iMac G5 20" Model A1145 Optical Drive Fan Replacement
  1. iMac G5 20" Model A1145 Optical Drive Fan Replacement, Access Door: step 1, image 1 of 1
    • Orient the iMac face-side down on a table with the bottom edge facing yourself.
    • Remove the two Phillips screws securing the access door to the bottom grille of your iMac.
    • The screws are captive in the access door.
    • Before beginning the repair, unplug the computer and press and hold the power switch for 20-30 seconds, to discharge internal capacitors.
    Ask FixBot
  2. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 2, image 1 of 1
    • Remove the access door.
    Ask FixBot
  3. iMac G5 20" Model A1145 Optical Drive Fan Replacement, Front Bezel: step 3, image 1 of 1
    • Remove the three T8 Torx screws securing the front bezel to the rear case along the lower edge of the iMac.
    Ask FixBot
  4. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 4, image 1 of 2 iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 4, image 2 of 2
    • Turn the computer over.
    • Use your thumbs to press both RAM arms in past the front bezel for enough clearance to lift it off the rear case.
    Ask FixBot
  5. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 5, image 1 of 1
    • While holding the RAM arms in with your thumbs, lift the lower edge of the front bezel enough to clear the rear case.
    Ask FixBot
  6. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 6, image 1 of 3 iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 6, image 2 of 3 iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 6, image 3 of 3
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Re-orient your iMac so it sits upright on the stand.
    • Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
    • Push the card toward the top of the iMac to release the front bezel latch.
    • Pull the front bezel away from the rear case.
    • Repeat this process for the other side of the front bezel.
    • It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches.
    • If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
    • Alternatively, you can use a strong magnet by holding it to the front top left/right corner of the display. You will hear a snapping sound when the hatch is released.
    Ask FixBot
  7. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 7, image 1 of 1
    • Lay your iMac stand-side down on a table.
    • Lift the front bezel from its lower edge and rotate it away from the rest of your iMac, minding the RAM arms that may get caught.
    • Lay the front bezel above the rest of the iMac.
    Ask FixBot
  8. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 8, image 1 of 1
    • If necessary, remove the piece of kapton tape wrapped around the microphone and camera connectors.
    Ask FixBot
  9. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 9, image 1 of 2 iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 9, image 2 of 2
    • Disconnect both the camera and microphone cables.
    Ask FixBot
  10. iMac G5 20" Model A1145 Optical Drive Fan Replacement, Lower EMI Shield: step 10, image 1 of 1
    • Peel the lower EMI shield off the lower edge of the iMac and off the two vertical 4" sections on either side of the iMac.
    • It is not necessary to peel the lower EMI shield off the display.
    Ask FixBot
  11. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 11, image 1 of 1
    • Tape the lower EMI shield up against the face of the display to keep it out of the way while you work.
    Ask FixBot
  12. iMac G5 20" Model A1145 Optical Drive Fan Replacement, Display: step 12, image 1 of 1
    • Remove the two T6 Torx screws securing the display data cable connector to the logic board.
    Ask FixBot
  13. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 13, image 1 of 1
    • To disconnect the display data cable, grab its connector's black tab and pull it away from the face of the logic board.
    Ask FixBot
  14. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 14, image 1 of 1
    • Peel back the two EMI tape strips from the left and right edges of the display.
    • During reassembly, it is helpful to use several small strips of tape to hold the EMI shielding along the left and right edges of the display footprint out of the way before lowering the display into the rear case of your iMac.
    Ask FixBot
  15. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 15, image 1 of 2 iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 15, image 2 of 2
    • Remove the four recessed T10 Torx screws securing the display to the rear case.
    • Bit drivers tend to be too short to reach these screws. Be sure to have a magnetic thin-shafted T10 Torx screwdriver on hand.
    Ask FixBot
  16. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 16, image 1 of 1
    • Lift the lower edge of the display slightly out of the rear case.
    • Disconnect both inverter cables (shown in red) by pulling their connectors toward the bottom edge of your iMac.
    Ask FixBot
  17. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 17, image 1 of 1
    • Lift the display until it is nearly perpendicular to the rear case.
    • Disconnect the remaining two inverter cables (shown in red) by pulling their connectors toward the top edge of your iMac.
    Ask FixBot
  18. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 18, image 1 of 1
    • While holding the display perpendicular to the rear case, pull it upward to peel off the EMI shield stuck to its upper edge.
    Ask FixBot
  19. iMac G5 20" Model A1145 Optical Drive Fan Replacement, Logic board: step 19, image 1 of 1
    • Disconnect the IR board cable by pulling its connector away from the socket on the IR board.
    Ask FixBot
  20. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 20, image 1 of 2 iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 20, image 2 of 2
    • Remove the two T6 Torx screws securing the IR board bracket to the IR board.
    Ask FixBot
  21. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 21, image 1 of 1
    • De-route the IR cable from under the aluminum heat sink and tuck it behind the optical drive to keep it out of the way.
    Ask FixBot
  22. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 22, image 1 of 2 iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 22, image 2 of 2
    • Remove the single T10 Torx screw securing the left speaker to the rear case.
