot
    20. iPad 9 LTE Logic Board Replacement: step 86, image 1 of 3 iPad 9 LTE Logic Board Replacement: step 86, image 2 of 3 iPad 9 LTE Logic Board Replacement: step 86, image 3 of 3
      • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on both the left and right speaker cable ZIF connectors.
      Ask FixBot
    21. iPad 9 LTE Logic Board Replacement: step 87, image 1 of 3 iPad 9 LTE Logic Board Replacement: step 87, image 2 of 3 iPad 9 LTE Logic Board Replacement: step 87, image 3 of 3
      • Use a pair of tweezers to carefully pull the left and right speaker cables straight out of their respective ZIF connectors.
      Ask FixBot
    22. iPad 9 LTE Logic Board Replacement, Disconnect the Smart Connector: step 88, image 1 of 2 iPad 9 LTE Logic Board Replacement, Disconnect the Smart Connector: step 88, image 2 of 2
      • Use the pointed end of a spudger to disconnect the Smart Connector coaxial cable by prying up as close to the connector as possible.
      Ask FixBot
    23. iPad 9 LTE Logic Board Replacement: step 89, image 1 of 2 iPad 9 LTE Logic Board Replacement: step 89, image 2 of 2
      • Use a pair of tweezers to disconnect the Smart Connector cable connector by lifting straight up.
      Ask FixBot
    24. iPad 9 LTE Logic Board Replacement: step 90, image 1 of 2 iPad 9 LTE Logic Board Replacement: step 90, image 2 of 2
      • Use a pair of tweezers to peel back the tape securing the Smart Connector cables to the rear case.
      Ask FixBot
    25. iPad 9 LTE Logic Board Replacement: step 91, image 1 of 3 iPad 9 LTE Logic Board Replacement: step 91, image 2 of 3 iPad 9 LTE Logic Board Replacement: step 91, image 3 of 3
      • Peel the Smart Connector cables away from the rear case.
      Ask FixBot
    26. iPad 9 LTE Logic Board Replacement, Heat the SIM card reader: step 92, image 1 of 1
      • Apply a heated iOpener to the bottom left corner of the rear case for one minute to loosen the SIM card reader's adhesive.
      Ask FixBot
    27. iPad 9 LTE Logic Board Replacement, Remove the SIM card reader: step 93, image 1 of 2 iPad 9 LTE Logic Board Replacement, Remove the SIM card reader: step 93, image 2 of 2
      • Be sure you've ejected the SIM card tray before continuing.
      • Use an opening tool to pry up on the bottom edge of the SIM card reader with a slow and steady force.
      • If the SIM card reader feels extra stuck, apply more heat and try again.
      Ask FixBot
    28. iPad 9 LTE Logic Board Replacement: step 94, image 1 of 2 iPad 9 LTE Logic Board Replacement: step 94, image 2 of 2
      • Remove the SIM card reader.
      Ask FixBot
    29. iPad 9 LTE Logic Board Replacement, Disconnect the charging port: step 95, image 1 of 2 iPad 9 LTE Logic Board Replacement, Disconnect the charging port: step 95, image 2 of 2
      • Use a Phillips screwdriver to remove the four screws securing the charging port to the frame:
      • Two 2.2 mm-long screws
      • Two 3.2 mm-long screws
      Ask FixBot
    30. iPad 9 LTE Logic Board Replacement, Heat the logic board: step 96, image 1 of 3 iPad 9 LTE Logic Board Replacement, Heat the logic board: step 96, image 2 of 3 iPad 9 LTE Logic Board Replacement, Heat the logic board: step 96, image 3 of 3
      • Apply a heated iOpener to the bottom, top, and logic board side of the iPad for thirty seconds in each location.
      Ask FixBot
    31. iPad 9 LTE Logic Board Replacement, Separate the charging port cable's adhesive: step 97, image 1 of 3 iPad 9 LTE Logic Board Replacement, Separate the charging port cable's adhesive: step 97, image 2 of 3 iPad 9 LTE Logic Board Replacement, Separate the charging port cable's adhesive: step 97, image 3 of 3
      • Insert an opening pick under the charging port cable near the charging port and slide it towards the logic board to cut the adhesive.
      Ask FixBot
    32. iPad 9 LTE Logic Board Replacement: step 98, image 1 of 2 iPad 9 LTE Logic Board Replacement: step 98, image 2 of 2
      • Pull the charging port out of its slot in the rear case.
      Ask FixBot
    33. iPad 9 LTE Logic Board Replacement, Remove the logic board: step 99, image 1 of 3 iPad 9 LTE Logic Board Replacement, Remove the logic board: step 99, image 2 of 3 iPad 9 LTE Logic Board Replacement, Remove the logic board: step 99, image 3 of 3
      • Insert an opening pick under the upper arm of the logic board and slide it toward the logic board to cut the adhesive securing it to the rear case.
      • Leave the opening pick inserted to keep the adhesive from re-adhering.
      Ask FixBot
    34. iPad 9 LTE Logic Board Replacement: step 100, image 1 of 2 iPad 9 LTE Logic Board Replacement: step 100, image 2 of 2
      • Remove the battery blocker.
      Ask FixBot
    35. iPad 9 LTE Logic Board Replacement: step 101, image 1 of 2 iPad 9 LTE Logic Board Replacement: step 101, image 2 of 2
      • Insert an opening tool near the bottom of the logic board and pry up with a slow and steady force to peel it away from the rear case.
      • Bending or warping the logic board could lead to permanent damage. If the adhesive feels extra stubborn, apply more heat and try again.
      • Slide an opening pick underneath the bottom edge of the logic board to slice some of the adhesive if your logic board won't budge.
      Ask FixBot
    36. iPad 9 LTE Logic Board Replacement: step 102, image 1 of 2 iPad 9 LTE Logic Board Replacement: step 102, image 2 of 2
      • Insert an opening tool near the middle of the logic board and pry up with a slow and steady force to peel it away from the rear case.
      Ask FixBot
    37. iPad 9 LTE Logic Board Replacement: step 103, image 1 of 2 iPad 9 LTE Logic Board Replacement: step 103, image 2 of 2
      • Insert an opening tool near the top of the logic board and pry up with a slow and steady force to peel it away from the rear case.
      Ask FixBot
    38. iPad 9 LTE Logic Board Replacement: step 104, image 1 of 3 iPad 9 LTE Logic Board Replacement: step 104, image 2 of 3 iPad 9 LTE Logic Board Replacement: step 104, image 3 of 3
      • Insert an opening tool near the middle of the logic board and pry up until you can grip it with your fingers.
      Ask FixBot
    39. iPad 9 LTE Logic Board Replacement: step 105, image 1 of 3 iPad 9 LTE Logic Board Replacement: step 105, image 2 of 3 iPad 9 LTE Logic Board Replacement: step 105, image 3 of 3
      Halberd Spudger
      $2.99
      Buy
      • Use a halberd spudger or an opening pick to slice any remaining adhesive securing the logic board to the rear case.
      Ask FixBot
    40. iPad 9 LTE Logic Board Replacement: step 106, image 1 of 1
      Tesa 61395 Tape
      $8.95
      Buy
      • Remove the logic board.
      • During reassembly, ensure that there are no ribbon cables stuck under the logic board before gluing it down.
      • During reassembly, apply strips of Tesa tape if the original adhesive is too mangled to be reused.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 8 Answers community for help.
2 other people completed this guide.
Alex Diaz-Kokaisl
247,513 Reputation
1,203 Guides authored
iFixit Member of iFixit
Staff
123 Members
78,917 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 21
Past 30 Days: 59
All Time: 2,398
