Up to 20% off select tools
iMac Intel 27" EMC 2390 RAM Replacement
Views: 41K
View statistics:
Past 24 Hours:
7
Past 7 Days:
38
Past 30 Days:
151
All Time:
41,310
Comments: 19
13 comments on steps, 6 guide comments.
Go to guide comments
Completed: 55
55 people have marked this guide "completed." Will you be next?
Favorites: 17
17 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kits
These kits contain all the parts and tools needed to complete this guide.
Parts
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Upgrade RAM modules for an instant boost in speed.
    1. iMac Intel 27" EMC 2390 RAM Replacement, Access Door: step 1, image 1 of 2 iMac Intel 27" EMC 2390 RAM Replacement, Access Door: step 1, image 2 of 2
      • Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
      • These screws will remain captive in the access door.
      • Remove the access door from your iMac.
      • During reassembly, fasten the access door loosely and align it with the pocket cut into the outer case of the iMac before fully tightening the screws.
      Ask FixBot
    1. iMac Intel 27" EMC 2390 RAM Replacement, RAM: step 2, image 1 of 1
      • Use your fingers or the tip of a spudger to slide the black plastic RAM tray pull tab out of the RAM slot.
      Ask FixBot
    2. iMac Intel 27" EMC 2390 RAM Replacement: step 3, image 1 of 2 iMac Intel 27" EMC 2390 RAM Replacement: step 3, image 2 of 2
      • Pull the black plastic tab away from the iMac to eject the RAM chip from its socket.
      • The RAM modules are firmly seated and may require a fair amount of force to remove.
      • Use your fingers to slide the RAM chip out of its socket.
      • If necessary, repeat this process for the other RAM module(s).
      Ask FixBot
55 other people completed this guide.
Author
with
Walter Galan
712,031 Reputation
1,203 Guides authored
6 Guide Comments
Super easy! I'm not exactly an experienced fixer, but this replacement took no effort at all. (I also replaced the battery of my iphone 4S: that was much much much harder)
Tessa - Reply Share
My wife's ageing iMac currently has 4x2GB, and it is creaking under even light use (on Mavericks... haven't dared upgrade any further yet).
I want to initially upgrade it to 2x8GB, which seems nice and easy. My question is is it then possible to add one more 8GB for a total of 24GB, or would I need to add 2x8GB for a total of 32GB? Will the iMac see and use 3 RAM modules, or does it need to be an even number, like in the old PC days?
Thanks!
Clive Murray - Reply Share
Maximum memory: 16384MB. See crucial for more information :
http://www.crucial.com/usa/en/compatible...
Frederic Morelli - Reply Share
Easy mode. Note that the bits is called PZ1 most screwdriver sets. Also known as Japanese Phillips, the bid comes to a + instead of to a point. A 2.0 flathead will also turn the screw.
Oh and, don't forget to check your black flats back in. Otherwise you'll get too funny little appendages sticking out the bottom when you reattach your access door :)
Kevin McCartney - Reply Share
2 Comments:
* firstly you may have to pull twice on the tab to release both RAMs as sometimes the first slot gets a little stuck.
* secondly - I've been having some trouble with different RAM chips - can anyone please tell me the definitive answer for how much RAM each slot will take, and what speed and latency? My iMac seems "finicky" about brands too!!!
Mike Haines - Reply Share
Past 24 Hours: 7
Past 7 Days: 38
Past 30 Days: 151
All Time: 41,310
