iMac Intel 24" EMC 2111 Logic Board Replacement
Views: 26K
View statistics:
Past 24 Hours:
5
Past 7 Days:
28
Past 30 Days:
112
All Time:
26,346
Comments: 10
9 comments on steps, 1 guide comment.
Go to guide comments
Completed: 13
13 people have marked this guide "completed." Will you be next?
Favorites: 12
12 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 - 4 hours
Difficulty: Difficult
Introduction
Go to step 1 ↓
Use this guide to remove the logic board assembly for service.
Tools
    1. iMac Intel 24" EMC 2111 Logic Board Replacement, Access Door: step 1, image 1 of 2 iMac Intel 24" EMC 2111 Logic Board Replacement, Access Door: step 1, image 2 of 2
      • Loosen the two Phillips screws securing the access door to your iMac.
      • Both screws remain captive within the access door.
      • Remove the access door.
      Ask FixBot
    1. iMac Intel 24" EMC 2111 Logic Board Replacement, Front Bezel: step 2, image 1 of 1
      • Remove the following screws along the lower edge of your iMac:
      • Three 6 mm T8 Torx screws
      • One 8 mm T8 Torx screw
      Ask FixBot
    2. iMac Intel 24" EMC 2111 Logic Board Replacement: step 3, image 1 of 2 iMac Intel 24" EMC 2111 Logic Board Replacement: step 3, image 2 of 2
      • Lay your iMac stand-side down on a flat surface.
      • To lift the front bezel off the iMac, simultaneously:
      • Use your thumbs to press in the RAM arms and hold the iMac down.
      • Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
      • Pull the front bezel up with your index fingers.
      • Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
      Ask FixBot
    3. iMac Intel 24" EMC 2111 Logic Board Replacement: step 4, image 1 of 3 iMac Intel 24" EMC 2111 Logic Board Replacement: step 4, image 2 of 3 iMac Intel 24" EMC 2111 Logic Board Replacement: step 4, image 3 of 3
      • Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge.
      • The third picture shows the top front bezel brackets and their slots cut into the top edge of the iMac's rear case.
      • Do not completely remove the front bezel, as it is still attached by the camera/microphone cables.
      Ask FixBot
    4. iMac Intel 24" EMC 2111 Logic Board Replacement: step 5, image 1 of 1
      • If necessary, remove the strip of tape covering the microphone cable connector.
      • The microphone connector is located near the inside of top edge of your iMac.
      Ask FixBot
    5. iMac Intel 24" EMC 2111 Logic Board Replacement: step 6, image 1 of 3 iMac Intel 24" EMC 2111 Logic Board Replacement: step 6, image 2 of 3 iMac Intel 24" EMC 2111 Logic Board Replacement: step 6, image 3 of 3
      • Disconnect the microphone cable.
      • Disconnect the camera cable by pulling its connector away from the socket on the camera board.
      • The camera cable connector and socket are delicate and easily bent. Remove with caution.
      Ask FixBot
    1. iMac Intel 24" EMC 2111 Logic Board Replacement, Display Assembly: step 7, image 1 of 2 iMac Intel 24" EMC 2111 Logic Board Replacement, Display Assembly: step 7, image 2 of 2
      • Peel the two highlighted EMI shield tabs off the frame of the LCD.
      Ask FixBot
    2. iMac Intel 24" EMC 2111 Logic Board Replacement: step 8, image 1 of 1
      • Remove the two T6 Torx screws securing the display data cable to the logic board.
      Ask FixBot
    3. iMac Intel 24" EMC 2111 Logic Board Replacement: step 9, image 1 of 1
      • Pull the black plastic tab attached to the display data cable connector to disconnect it from the logic board.
      Ask FixBot
    4. iMac Intel 24" EMC 2111 Logic Board Replacement: step 10, image 1 of 2 iMac Intel 24" EMC 2111 Logic Board Replacement: step 10, image 2 of 2
      • Use your fingertips to pull both sides of the wide inverter cable connector out of its socket on the logic board.
