Up to 20% off select tools
iMac Intel 20" EMC 2266 RAM Replacement
Views: 39K
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
104
All Time:
39,218
Comments: 3
3 comments on steps.
Completed: 93
93 people have marked this guide "completed." Will you be next?
Favorites: 19
19 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 10 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Use this guide to replace or upgrade your RAM chips.
    1. iMac Intel 20" EMC 2266 RAM Replacement, Access Door: step 1, image 1 of 1
      • Lay your iMac front side down on a table with the lower edge facing yourself.
      • Loosen the single Phillips screw in the center of the access door.
      • This screw is captive in the access door.
      • Remove the access door from your iMac.
      Ask FixBot
    1. iMac Intel 20" EMC 2266 RAM Replacement, RAM: step 2, image 1 of 2 iMac Intel 20" EMC 2266 RAM Replacement, RAM: step 2, image 2 of 2
      • Use the sharp end of a spudger to pull the black plastic RAM tabs out of the memory bay.
      • Pull the black plastic RAM tab away from your iMac to eject the RAM chip.
      Ask FixBot
    2. iMac Intel 20" EMC 2266 RAM Replacement: step 3, image 1 of 1
      • Grab the RAM chip by its edges and pull it straight out of its slot.
      • If two RAM chips are installed, repeat this process for the other chip.
      Ask FixBot
93 other people completed this guide.
Author
with
Walter Galan
712,031 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 104
All Time: 39,218
