iMac Intel 27" Retina 5K Display 2020 RAM Replacement
Views: 15K
View statistics:
Past 24 Hours:
7
Past 7 Days:
45
Past 30 Days:
216
All Time:
15,011
Comments: 21
20 comments on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 5 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Follow this guide to replace the RAM on a 2020 iMac 27" Retina 5K.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the guide procedure.
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
  • Spudger
    4.9
    Recommended
    1. iMac Intel 27" Retina 5K Display 2020 RAM Replacement, Open the RAM door: step 1, image 1 of 2 iMac Intel 27" Retina 5K Display 2020 RAM Replacement, Open the RAM door: step 1, image 2 of 2
      • While holding the display steady, use the flat end of a spudger to press in on the RAM door release button, located just above the power port.
      • You may have to press fairly hard—keep at it until the bottom of the door pops out about 0.25" from the rear of the iMac.
      Ask FixBot
    2. iMac Intel 27" Retina 5K Display 2020 RAM Replacement, Remove the RAM door: step 2, image 1 of 3 iMac Intel 27" Retina 5K Display 2020 RAM Replacement, Remove the RAM door: step 2, image 2 of 3 iMac Intel 27" Retina 5K Display 2020 RAM Replacement, Remove the RAM door: step 2, image 3 of 3
      • Pull the RAM access door off the back of the iMac.
      Ask FixBot
    3. iMac Intel 27" Retina 5K Display 2020 RAM Replacement, Unlock the RAM tray: step 3, image 1 of 3 iMac Intel 27" Retina 5K Display 2020 RAM Replacement, Unlock the RAM tray: step 3, image 2 of 3 iMac Intel 27" Retina 5K Display 2020 RAM Replacement, Unlock the RAM tray: step 3, image 3 of 3
      • The RAM tray is locked into its upright position with two grey tabs.
      • Use your thumbs or index fingers to unlock the tray by pushing the tabs outward, away from the RAM.
      • Pull the tabs out and down, swinging the RAM tray down to a near-horizontal position.
      Ask FixBot
    4. iMac Intel 27" Retina 5K Display 2020 RAM Replacement, Remove the RAM: step 4, image 1 of 3 iMac Intel 27" Retina 5K Display 2020 RAM Replacement, Remove the RAM: step 4, image 2 of 3 iMac Intel 27" Retina 5K Display 2020 RAM Replacement, Remove the RAM: step 4, image 3 of 3
      • Remove a stick of RAM by grabbing it with two hands and pulling straight out of the RAM tray.
      • RAM modules are keyed so that they can only be installed in the proper orientation. Note where the shorter section of contacts is when removing, and reinstalling, your RAM.
      • To install a new module, insert the module into the desired slot in the tray and press it firmly in place. Push the tray back up until it locks in place.
      • The RAM access door is not symmetrical. If it is not flush on both ends, try putting it in the other way.
      • Re-insert the RAM access door back into its place.
      Ask FixBot
3 other people completed this guide.
Sam Omiotek
101,181 Reputation
289 Guides authored
1 Guide Comment
Does this use standard SO-DIMMS? im thinking of adding two DDR4 2400 4gb sticks to the extra slots to make 16gb.
ArandomHitman - Reply Share
Past 24 Hours: 7
Past 7 Days: 45
Past 30 Days: 216
All Time: 15,011
