iPad 10 Front Glass Replacement
    1. iPad 10 Front Glass Replacement, Prepare the iPad for disassembly: step 1, image 1 of 2 iPad 10 Front Glass Replacement, Prepare the iPad for disassembly: step 1, image 2 of 2
      • Disconnect all cables and accessories from the iPad.
      • For your safety, fully discharge the battery before disassembling the device. This reduces the risk of fire if the battery is accidentally damaged during the repair.
      • Note that directions in this guide are given for the iPad in landscape orientation. The USB-C port is on the right edge of the iPad.
      Ask FixBot
    1. iPad 10 Front Glass Replacement, Cracked glass preparation: step 2, image 1 of 1
      • If the iPad has a cracked digitizer, follow this step.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • Apply strips of packing tape to the cracked glass until the whole digitizer is covered—this will help keep the glass contained and allow the suction cup to stick to it.
      • Make sure there's a single strip (not overlapping) of tape across the bottom edge, big enough for a suction cup to fit on.
      • Only cover the glass itself—don't stick any tape to the frame.
      Ask FixBot
    2. iPad 10 Front Glass Replacement, Heat the right edge of the digitizer glass: step 3, image 1 of 1
      • Use a hair dryer or heat gun to heat the right edge of the iPad until it’s slightly too hot to touch. This softens the adhesive securing the digitizer glass.
      • Improper use of a heat gun can destroy the display and/or battery—review this guide for instructions. To prevent damage, keep your heat source moving rather than focused on one spot.
      • For tips on using a hair dryer to soften adhesive, check out this guide.
      Ask FixBot
    3. iPad 10 Front Glass Replacement, Insert the opening wheel: step 4, image 1 of 3 iPad 10 Front Glass Replacement, Insert the opening wheel: step 4, image 2 of 3 iPad 10 Front Glass Replacement, Insert the opening wheel: step 4, image 3 of 3
      • Apply a suction handle above the USB‑C port with the open part of the handle facing away from the edge.
      • Pull up on the suction handle with firm, constant pressure to create a slight gap under the glass.
      • Insert an opening wheel into the gap.
      • The adhesive holding the glass in place is very strong. If you're having a hard time, be patient, apply more heat, and try again.
      Ask FixBot
    4. iPad 10 Front Glass Replacement, Slide the opening wheel: step 5, image 1 of 2 iPad 10 Front Glass Replacement, Slide the opening wheel: step 5, image 2 of 2
      • Slide the opening wheel back‑and‑forth to separate the adhesive directly above the USB‑C port.
      • Try to get underneath the adhesive strip securing the digitizer, rather than slicing through the thickest part. This will make removal easier.
      • Leave the opening wheel in place to prevent the adhesive from resealing.
      Ask FixBot
    5. iPad 10 Front Glass Replacement, Remove the suction cup: step 6, image 1 of 2 iPad 10 Front Glass Replacement, Remove the suction cup: step 6, image 2 of 2
      • Pull up on the suction handle tab and remove it.
      Ask FixBot
    6. iPad 10 Front Glass Replacement, Reheat the right edge: step 7, image 1 of 1
      • This iPad cools very quickly. To get the digitizer off, work in sections of about 3 inches at a time before reheating.
      • Use a hair dryer or heat gun to soften the adhesive securing the right edge of the glass.
      Ask FixBot
    7. iPad 10 Front Glass Replacement, Separate the right edge adhesive: step 8, image 1 of 2 iPad 10 Front Glass Replacement, Separate the right edge adhesive: step 8, image 2 of 2
      • Be patient while separating the screen adhesive. If you begin to feel more resistance, stop and apply more heat.
      • Apply the suction handle to the right of the USB‑C port and lift the glass to create a gap.
      • Slide the opening wheel beneath the glass you're lifting to separate the adhesive.
      Ask FixBot
    8. iPad 10 Front Glass Replacement: step 9, image 1 of 3 iPad 10 Front Glass Replacement: step 9, image 2 of 3 iPad 10 Front Glass Replacement: step 9, image 3 of 3
      • Repeat this heating and separating process to separate the remaining adhesive along the right edge of the iPad.
