Up to 20% off select tools
iMac Whiteboard
Views: 9.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
98
All Time:
9,202
Comments: 4
4 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 day
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
iMac Whiteboard
Tools
Introduction
Go to step 1 ↓
This guide shows you the steps needed to recycle an iMac and turn it into a neat whiteboard. I recommend verifying that you can no longer fix or use your iMac and when you tear it down, try to save as many components or parts for future repairs. Hope you find it useful!
This guide gives you the whiteboard measurements for working with a 24inch iMac.
    1. iMac Whiteboard, iMac Whiteboard: step 1, image 1 of 1
      • We start up with an empty case of an iMac.
      • For directions on removing all of the interior components from your iMac, check out the 24" iMac EMC 2111 device page.
      • This procedure should also work on an iMac G5 or early Intel iMac.
      Ask FixBot
    2. iMac Whiteboard: step 2, image 1 of 1
      • Unscrew the case and take the 56x35 whiteboard, check that it fits nicely.
      Ask FixBot
    3. iMac Whiteboard: step 3, image 1 of 1
      • Apply contact cement to the inside borders of the front case. Leave to dry for about 5 minutes.
      Ask FixBot
    4. iMac Whiteboard: step 4, image 1 of 1
      • Place the whiteboard onto the front case and put weight on it.
      • Make sure that the whiteboard touches the lower side of the metal panel.
      • Leave to dry out for a day.
      Ask FixBot
    5. iMac Whiteboard: step 5, image 1 of 2 iMac Whiteboard: step 5, image 2 of 2
      • Mark up 4 lines of 4cm each on the cardboard.
      • Cut up a rectangle and fold to make up a cylinder. Use scotch tape to hold them together.
      • Repeat to get 2 more cylinders.
      Ask FixBot
    6. iMac Whiteboard: step 6, image 1 of 1
      • Glue the cylinders to the back case of the iMac.
      • This is to have some pressure against the whiteboard.
      Ask FixBot
    7. iMac Whiteboard: step 7, image 1 of 1
      • After the contact cement has dried, take out the small contact cement remnants from the board with a box cutter and a plastic tool (as to not damage the whiteboard)
      Ask FixBot
    8. iMac Whiteboard: step 8, image 1 of 1
      • Reassemble your iMac and write something on it.
      Ask FixBot
Very useful mobile whiteboard!
2 other people completed this guide.
Author
with
Angela Penaherrera
12,715 Reputation
5 Guides authored
4 Guide Comments
Great idea! How about adding an attachment to the bottom of the stand to hold a book open. Maybe use the speaker case cut to size. Affix it using the holes for the RAM access plate.
mayer - Reply Share
Thats a great idea too! If you add the stand post some pics ^_^
Angela Penaherrera - Reply Share
Angela, I tried contacting you via twitter, would you click on my icon and email me. This is about my possible relocation to Ecuador .
mayer - Reply Share
Done! Check your inbox :)
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 98
All Time: 9,202
