iNNEXT N64 Classic Controller Shoulder Buttons Replacement
  1. iNNEXT N64 Classic Controller Shoulder Buttons Replacement, Bottom Case: step 1, image 1 of 2 iNNEXT N64 Classic Controller Shoulder Buttons Replacement, Bottom Case: step 1, image 2 of 2
    • Turn the controller face down.
    • Use a Phillips #00 screwdriver to remove the eight screws on the back of the controller.
    Ask FixBot
  2. iNNEXT N64 Classic Controller Shoulder Buttons Replacement: step 2, image 1 of 1
    • Insert an opening tool into the seam between the top and bottom case.
    • Work your way around edge of the controller to release the tabs connecting the top and bottom of the controller.
    • Remove the bottom case from the controller.
    Ask FixBot
  3. iNNEXT N64 Classic Controller Shoulder Buttons Replacement, Shoulder Buttons: step 3, image 1 of 2 iNNEXT N64 Classic Controller Shoulder Buttons Replacement, Shoulder Buttons: step 3, image 2 of 2
    • To remove the shoulder buttons, lift the buttons labelled with "L" and "R" upwards and out of the controller. There should not be any resistance coming out.
    • To add the new buttons, put the top notch of the shoulder buttons into the hole right above the control circuit. There should not be any resistance going in. Once done, you can put the back of the controller back on
    Ask FixBot
Finish Line
Khaymare commock
265 Reputation
3 Guides authored
UMass Dartmouth, Team 3-4, Santin Fall 2024 Member of UMass Dartmouth, Team 3-4, Santin Fall 2024
UMASSD-SANTIN-F24S3G4
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 200
