Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓Follow this guide to replace the battery in an iPad 10.
If the iPad needs to be charged more often or runs slower, it might be time to replace the battery.
If your battery is swollen, take appropriate precautions.
You'll need replacement battery and digitizer adhesives to complete this repair. Our battery comes with pre‑installed adhesive.
This guide was written with iPad model A2696. Different models may look a little different, but the procedure will be correct.
Apply strips of packing tape to the cracked glass until the whole digitizer is covered—this will help keep the glass contained and allow the suction cup to stick to it.
Make sure there's a single strip (not overlapping) of tape across the bottom edge, big enough for a suction cup to fit on.
Only cover the glass itself—don't stick any tape to the frame.
Use a hair dryer or heat gun to heat the right edge of the iPad until it’s slightly too hot to touch. This softens the adhesive securing the digitizer glass.
For tips on using a hair dryer to soften adhesive, check out this guide.
Apply a suction handle above the USB‑C port with the open part of the handle facing away from the edge.
Pull up on the suction handle with firm, constant pressure to create a slight gap under the glass.
Insert an opening wheel into the gap.
Slide the opening wheel back‑and‑forth to separate the adhesive directly above the USB‑C port.
Try to get underneath the adhesive strip securing the digitizer, rather than slicing through the thickest part. This will make removal easier.
Leave the opening wheel in place to prevent the adhesive from resealing.
Use a hair dryer or heat gun to soften the adhesive securing the right edge of the glass.
Apply the suction handle to the right of the USB‑C port and lift the glass to create a gap.
Slide the opening wheel beneath the glass you're lifting to separate the adhesive.
Insert a plastic card underneath the right edge of the glass to keep the adhesive separated.
Remove the opening wheel.
Repeat to separate the adhesive along the bottom edge of the digitizer.
Repeat to separate the adhesive along the left edge of the iPad.
Repeat the heating and adhesive separation process to separate the adhesive along the top edge.
Remove the plastic cards.
Lift the digitizer by its bottom edge and swing it open until it's perpendicular to the iPad.
Rest the digitizer on a strong, sturdy object to keep it held up while you remove the display.
Use a Torx Plus 2IP screwdriver to remove the ten screws securing the iPad display:
Four 3.5 mm‑long screws
Six 3.2 mm‑long screws
In cellular models, use a JIS 00 screwdriver to remove the additional screws along the right edge.
Insert the flat end of a spudger beneath the display in the center of its left edge.
Pry up the display until you can get your fingers beneath it.
Use a JIS 00 screwdriver to remove the two 1.1 mm‑long screws securing the display connector cover.
Use the flat end of a spudger to disconnect the display press connector.
Use a JIS 00 screwdriver to remove the four 1.1 mm‑long screws securing the digitizer connector covers.
Use the flat end of a spudger to disconnect the three digitizer cable press connectors.
Slowly lift the digitizer to separate any remaining adhesive securing it to the iPad.
Remove the digitizer.
Use a JIS 00 screwdriver to remove the 1.7 mm‑long screw securing the battery connector.
Use a pair of blunt tweezers to grab one of the four stretch-release adhesive strips under the battery.
Remove the remaining three stretch‑release adhesive strips securing the battery.
Insert a plastic card beneath each battery cell to separate any remaining adhesive securing it.
Slide the battery away from the logic board to disconnect its connector.
Remove the battery.
Tool used on this step:Adhesive Cleanup Kit (Set of 12)$7.99
Use high-concentration isopropyl alcohol (>90%) and a microfiber or lint-free cloth to clean any adhesive residue from the iPad frame.
Remove any liners on the bottom of the battery to expose the battery adhesive.
Slide the battery connector fully into its socket on the board and set the battery in place.
Use a JIS 00 screwdriver to install the 1.7 mm‑long screw securing the battery connector.
Don't touch the ambient light sensor or selfie camera along the top edge of the iPad while cleaning the frame.
Use a hair dryer or heat gun to heat a roughly 3Â inch (~8Â cm) section of the frame edge.
Apply a bit of isopropyl alcohol to a cotton swab or lint-free cloth and clean the frame until it's free of adhesive residue.
Alternatively, use our adhesive cleanup kit.
Repeat this process to clean the adhesive off the digitizer bezel. Use tweezers to get any large pieces off before using the opening tool.
Before removing any liners, align each adhesive strip over the digitizer to see where it goes. It's easiest to align the strip on the edge with the camera cutout.
Remove the large liners from one of the long adhesive strips. The adhesive is now exposed.
Install one of the large adhesive strips to the back of the digitizer.
Check the adhesive to make sure it doesn't overhang the edge of the digitizer glass. If it does, remove it and start over with new adhesive.
Set the digitizer on the frame of the iPad, so the cables can reach their connectors on the board.
Lean the digitizer against a large, sturdy object to keep it upright.
Use your finger or the flat end of a spudger to connect the three digitizer press connectors to their respective sockets on the board.
Set the two digitizer connector covers over their respective connectors on the board.
Set the screen on the iPad, so the screen cable connector can reach its socket on the board.
Use your finger to connect the screen connector to its socket on the board.
Press the screen cable down so it sits flat onto the board.
Set the display connector cover into place, aligned with its screw posts.
Use a Torx Plus 2IP screwdriver to install the ten screws securing the iPad display:
Use tweezers or your fingers to remove the top blue liner off the iPad digitizer adhesive.
Lower the digitizer into place.
Press along the edges of the digitizer so it sits flush into the iPad frame.
Place the iPad screen-side-down on a soft, flat surface.
Apply painter's tape to the back to protect its finish.
Calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 10 Answers Community for help.
