This teardown is not a repair guide. To repair your iMac M1 24", use our service manual.
    1. iMac M1 24" Full Chip ID, iMac M1 24" Full Chip ID: step 1, image 1 of 2 iMac M1 24" Full Chip ID, iMac M1 24" Full Chip ID: step 1, image 2 of 2
      • Back side of the logic board:
      • Apple APL1102/339S00817 64-bit M1 8-core SoC (system on a chip).
      • SK hynix H9HCNNNCRMMVGR-NEH 8 GB (2 x 4 GB) LPDDR4 SDRAM memory
      • Kioxia KICM225VE4779 128 GB NAND Flash
      • Murata 339S00763 Wi-Fi/Bluetooth module
      • Apple APL1096/343S00474 power management IC
      • Apple APL1097/343S00475 power management IC
      • Richtek RT4541GQV power management IC
      Ask FixBot
    2. iMac M1 24" Full Chip ID: step 2, image 1 of 1
      • Back side of the logic board, continued:
      • Texas Instruments INA210 bi-directional current sense amplifier
      • Texas Instruments INA214 bi-directional current sense amplifier
      • Texas Instruments TPS62137 DC-DC converter
      • Dialog Semiconductor (formerly Silego) SLG59M301V 4-amp load switch
      • Texas Instruments SN74AVC4T234 4-bit bus transceiver
      Ask FixBot
    3. iMac M1 24" Full Chip ID: step 3, image 1 of 2 iMac M1 24" Full Chip ID: step 3, image 2 of 2
      • Front side of the logic board:
      • Broadcom BCM57762 ethernet controller
      • Infineon (formerly Cypress Semiconductor) CYPDC1185B2-32LQXQ USB-C cable controller
      • Cirrus Logic CS42L83A audio codec
      • Analog Devices SSM3515B 31-watt class-D audio amplifier
      • Analog Devices (formerly Linear Technology) LTC3890-2 two-phase synchronous step-down converter
      • Texas Instruments TPS259827ON 15-amp eFuse with load current monitoring and transient fault management
      Ask FixBot
    4. iMac M1 24" Full Chip ID: step 4, image 1 of 1
      • Front side of logic board, continued:
      • Macronix MX25U6472F 64 MB serial NOR flash memory
      • Texas Instruments OPA333 single zero-drift CMOS operational amplifier
      • Temperature sensor (likely)
      • Nexperia (formerly NXP Semiconductor) 74AVC2T45 2-bit dual-supply voltage level translator/transceiver
      • Texas Instruments SN74AHC1G32 single 2-input OR gate
      • NXP Semiconductor SN210V NFC controller with secure element
      Ask FixBot
    5. iMac M1 24" Full Chip ID: step 5, image 1 of 2 iMac M1 24" Full Chip ID: step 5, image 2 of 2
      • Interconnect board:
      • ASMedia ASM3142 PCIe-to-USB 3.1 Gen 2 controller
      • Texas Instruments CD3218B12 USB-C port/power delivery controller
      • Intel JHL8040R Thunderbolt 4 retimer
      • ASMedia ASM1543 10 Gbps 4:2 mux switch with USB 3.1 type-C compatibility
      • Texas Instruments TMP464 five-channel temperature sensor
      Ask FixBot
    6. iMac M1 24" Full Chip ID: step 6, image 1 of 1
      • Interconnect board, continued:
      • Winbond W25Q80DVUXIE 8 MB serial NOR flash memory
      • Texas Instruments INA231BIYFD 16-bit current/voltage/power monitor
      • Texas Instruments TMUX1108 1-channel analog multiplexer (likely)
      • Texas Instruments TLV75533P 500 mA LDO regulator
      • Maxim Integrated DC-DC converter
      • Nexperia (formerly NXP Semiconductor) 74AUP1G09 single AND gate
      Ask FixBot
    7. iMac M1 24" Full Chip ID: step 7, image 1 of 1
      • Nexperia (formerly NXP Semiconductor) LSF0101 1-bit bidirectional multi-voltage level translator
      • Texas Instruments SN74AXC1T45 dual-supply bus transceiver
      • Texas Instruments SN74AUP1G17 Schmitt trigger (likely)
      Ask FixBot
    8. iMac M1 24" Full Chip ID: step 8, image 1 of 2 iMac M1 24" Full Chip ID: step 8, image 2 of 2
      • Left side of the display board:
      • Parade Technologies DP855A DisplayPort timing controller
      • Silicon Works SW50024 LCD level shifter
      • Winbond W25Q40EWUXIE 4 MB serial NOR flash memory
      • Texas Instruments TMP468 9-channel temperature sensor
      • Dialog Semiconductor (formerly Silego) SLG46826 mixed signal array
      • Analog Devices (formerly Linear Technology) LTC3115-1 2-amp synchronous buck converter
      • Texas Instruments TPS62140 2-amp step-down converter
      Ask FixBot
    9. iMac M1 24" Full Chip ID: step 9, image 1 of 2 iMac M1 24" Full Chip ID: step 9, image 2 of 2
      • Right side of the display board:
      • Texas Instruments BUF18830 18-channel gamma-voltage generator
      • Richtek RT6811HGQV display power management
      • Texas Instruments TPS259571 eFuse with over-voltage protection
      • Texas Instruments TPS26621 800 mA eFuse with I/O reverse polarity protection
      • Texas Instruments 2N7001T 1-bit dual-supply buffered voltage signal converter
      • Texas Instruments TLV76701 1-amp LDO Regulator
      • Texas Instruments SN74LVC1G04 single inverter
      Ask FixBot
    10. iMac M1 24" Full Chip ID: step 10, image 1 of 2 iMac M1 24" Full Chip ID: step 10, image 2 of 2
      • Left and right side of the display board, continued:
      • Texas Instruments OPA2810 dual rail-to-rail I/O operational amplifier
      • ON Semiconductor analog switch
      • Dialog Semiconductor load switch (likely)
      • Texas Instruments microcontroller (likely)
      • Texas Instruments regulator (likely)
      • Display drivers
      Ask FixBot
    11. iMac M1 24" Full Chip ID: step 11, image 1 of 2 iMac M1 24" Full Chip ID: step 11, image 2 of 2
      • Texas Instruments DRV10975 BLDC motor driver
      Ask FixBot
    12. iMac M1 24" Full Chip ID: step 12, image 1 of 3 iMac M1 24" Full Chip ID: step 12, image 2 of 3 iMac M1 24" Full Chip ID: step 12, image 3 of 3
      • A partial list of chips on the power supply board:
      • NXP Semiconductor TEA19161T digital power supply controller
      • NXP Semiconductor TEA19162T power factor correction controller
      • NXP Semiconductor TEA2095TE dual synchronous rectifier switching controller
      Ask FixBot
Craig Lloyd
43,231 Reputation
82 Guides authored
1 Guide Comment
76MiB of flash across the boards on this machine. Apple really does like large amounts of ROM, don’t they?
Saoirse Ó Catháin - Reply Share
Past 24 Hours: 7
Past 7 Days: 36
Past 30 Days: 192
All Time: 19,457