      • De-route the inverter cable from its location next to the CPU fan.
      Ask FixBot
    5. iMac Intel 24" EMC 2111 Logic Board Replacement: step 11, image 1 of 1
      • Before attempting this step, we recommend laying your iMac stand-side down on a table to avoid the display falling down.
      • Remove the eight T8 Torx screws securing the display assembly to the rear case.
      • It is helpful to use a thin magnetized screwdriver to remove these screws.
      Ask FixBot
    6. iMac Intel 24" EMC 2111 Logic Board Replacement: step 12, image 1 of 1
      • Remove the display assembly from the iMac.
      Ask FixBot
    1. iMac Intel 24" EMC 2111 Logic Board Replacement, Right Speaker: step 13, image 1 of 2 iMac Intel 24" EMC 2111 Logic Board Replacement, Right Speaker: step 13, image 2 of 2
      • Peel back the piece of EMI tape connecting the bottom edge of the right speaker to the metal frame of the iMac.
      • Peel the tape away from the lower corner of the right speaker.
      Ask FixBot
    2. iMac Intel 24" EMC 2111 Logic Board Replacement: step 14, image 1 of 2 iMac Intel 24" EMC 2111 Logic Board Replacement: step 14, image 2 of 2
      • De-route the right-hand speaker's cable from between the logic board and the optical drive fan.
      • Disconnect the cable from the logic board.
      Ask FixBot
    3. iMac Intel 24" EMC 2111 Logic Board Replacement: step 15, image 1 of 1
      • Remove the 26 mm T10 Torx screw securing the right speaker to the iMac.
      Ask FixBot
    4. iMac Intel 24" EMC 2111 Logic Board Replacement: step 16, image 1 of 1
      • Pull the right speaker away from the logic board and remove it from the iMac.
      Ask FixBot
    1. iMac Intel 24" EMC 2111 Logic Board Replacement, Logic Board: step 17, image 1 of 2 iMac Intel 24" EMC 2111 Logic Board Replacement, Logic Board: step 17, image 2 of 2
      • Use the flat end of a spudger to pry both antenna connectors off their sockets on the AirPort card.
      • The black antenna attaches closest to the bottom edge of the iMac.
      Ask FixBot
    2. iMac Intel 24" EMC 2111 Logic Board Replacement: step 18, image 1 of 1
      • Use both fingertips to disconnect the camera and microphone cable from its socket on the logic board.
      • Pull the connector perpendicular to the face of the logic board.
      Ask FixBot
    3. iMac Intel 24" EMC 2111 Logic Board Replacement: step 19, image 1 of 1
      • Pull the optical drive fan connector toward the top edge of the iMac to disconnect it from the logic board.
      Ask FixBot
    4. iMac Intel 24" EMC 2111 Logic Board Replacement: step 20, image 1 of 1
      • Pull the left speaker connector toward the top edge of the iMac to disconnect it from the logic board.
      Ask FixBot
    5. iMac Intel 24" EMC 2111 Logic Board Replacement: step 21, image 1 of 1
      • Pull the optical drive thermal sensor connector toward the right side of the iMac to disconnect it from its socket.
      Ask FixBot
    6. iMac Intel 24" EMC 2111 Logic Board Replacement: step 22, image 1 of 1
      • If necessary, remove the strip of tape covering the optical drive connector.
      Ask FixBot
    7. iMac Intel 24" EMC 2111 Logic Board Replacement: step 23, image 1 of 3 iMac Intel 24" EMC 2111 Logic Board Replacement: step 23, image 2 of 3 iMac Intel 24" EMC 2111 Logic Board Replacement: step 23, image 3 of 3
      • Gently pull the cable retainer on the optical drive cable ZIF socket toward the right side of the iMac.
      • The retainer should move about 1 mm and stop. Do not attempt to remove the retainer.
      • Pull the optical drive ribbon cable out of its socket, being careful not to rip it in the process.