      Ask FixBot
    9. iPad 10 Front Glass Replacement, Insert a plastic card: step 10, image 1 of 3 iPad 10 Front Glass Replacement, Insert a plastic card: step 10, image 2 of 3 iPad 10 Front Glass Replacement, Insert a plastic card: step 10, image 3 of 3
      • Insert a plastic card underneath the right edge of the glass to keep the adhesive separated.
      • Remove the opening wheel.
      Ask FixBot
    10. iPad 10 Front Glass Replacement, Separate the bottom edge adhesive: step 11, image 1 of 3 iPad 10 Front Glass Replacement, Separate the bottom edge adhesive: step 11, image 2 of 3 iPad 10 Front Glass Replacement, Separate the bottom edge adhesive: step 11, image 3 of 3
      • Repeat to separate the adhesive along the bottom edge of the digitizer.
      Ask FixBot
    11. iPad 10 Front Glass Replacement, Separate the left edge adhesive: step 12, image 1 of 3 iPad 10 Front Glass Replacement, Separate the left edge adhesive: step 12, image 2 of 3 iPad 10 Front Glass Replacement, Separate the left edge adhesive: step 12, image 3 of 3
      • Repeat to separate the adhesive along the left edge of the iPad.
      Ask FixBot
    12. iPad 10 Front Glass Replacement, Separate the top edge adhesive: step 13, image 1 of 3 iPad 10 Front Glass Replacement, Separate the top edge adhesive: step 13, image 2 of 3 iPad 10 Front Glass Replacement, Separate the top edge adhesive: step 13, image 3 of 3
      • Be very careful with this step. Don't insert the opening wheel deeper than 2 mm along the top edge to avoid damaging the digitizer cables, but don't use it at an angle.
      • Repeat the heating and adhesive separation process to separate the adhesive along the top edge.
      • Remove the plastic cards.
      Ask FixBot
    13. iPad 10 Front Glass Replacement, Lift the digitizer: step 14, image 1 of 3 iPad 10 Front Glass Replacement, Lift the digitizer: step 14, image 2 of 3 iPad 10 Front Glass Replacement, Lift the digitizer: step 14, image 3 of 3
      • The digitizer is still connected to the iPad with three ribbon cables. Don't try to fully remove it yet.
      • Try not to touch the back side of the digitizer or the surface of the display with your fingers—any fingerprints can be tough to clean off.
      • Lift the digitizer by its bottom edge and swing it open until it's perpendicular to the iPad.
      • Rest the digitizer on a strong, sturdy object to keep it held up while you remove the display.
      Ask FixBot
    14. iPad 10 Front Glass Replacement, Remove the display screws: step 15, image 1 of 1
      • Use a Torx Plus 2IP screwdriver to remove the ten screws securing the iPad display:
      • Four 3.5 mm‑long screws
      • Six 3.2 mm‑long screws
      • In cellular models, use a JIS 00 screwdriver to remove the additional screws along the right edge.
      Ask FixBot
    15. iPad 10 Front Glass Replacement, Lift the display: step 16, image 1 of 2 iPad 10 Front Glass Replacement, Lift the display: step 16, image 2 of 2
      • Insert the flat end of a spudger beneath the display in the center of its left edge.
      • Pry up the display until you can get your fingers beneath it.
      Ask FixBot
    16. iPad 10 Front Glass Replacement: step 17, image 1 of 2 iPad 10 Front Glass Replacement: step 17, image 2 of 2
      • Lift the display by its screw posts until it's perpendicular to the iPad. Rest it on a sturdy object.
      Ask FixBot
    17. iPad 10 Front Glass Replacement, Remove the display connector cover: step 18, image 1 of 1
      • Use a JIS 00 screwdriver to remove the two 1.1 mm‑long screws securing the display connector cover.
