iMac Intel 27" EMC 2429 Motherboard Replacement
    1. iMac Intel 27" EMC 2429 Motherboard Replacement, Glass Panel: step 1, image 1 of 3 iMac Intel 27" EMC 2429 Motherboard Replacement, Glass Panel: step 1, image 2 of 3 iMac Intel 27" EMC 2429 Motherboard Replacement, Glass Panel: step 1, image 3 of 3
      Tool used on this step:
      Heavy-Duty Suction Cups (Pair)
      $16.95
      Buy
      • Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
      • To attach the suction cups, first position the suction cup with the movable handle parallel to the face of the glass panel (as indicated in the second picture).
      • While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
      • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a damp soft, lint-free cloth. (Dampen with distilled water, and if needed, an equal ratio of distilled water and white vinegar for best results.)
      • Do not use the suction cups to carry the display glass because if one of them fails to stick, you could drop the screen and break it.
      • The original iMac box makes a good place to store the glass panel. Otherwise, a padded horizontal surface, like a towel on a desk, will do nicely.
      Ask FixBot
    2. iMac Intel 27" EMC 2429 Motherboard Replacement: step 2, image 1 of 3 iMac Intel 27" EMC 2429 Motherboard Replacement: step 2, image 2 of 3 iMac Intel 27" EMC 2429 Motherboard Replacement: step 2, image 3 of 3
      • Gently lift the glass panel perpendicular to the face of the LCD, enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
      • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
      • Don't use the suction cups to carry the glass panel—if either one loses its grip, the panel could fall and break.
      • After setting the glass panel down safely, be sure to release the suction cups, as the suction force over time can crack the glass.
      • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
      Ask FixBot
    1. iMac Intel 27" EMC 2429 Motherboard Replacement, Display: step 3, image 1 of 1
      • Remove the eight T10 Torx screws securing the LCD to the outer case.
      • Be careful not to touch the display as the oil from your fingers may leave a residue that can be difficult to remove.
      • If necessary, peel the EMI gaskets located near the top center edge of the display assembly.
      Ask FixBot
    2. iMac Intel 27" EMC 2429 Motherboard Replacement, Display: step 4, image 1 of 3 iMac Intel 27" EMC 2429 Motherboard Replacement, Display: step 4, image 2 of 3 iMac Intel 27" EMC 2429 Motherboard Replacement, Display: step 4, image 3 of 3
      $3.99
      Buy
      • Carefully lay the iMac stand-side down on a flat surface.
      • Due to tight tolerances, you will have to use a thin hooked tool to lift the display out of the outer case. As seen in the first picture, we made one out of a bent paperclip. A pair of angled tweezers can also work well.
      • Use a thin hooked tool to lift one side of the top edge of the display by its steel outer frame.
      • After lifting the top edge of the display on one side, hold it out of the outer case while you use a hooked tool to lift the other side.
      • Raise and hold the display high enough to access the cables.
      • Do not lift the top edge of the display out of the outer case too far, as several short ribbon cables still connect the two components.
      Ask FixBot
    3. iMac Intel 27" EMC 2429 Motherboard Replacement: step 5, image 1 of 1
      • Disconnect the vertical sync cable in the upper left corner of the screen. Use the tip of a spudger to push on the connector's side tabs and gently walk it out of its socket.
      Ask FixBot
    4. iMac Intel 27" EMC 2429 Motherboard Replacement: step 6, image 1 of 1
      • This step brings your hands close to the exposed rear of the power supply. To avoid a high-voltage shock from the many large capacitors attached to the board, do NOT touch the rear of the power supply.
      • Disconnect the LED backlight driver cable with your hand by pressing the tab down and sliding it towards the bottom of the display.
      Ask FixBot
    5. iMac Intel 27" EMC 2429 Motherboard Replacement: step 7, image 1 of 2 iMac Intel 27" EMC 2429 Motherboard Replacement: step 7, image 2 of 2
      • Pull the black tab straight up to disconnect the latch on the display data cable ZIF connector.
      • Do not pull up too hard or you will damage the connector and socket.
      • Continue to pull the black tab up toward the top of the device, to detach the display data cable.
      Ask FixBot
    6. iMac Intel 27" EMC 2429 Motherboard Replacement: step 8, image 1 of 1
      • Use the tip of a spudger to disconnect the display power cable next to the display data cable.
      Ask FixBot
    7. iMac Intel 27" EMC 2429 Motherboard Replacement: step 9, image 1 of 1
      • Carefully pull the display toward the top edge of your iMac and lift it out of the iMac case.
      Ask FixBot
    8. iMac Intel 27" EMC 2429 Motherboard Replacement: step 10, image 1 of 1
      • Lay the display face down on a flat, soft surface.
      • If you are replacing the display panel, you will need to transfer additional components from the old panel to the new one. Compare the back of the old display with the replacement display. Note all cables, sensors, and foam cushioning that are missing from the new display.
      • If there is a wire or cable underneath adhesive tape, always pull the tape off first. Do not pull on the cable directly.
      • If the cable is glued to the chassis, use a heated iOpener or a hair dryer to soften the adhesive first. You can then slide an opening pick underneath the cable to loosen it. Never pull on the delicate connectors.
      • Slide an opening pick underneath the foam cushion pieces to separate them from the display, and gently pull them off. You may need some double sided tape to re-attach them to the new display.
      Ask FixBot
      • Insert wisdom here.
      Ask FixBot
Ben Capehart
10,266 Reputation
18 Guides authored
Restart Project Member of Restart Project
Local Repair Groups
33 Members
2,398 Guides authored
1 Guide Comment
May be i lost something on the track but i don't understand why this manuel stops at the step 11? seeming to be incomplete.
As i remember a few months ago there was all the steps to remove the mother board. Something i forget?
jeff - Reply Share
Past 24 Hours: 4
Past 7 Days: 45
Past 30 Days: 183
All Time: 5,457
