Introduction
If the fan in your 21.5" Retina 4K 2019 iMac is faulty, failing, or badly clogged with dust, use this guide to replace it and return your iMac to cool and quiet operation.
Some images in this guide use an older iMac, which has minor visual differences. These differences do not affect the repair procedure.
Tool used on this step:iMac Intel 21.5" Cardboard Service Wedge$4.99
With the hinge free to move, the iMac will be unbalanced and hard to work on. Place an iMac service wedge, in the stand to stabilize the iMac.
Starting on the left side of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear enclosure.
Use the tool like a pizza cutter—roll it along the gap, cutting the foam adhesive in between the frame and display.
Run the tool up along the left side of the display.
Hold the display with one hand while using your other hand to unplug the display power cable.
Gently pull the fan cable connector straight away from its socket on the logic board.
2 other people completed this guide.