      Ask FixBot
    18. iPad 10 Front Glass Replacement: step 19, image 1 of 2 iPad 10 Front Glass Replacement: step 19, image 2 of 2
      • Use tweezers or your fingers to remove the display connector cover.
      Ask FixBot
    19. iPad 10 Front Glass Replacement, Disconnect the display: step 20, image 1 of 2 iPad 10 Front Glass Replacement, Disconnect the display: step 20, image 2 of 2
      • Use the flat end of a spudger to disconnect the display press connector.
      Ask FixBot
    20. iPad 10 Front Glass Replacement, Remove the display: step 21, image 1 of 3 iPad 10 Front Glass Replacement, Remove the display: step 21, image 2 of 3 iPad 10 Front Glass Replacement, Remove the display: step 21, image 3 of 3
      • The display cable is lightly adhered to the logic board.
      • Peel up the display cable and remove the display.
      Ask FixBot
    1. iPad 10 Front Glass Replacement, Remove the digitizer connector covers: step 22, image 1 of 1
      • Use a JIS 00 screwdriver to remove the four 1.1 mm‑long screws securing the digitizer connector covers.
      Ask FixBot
    2. iPad 10 Front Glass Replacement: step 23, image 1 of 3 iPad 10 Front Glass Replacement: step 23, image 2 of 3 iPad 10 Front Glass Replacement: step 23, image 3 of 3
      • Use tweezers or your fingers to remove the two digitizer connector covers.
      Ask FixBot
    3. iPad 10 Front Glass Replacement, Disconnect the digitizer: step 24, image 1 of 3 iPad 10 Front Glass Replacement, Disconnect the digitizer: step 24, image 2 of 3 iPad 10 Front Glass Replacement, Disconnect the digitizer: step 24, image 3 of 3
      • Use the flat end of a spudger to disconnect the three digitizer cable press connectors.
      Ask FixBot
    4. iPad 10 Front Glass Replacement, Remove the digitizer: step 25, image 1 of 2 iPad 10 Front Glass Replacement, Remove the digitizer: step 25, image 2 of 2
      • Slowly lift the digitizer to separate any remaining adhesive securing it to the iPad.
      • Remove the digitizer.
      Ask FixBot
    1. iPad 10 Front Glass Replacement, Clean the frame adhesive: step 26, image 1 of 2 iPad 10 Front Glass Replacement, Clean the frame adhesive: step 26, image 2 of 2
      • Don't touch the ambient light sensor or selfie camera along the top edge of the iPad while cleaning the frame.
      • Use a hair dryer or heat gun to heat a roughly 3 inch (~8 cm) section of the frame edge.
      Ask FixBot
    2. iPad 10 Front Glass Replacement: step 27, image 1 of 2 iPad 10 Front Glass Replacement: step 27, image 2 of 2
      • Use an opening tool to scrape the old adhesive into a ball on the section of the frame you heated.
      • Use tweezers to remove the balled up adhesive.
      • Repeat this heating and scraping process until most of the old adhesive is removed from the frame.
      Ask FixBot
    3. iPad 10 Front Glass Replacement: step 28, image 1 of 3 iPad 10 Front Glass Replacement: step 28, image 2 of 3 iPad 10 Front Glass Replacement: step 28, image 3 of 3
      Tool used on this step:
      Adhesive Cleanup Kit (Set of 12)
      $7.99
      Buy
      • Apply a bit of isopropyl alcohol to a cotton swab or lint-free cloth and clean the frame until it's free of adhesive residue.
      • Alternatively, use our adhesive cleanup kit.
      Ask FixBot
    4. iPad 10 Front Glass Replacement, Clean the digitizer adhesive: step 29, image 1 of 3 iPad 10 Front Glass Replacement, Clean the digitizer adhesive: step 29, image 2 of 3 iPad 10 Front Glass Replacement, Clean the digitizer adhesive: step 29, image 3 of 3
      • Skip this step if you're installing a new digitizer.
      • Repeat this process to clean the adhesive off the digitizer bezel. Use tweezers to get any large pieces off before using the opening tool.
      • Don't scrape too hard, or you'll scratch the digitizer's black paint.
