iNNEXT N64 Classic Controller Face Buttons Replacement
  1. iNNEXT N64 Classic Controller Face Buttons Replacement, Bottom Case: step 1, image 1 of 2 iNNEXT N64 Classic Controller Face Buttons Replacement, Bottom Case: step 1, image 2 of 2
    • Turn the controller face down.
    • Use a Phillips #00 screwdriver to remove the eight screws on the back of the controller.
    Ask FixBot
  2. iNNEXT N64 Classic Controller Face Buttons Replacement: step 2, image 1 of 1
    • Insert an opening tool into the seam between the top and bottom case.
    • Work your way around edge of the controller to release the tabs connecting the top and bottom of the controller.
    • Remove the bottom case from the controller.
    Ask FixBot
  3. iNNEXT N64 Classic Controller Face Buttons Replacement, Shoulder Buttons: step 3, image 1 of 2 iNNEXT N64 Classic Controller Face Buttons Replacement, Shoulder Buttons: step 3, image 2 of 2
    • To remove the shoulder buttons, lift the buttons labelled with "L" and "R" upwards and out of the controller. There should not be any resistance coming out.
    • To add the new buttons, put the top notch of the shoulder buttons into the hole right above the control circuit. There should not be any resistance going in. Once done, you can put the back of the controller back on
    Ask FixBot
  4. iNNEXT N64 Classic Controller Face Buttons Replacement, Face Buttons: step 4, image 1 of 2 iNNEXT N64 Classic Controller Face Buttons Replacement, Face Buttons: step 4, image 2 of 2
    • Use a Phillips screwdriver to remove the 6 screws securing the joystick assembly to the top of the controller.
    • Gently lift the control panel and joystick assembly from the top cover of the controller.
    Ask FixBot
  5. iNNEXT N64 Classic Controller Face Buttons Replacement: step 5, image 1 of 1
    • Remove the silicone button gaskets.
    Ask FixBot
  6. iNNEXT N64 Classic Controller Face Buttons Replacement: step 6, image 1 of 1
    • Remove the old buttons by either pulling them out or pushing lightly from the front of the top case.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Khaymare commock
265 Reputation
3 Guides authored
UMass Dartmouth, Team 3-4, Santin Fall 2024 Member of UMass Dartmouth, Team 3-4, Santin Fall 2024
UMASSD-SANTIN-F24S3G4
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 26
All Time: 203
