iNet M1001 USB Port Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
86
All Time:
509
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show users how to replace the USB port of the iNet M1001. This guide is for you if the USB port of your iNet M1001 tablet has gone bad and now needs replacing. To complete this guide some soldering is required.
Tools
    1. iNet M1001 USB Port Replacement, Back Cover: step 1, image 1 of 2 iNet M1001 USB Port Replacement, Back Cover: step 1, image 2 of 2
      • Remove the two 4.1 mm PH1 screws with a Philips screwdriver.
      Ask FixBot
    2. iNet M1001 USB Port Replacement: step 2, image 1 of 2 iNet M1001 USB Port Replacement: step 2, image 2 of 2
      • Press the small suction cup on the back cover, and then pull the small suction cup to remove the back cover.
      Ask FixBot
    1. iNet M1001 USB Port Replacement, USB Port: step 3, image 1 of 2 iNet M1001 USB Port Replacement, USB Port: step 3, image 2 of 2
      • Remove the two 3.8 mm PH1 screw with a Philips screwdriver.
      Ask FixBot
    2. iNet M1001 USB Port Replacement: step 4, image 1 of 1
      • Remove the USB port from it's plastic housing.
      Ask FixBot
    3. iNet M1001 USB Port Replacement: step 5, image 1 of 2 iNet M1001 USB Port Replacement: step 5, image 2 of 2
      • Desolder the white wire, and pull it off of the motherboard.
      • Check out this awesome guide for tips on soldering and desoldering.
      Ask FixBot
Abdulateef Abola
401 Reputation
4 Guides authored
IUPUI, Team 4-1, Baechle Spring 2017 Member of IUPUI, Team 4-1, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G1
2 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 86
All Time: 509
