Introduction
Go to step 1 ↓Use this guide to replace a dead PRAM battery.
Tools
Spudger4.9
Loosen the two Phillips screws securing the access door to your iMac.
Remove the access door.
Remove the following screws along the lower edge of your iMac:
Three 6 mm T8 Torx screws
One 8 mm T8 Torx screw
To lift the front bezel off the iMac, simultaneously:
Use your thumbs to press in the RAM arms and hold the iMac down.
Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
Pull the front bezel up with your index fingers.
Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
Use the tip of a spudger to pry the PRAM battery out of its socket on the logic board.
Remove the PRAM battery.
8 other people completed this guide.
