Up to 20% off select tools
iMac Intel 24" EMC 2267 RAM Replacement
Views: 28K
View statistics:
Past 24 Hours:
5
Past 7 Days:
18
Past 30 Days:
96
All Time:
27,815
Comments: 0
Go to guide comments
Completed: 37
37 people have marked this guide "completed." Will you be next?
Favorites: 22
22 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Use this guide to replace or upgrade your RAM chips.
    1. iMac Intel 24" EMC 2267 RAM Replacement, Note - most of this guide was taken from the info for: iMac Intel 20" EMC 2266: step 1, image 1 of 1
      • Lay your iMac front side down on a table with the lower edge facing yourself.
      • Loosen the single Phillips screw PH#2 in the center of the access door.
      • This screw is captive in the access door.
      • Remove the access door from your iMac.
      Ask FixBot
    1. iMac Intel 24" EMC 2267 RAM Replacement, Note - most of this guide was taken from the info for: iMac Intel 20" EMC 2266: step 2, image 1 of 2 iMac Intel 24" EMC 2267 RAM Replacement, Note - most of this guide was taken from the info for: iMac Intel 20" EMC 2266: step 2, image 2 of 2
      • Use the sharp end of a spudger to pull the black plastic RAM tabs out of the memory bay. Formatting help
      • Pull the black plastic RAM tab away from your iMac to eject the RAM chip.
      Ask FixBot
    2. iMac Intel 24" EMC 2267 RAM Replacement: step 3, image 1 of 1
      • Grab the RAM chip by its edges and pull it straight out of its slot.
      • If two RAM chips are installed, repeat this process for the other chip.
      Ask FixBot
37 other people completed this guide.
Author
with
johann beda
3,432 Reputation
15 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 96
All Time: 27,815
