Up to 20% off select tools
iMac M1 24" Display Replacement
Views: 23K
View statistics:
Past 24 Hours:
36
Past 7 Days:
254
Past 30 Days:
994
All Time:
22,686
Comments: 15
5 comments on steps, 10 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
    1. iMac M1 24" Display Replacement, Display: step 1, image 1 of 1
      • Start by gently peeling the adhesive off of each side of the iMac by using the iMac Opening Wheel.
      Ask FixBot
    2. iMac M1 24" Display Replacement: step 2, image 1 of 1
      • After the adhesive has been removed, you can use a suction cup to help remove the display from the case.
      Ask FixBot
    3. iMac M1 24" Display Replacement: step 3, image 1 of 1
      • Next, carefully remove the three cables.
      • (From left to right) The first cable can be removed with a prying tool or with a fingernail. With the second, the tab on the ZIF Connector must be flipped up so that the cable can be removed. With the third, you must lift the tab on the left of the socket upwards so that you can remove it.
      Ask FixBot
    4. iMac M1 24" Display Replacement, Done!: step 4, image 1 of 1
      • The display is now removed!
      • It is highly recommended to apply new adhesive, when reinstalling the screen.
      Ask FixBot
To reassemble your device, follow the steps in reverse order.
10 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
Thomas B
1,033 Reputation
2 Guides authored
10 Guide Comments
Will this cause an issue with true tone and the front camera similar to iPhone screen replacements?
Kane Snyder - Reply Share
True Tone will be removed however the camera will still work. The screen will work just fine
Stephen - Reply Share
Where is a good place to buy replacement screens? I have and Apple 24" iMac with M1 Chip (Mid 2021, Silver) and afraid I’m going to buy the wrong screen or a fake one. Thanks for time
Joe Redding - Reply Share
Apple has eliminated the ability for these parts to be available from anyone but Apple and they charge so much that you might as well buy a new iMac. So much for their supposed commitment to repairability. There whole repairability program is nothing but a forward facing PR campaign while their actual processes are meant to encourage their continued windfall from Applecare or the sale of new machines. They are happy to have you trade in your existing product that they then fix and resell, just not willing to do that at a reasonable cost for their actual customers.
And That's The Way It Is - Reply Share
Since you partner with Apple why no listing of availability of the actual part? And if it's not available what is the point of this being titled "Screen Replacement"?
Past 24 Hours: 36
Past 7 Days: 254
Past 30 Days: 994
All Time: 22,686