      • Solvents (like isopropyl alcohol) will dissolve the foam gasket surrounding the clear glass. Only apply solvents to the black bezel.
      Ask FixBot
    5. iPad 10 Front Glass Replacement, Align the adhesive: step 30, image 1 of 2 iPad 10 Front Glass Replacement, Align the adhesive: step 30, image 2 of 2
      • If your replacement digitizer comes with adhesive pre‑installed, skip the next four steps.
      • Be careful not to crease or stretch the adhesive during installation. It can't be used if damaged.
      • Before removing any liners, align each adhesive strip over the digitizer to see where it goes. It's easiest to align the strip on the edge with the camera cutout.
      Ask FixBot
    6. iPad 10 Front Glass Replacement, Remove the first adhesive liner: step 31, image 1 of 3 iPad 10 Front Glass Replacement, Remove the first adhesive liner: step 31, image 2 of 3 iPad 10 Front Glass Replacement, Remove the first adhesive liner: step 31, image 3 of 3
      • Remove the large liners from one of the long adhesive strips. The adhesive is now exposed.
      Ask FixBot
    7. iPad 10 Front Glass Replacement, Install the adhesive: step 32, image 1 of 3 iPad 10 Front Glass Replacement, Install the adhesive: step 32, image 2 of 3 iPad 10 Front Glass Replacement, Install the adhesive: step 32, image 3 of 3
      • Work slowly when installing the adhesive—once it sticks, it can't be repositioned.
      • Install one of the large adhesive strips to the back of the digitizer.
      • Check the adhesive to make sure it doesn't overhang the edge of the digitizer glass. If it does, remove it and start over with new adhesive.
      Ask FixBot
    8. iPad 10 Front Glass Replacement: step 33, image 1 of 3 iPad 10 Front Glass Replacement: step 33, image 2 of 3 iPad 10 Front Glass Replacement: step 33, image 3 of 3
      • Repeat this process to install the remaining two adhesive strips.
      Ask FixBot
    9. iPad 10 Front Glass Replacement, Prop up the digitizer: step 34, image 1 of 1
      • Set the digitizer on the frame of the iPad, so the cables can reach their connectors on the board.
      • Lean the digitizer against a large, sturdy object to keep it upright.
      Ask FixBot
    10. iPad 10 Front Glass Replacement, Connect the digitizer: step 35, image 1 of 3 iPad 10 Front Glass Replacement, Connect the digitizer: step 35, image 2 of 3 iPad 10 Front Glass Replacement, Connect the digitizer: step 35, image 3 of 3
      • Use your finger or the flat end of a spudger to connect the three digitizer press connectors to their respective sockets on the board.
      Ask FixBot
    11. iPad 10 Front Glass Replacement, Install the digitizer connector covers: step 36, image 1 of 3 iPad 10 Front Glass Replacement, Install the digitizer connector covers: step 36, image 2 of 3 iPad 10 Front Glass Replacement, Install the digitizer connector covers: step 36, image 3 of 3
      • Set the two digitizer connector covers over their respective connectors on the board.
      Ask FixBot
    12. iPad 10 Front Glass Replacement: step 37, image 1 of 1
      • Use a JIS 00 screwdriver to install the four 1.1 mm‑long screws securing the digitizer connector covers.
      Ask FixBot
    13. iPad 10 Front Glass Replacement, Set the screen into place: step 38, image 1 of 1
      • Don't touch the front of the screen with your fingers. Any oils will be difficult to remove.
      • Set the screen on the iPad, so the screen cable connector can reach its socket on the board.
      Ask FixBot
    14. iPad 10 Front Glass Replacement, Connect the screen: step 39, image 1 of 3 iPad 10 Front Glass Replacement, Connect the screen: step 39, image 2 of 3 iPad 10 Front Glass Replacement, Connect the screen: step 39, image 3 of 3
      • Use your finger to connect the screen connector to its socket on the board.
      • Press the screen cable down so it sits flat onto the board.