    • The screw for the left speaker has coarse threads.
    • Lift the left speaker out of the rear case and de-route its cable across the logic board.
    Ask FixBot
  23. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 23, image 1 of 2 iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 23, image 2 of 2
    • Remove the single T10 Torx screw securing the right speaker to the rear case.
    • The right speaker screw has fine threads.
    • Lift the right speaker out of the rear case, minding the short cable between the speaker and its connector (located slightly above the right speaker).
    Ask FixBot
  24. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 24, image 1 of 1
    • Disconnect the speakers from the logic board by pulling their connector toward the top edge of the iMac.
    Ask FixBot
  25. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 25, image 1 of 1
    • Remove the two Phillips or two T6 Torx screws securing the AirPort/Bluetooth board to the logic board.
    Ask FixBot
  26. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 26, image 1 of 1
    • Use your finger to lift the AirPort/Bluetooth board from its left edge, disconnecting it from the logic board.
    • Lift the board from its left edge only.
    Ask FixBot
  27. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 27, image 1 of 2 iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 27, image 2 of 2
    • Use the flat end of a spudger to pry both antenna cable connectors up off the AirPort/Bluetooth board.
    Ask FixBot
  28. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 28, image 1 of 2 iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 28, image 2 of 2
    • Disconnect the DC-in cable by simultaneously depressing both locking arms and pulling its connector away from the socket on the logic board toward the top of your iMac.
    • After both locking arms pass their retaining tabs, it is helpful to push the arms toward the top edge of your iMac while wiggling the connector.
    Ask FixBot
  29. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 29, image 1 of 1
    • Disconnect the ambient light sensor by pulling its connector away from the face of the logic board.
    Ask FixBot
  30. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 30, image 1 of 2 iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 30, image 2 of 2
    • Disconnect the optical drive fan from the logic board.
    • To aid in removal, it is helpful to use both of your thumbnails to push the ears on either side of the connector toward the top edge of the iMac.
    Ask FixBot
  31. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 31, image 1 of 2 iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 31, image 2 of 2
    • Disconnect the IR/camera cable from the logic board.
    • This connector is especially wide and prone to breakage.
    • To aid in removal, it is helpful to use one hand to pinch the cables against a spudger and pull up toward the top edge of the iMac while pulling up gently on the cables with your other hand.
    Ask FixBot
  32. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 32, image 1 of 1
    • Disconnect the optical drive thermal sensor cable from the logic board by pulling its connector toward the left edge of the iMac.
    Ask FixBot
  33. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 33, image 1 of 1
    • Remove the two T6 Torx screws securing the optical drive connector to the logic board.
    Ask FixBot
  34. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 34, image 1 of 1
    • Use the flat end of a spudger to pry the optical drive connector up off the logic board.
    • It is helpful to insert the spudger under the top or bottom edge of the connector and twist to separate the connector from the logic board.
    Ask FixBot
  35. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 35, image 1 of 1
    • Disconnect the CPU fan from the logic board by pulling its connector toward the top edge of the iMac.
    Ask FixBot
  36. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 36, image 1 of 1
    • Disconnect the hard drive thermal sensor from the logic board by pulling its connector toward the top edge of the iMac.
    Ask FixBot
  37. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 37, image 1 of 1
    • Disconnect the hard drive fan by pulling its connector away from the face of the logic board.
    Ask FixBot
  38. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 38, image 1 of 1
    • Disconnect the power button cable by pulling its connector away from the face of the logic board.
    Ask FixBot
  39. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 39, image 1 of 1
    • Remove the two T6 Torx screws near the top of the heat sinks.
    Ask FixBot
  40. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 40, image 1 of 1
    • Remove the following seven screws securing the logic board to the rear case:
    • Three coarse-thread T10 Torx.
    • Three fine-thread T10 Torx.
    • One long coarse-thread T10 Torx.
    Ask FixBot
  41. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 41, image 1 of 2 iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 41, image 2 of 2
    • Tuck the RAM arms into the iMac so they rest on the perforated metal grille along its lower edge.
    Ask FixBot
  42. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 42, image 1 of 1
    • Rotate the top of the logic board toward yourself slightly.
    • Pull the right edge of the logic board toward yourself slightly to free the I/O ports from the rear case, being careful not to bend the board.
    • Continue rotating the board toward yourself until you have enough room to reach the SATA connector, shown in the next step.
    Ask FixBot
  43. iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 43, image 1 of 2 iMac G5 20" Model A1145 Optical Drive Fan Replacement: step 43, image 2 of 2
    • Continue rotating the board toward yourself until you have enough room to reach the SATA connector (shown in red).
    • Insert the blunt end of a metal spudger between the SATA connector and its socket. Twist the shaft of the metal spudger to separate the connector from its socket.
    • Disconnect the SATA cable from the logic board.
    • Lift the logic board out of the rear case by its edges, minding any cables that may get caught.
    Ask FixBot
  44. iMac G5 20" Model A1145 Optical Drive Fan Replacement, Optical Drive Fan: step 44, image 1 of 1
    • Lift the optical drive fan off the plastic posts protruding from the rear case.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 56
All Time: 5,068
