Introduction
This is a guide on how to upgrade your Mid 2011 iMac's Ram, HDD, CPU, and GPU. This guide also shows you how to clean out the fans of your iMac.
First Start by unplugging all cables from your iMac and setting up a workstation.
Tool used on this step:Heavy-Duty Suction Cups (Pair)$16.95
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
4 other people completed this guide.
7 Guide Comments
Where is the rest of this guide?
Obviously not following this guide, I opened my iMac that had full graphics failure, uninstalled the GPU-card, cleaned it, baked it in the oven to soften the solder and let the chip reattach itself, added new conductive paste, reinstalled it and it worked again.
I can't remember the temperatures, but there are tutorials to be found.
How long did your fix last?
I tried this heating of the GPU on a MacBook Pro 15" 2011 and it help up not even two months.
Non รจ una guida. Manca tutto!
This guide only covers removal of the outer glass and LCD display. Where are the rest of the steps?
