Introduction
Go to step 1 ↓Use this guide to replace your logic board's BR 2032 PRAM battery.
Tool used on this step:Heavy-Duty Suction Cups (Pair)$16.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Use the tip of a spudger to pry the PRAM battery out of its socket on the logic board.
12 other people completed this guide.
3 Guide Comments
Is this the same battery and procedure for the mid 2011 27”?
Yes, the two iMacs have very similar layouts, so the PRAM battery layout wouldn't be any different
is this the solution of fixing the black screen after press the power bottom behind when starting or restart?