      Ask FixBot
    15. iPad 10 Front Glass Replacement, Install the display connector cover: step 40, image 1 of 2 iPad 10 Front Glass Replacement, Install the display connector cover: step 40, image 2 of 2
      • Set the display connector cover into place, aligned with its screw posts.
      Ask FixBot
    16. iPad 10 Front Glass Replacement: step 41, image 1 of 1
      • Use a JIS 00 screwdriver to install the two 1.1 mm‑long screws securing the display connector cover.
      Ask FixBot
    17. iPad 10 Front Glass Replacement, Lay the screen into place: step 42, image 1 of 3 iPad 10 Front Glass Replacement, Lay the screen into place: step 42, image 2 of 3 iPad 10 Front Glass Replacement, Lay the screen into place: step 42, image 3 of 3
      • Lower the screen into its recess.
      Ask FixBot
    18. iPad 10 Front Glass Replacement, Install the display screws: step 43, image 1 of 1
      • Use a Torx Plus 2IP screwdriver to install the ten screws securing the iPad display:
      Ask FixBot
    19. iPad 10 Front Glass Replacement, Remove the adhesive liners: step 44, image 1 of 3 iPad 10 Front Glass Replacement, Remove the adhesive liners: step 44, image 2 of 3 iPad 10 Front Glass Replacement, Remove the adhesive liners: step 44, image 3 of 3
      • Use tweezers or your fingers to remove the top blue liner off the iPad digitizer adhesive.
      Ask FixBot
    20. iPad 10 Front Glass Replacement: step 45, image 1 of 2 iPad 10 Front Glass Replacement: step 45, image 2 of 2
      • Use tweezers or your fingers to remove the blue liner on the left edge of the digitizer adhesive.
      Ask FixBot
    21. iPad 10 Front Glass Replacement: step 46, image 1 of 3 iPad 10 Front Glass Replacement: step 46, image 2 of 3 iPad 10 Front Glass Replacement: step 46, image 3 of 3
      • Lower the digitizer until you can access the final blue liner.
      • Use tweezers or your fingers to peel the final blue liner off the last adhesive strip.
      Ask FixBot
    22. iPad 10 Front Glass Replacement, Install the digitizer: step 47, image 1 of 3 iPad 10 Front Glass Replacement, Install the digitizer: step 47, image 2 of 3 iPad 10 Front Glass Replacement, Install the digitizer: step 47, image 3 of 3
      • Lower the digitizer into place.
      • Press along the edges of the digitizer so it sits flush into the iPad frame.
      Ask FixBot
    23. iPad 10 Front Glass Replacement, Press the screen adhesive: step 48, image 1 of 2 iPad 10 Front Glass Replacement, Press the screen adhesive: step 48, image 2 of 2
      • In order for the adhesive to bond correctly, you'll need to apply even pressure around the perimeter of the iPad. You can compensate for the camera bump by laying the iPad face-down and placing coins around its perimeter.
      • Alternatively, you can use screen vise clamps around the perimeter of your device to set the new adhesive.
      • Place the iPad screen-side-down on a soft, flat surface.
      • Apply painter's tape to the back to protect its finish.
      Ask FixBot
    24. iPad 10 Front Glass Replacement: step 49, image 1 of 2 iPad 10 Front Glass Replacement: step 49, image 2 of 2
      • Place evenly spaced layers of coins or similarly thick objects on the tape along the edges of the back glass.
      • Stack them to a consistent height taller than the camera bump.
      Ask FixBot
    25. iPad 10 Front Glass Replacement: step 50, image 1 of 1
      • Stack multiple books or other heavy objects on the iPad.
      • The coins may leave an impression on the bottom object, so don't use anything valuable.
      • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
      Ask FixBot
Calibrate the replacement display using Apple's Repair Assistant. Navigate to Settings → General → About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 10 Answers Community for help.
Nick Schultz
65,763 Reputation
343 Guides authored
0 Guide Comments
Past 24 Hours: 28
Past 7 Days: 251
Past 30 Days: 1,067
All Time: 1,523
