iMac Intel 27" EMC 2390 Access Door Replacement
  1. iMac Intel 27" EMC 2390 Access Door Replacement, Access Door: step 1, image 1 of 2 iMac Intel 27" EMC 2390 Access Door Replacement, Access Door: step 1, image 2 of 2
    • Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
    • These screws will remain captive in the access door.
    • Remove the access door from your iMac.
    • During reassembly, fasten the access door loosely and align it with the pocket cut into the outer case of the iMac before fully tightening the screws.
12 other people completed this guide.
1 Guide Comment
Easy mode. Note that the bits is called PZ1 most screwdriver sets. Also known as Japanese Phillips, the bid comes to a + instead of to a point. A 2.0 flathead will also turn the screw
Kevin McCartney - Reply Share
Past 24 Hours: 1
Past 7 Days: 30
Past 30 Days: 117
All Time: 10,045