      Ask FixBot
    8. iMac Intel 24" EMC 2111 Logic Board Replacement: step 24, image 1 of 1
      • Disconnect the hard drive thermal sensor and hard drive fan cables from the logic board by pulling their connectors toward the top edge of the iMac.
      Ask FixBot
    9. iMac Intel 24" EMC 2111 Logic Board Replacement: step 25, image 1 of 1
      • Pull the CPU fan connector toward the left edge of the iMac to disconnect it from the logic board.
      Ask FixBot
    10. iMac Intel 24" EMC 2111 Logic Board Replacement: step 26, image 1 of 2 iMac Intel 24" EMC 2111 Logic Board Replacement: step 26, image 2 of 2
      • Disconnect the power button cable from the logic board.
      • Pull its connector perpendicular to the face of the logic board.
      Ask FixBot
    11. iMac Intel 24" EMC 2111 Logic Board Replacement: step 27, image 1 of 1
      • Use the flat end of a spudger to pry the single Bluetooth antenna off its socket on the Bluetooth board.
      Ask FixBot
    12. iMac Intel 24" EMC 2111 Logic Board Replacement: step 28, image 1 of 1
      • Pull the ambient temperature sensor cable perpendicular to the face of the logic board to disconnect it from its socket.
      Ask FixBot
    13. iMac Intel 24" EMC 2111 Logic Board Replacement: step 29, image 1 of 2 iMac Intel 24" EMC 2111 Logic Board Replacement: step 29, image 2 of 2
      • Disconnect the DC-In cable from the logic board by pulling its cable toward the right side of the iMac while depressing its locking mechanism.
      • It is helpful to use a spudger and pry from alternating sides of the connector to help "walk" it out of its socket.
      Ask FixBot
    14. iMac Intel 24" EMC 2111 Logic Board Replacement: step 30, image 1 of 3 iMac Intel 24" EMC 2111 Logic Board Replacement: step 30, image 2 of 3 iMac Intel 24" EMC 2111 Logic Board Replacement: step 30, image 3 of 3
      • Pull the hard drive SATA data cable perpendicular to the face of the logic board to disconnect it from its socket.
      • To avoid damaging the socket on the logic board, we recommend using a metal spudger to help separate the SATA data cable and its socket.
      Ask FixBot
    15. iMac Intel 24" EMC 2111 Logic Board Replacement: step 31, image 1 of 1
      • Peel the foam tape off the top edge of the heat sink framework.
      Ask FixBot
    16. iMac Intel 24" EMC 2111 Logic Board Replacement: step 32, image 1 of 1
      • Remove the following ten screws:
      • Three 6.6 mm T10 Torx fine thread screws
      • Three 7 mm T10 Torx coarse thread screws
      • Two 9.3 mm T10 Torx coarse thread screws
      • Two 5.3 mm T10 Torx coarse thread screws
      Ask FixBot
    17. iMac Intel 24" EMC 2111 Logic Board Replacement: step 33, image 1 of 2 iMac Intel 24" EMC 2111 Logic Board Replacement: step 33, image 2 of 2
      • Pull the right edge of the logic board slightly away from the rear case to dislodge the rear I/O ports from their bezel.
      • Tilt the top edge of the board away from the rear case and lift the logic board assembly out of the rear case, minding any cables that may get caught.
      • When reinstalling the logic board, it is helpful to use tape to temporarily tuck the cables out of the way until the board is properly seated in the rear case.
      • During reassembly of the logic board, pay attention to the position of the I/O connectors. When the board is back in the case, insert a USB or Thunderbolt cable into one of the connectors to align it perfectly.
      Ask FixBot
13 other people completed this guide.
1 Guide Comment
HI hello, I´m having some problems with this iMac; can someone help me, please. I change the hard drive for a SSD, The problem is there isn´t a startup sound and also no video signal shows, when I turn on, everything is perfect, the 3 fans start running, but thats all.
I´m trying to find the possible damage part with no success.
Could be the motherboard?
Where I can buy it?
Thank you very much and excellents manuals, I always look here.
Victor G M - Reply Share
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 112
All Time: 26,346
