Video Overview
This teardown is not a repair guide. To repair your iPad 10, use our service manual.
    1. iPad 10 Chip ID, Main Board Side 1: step 1, image 1 of 2 iPad 10 Chip ID, Main Board Side 1: step 1, image 2 of 2
      • Chip ID part 1:
      • Apple APL1W01/339S00803 A14 hexa-core applications processor layered under SK hynix H9HKNNNCRMMVFR-NEH likely 4 GB LPDDR4X SDRAM memory
      • Kioxia K5A2JW30I8TAI2217 ? 64 GB NAND flash
      • Apple APL1094/343S00564 power management
      • Apple APL1099/343S00565 power management
      • Texas Instruments SN2610A0 battery charger
      • Broadcom BCM15957A0 touchscreen controller
      • Texas Instruments CD3217B13 USB type-C controller
      Ask FixBot
    2. iPad 10 Chip ID: step 2, image 1 of 1
      • Chip ID part 2:
      • Analog Devices MAX98709B audio amplifier
      • Winbond W25Q80DV 1 MB serial NOR flash memory
      • Apple/Cirrus Logic 343S00377 power management
      • Likely Texas Instruments USB 2.0 dual repeater
      • Texas Instruments LM3638 backlight LED driver
      • Texas Instruments TPS61230A 6 A / 5 V step-up converter
      • Texas Instruments SN1705004A0 DC-DC converter (likely)
      Ask FixBot
    3. iPad 10 Chip ID: step 3, image 1 of 1
      • Chip ID part 3:
      • Texas Instruments TPD4S311A USB type-C port protector
      • Texas Instruments TVS2200 surge protection
      • Nexperia 74AVC1T45 dual-supply voltage level translator/transceiver
      • Nexperia LSF0101 1-bit multi-voltage level translator
      Ask FixBot
    4. iPad 10 Chip ID: step 4, image 1 of 1
      • Chip ID part 4 - connectivity:
      • NXP Semiconductor SN210 NFC controller w/ secure element
      • USI 339S01015 WiFi/Bluetooth module
      Ask FixBot
    5. iPad 10 Chip ID: step 5, image 1 of 1
      • Chip ID part 5 - sensors:
      • Bosch Sensortec BMI282 6-axis accelerometer/gyroscope
      • Bosch Sensortec pressure sensor
      • Alps hall sensor
      Ask FixBot
3 Guide Comments
this iPad get water damage and it would just turn on apple logo and turn itself off,
Neclus ADams - Reply Share
keep in mind l did a factory restore or tried to install the operating system and it didn't work
My ipad is at dead battery, Im trying to charge it but its not working. Only showing the charger logo and a low battery icon. What do you think is the problem? The repair man says its the charging IC and the eemc, can somebody tell me what does eemc means?
Mike - Reply Share
Past 24 Hours: 18
Past 7 Days: 123
Past 30 Days: 619
All Time: 35,522
