iMac G5 20" Model A1145 Display Replacement
Views: 17K
View statistics:
Past 24 Hours:
5
Past 7 Days:
22
Past 30 Days:
110
All Time:
17,156
Comments: 12
12 comments on steps.
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
Remove the display to access most of your iMac's internals.
Tools
    1. iMac G5 20" Model A1145 Display Replacement, Access Door: step 1, image 1 of 1
      • Orient the iMac face-side down on a table with the bottom edge facing yourself.
      • Remove the two Phillips screws securing the access door to the bottom grille of your iMac.
      • The screws are captive in the access door.
      • Before beginning the repair, unplug the computer and press and hold the power switch for 20-30 seconds, to discharge internal capacitors.
      Ask FixBot
    2. iMac G5 20" Model A1145 Display Replacement: step 2, image 1 of 1
      • Remove the access door.
      Ask FixBot
    1. iMac G5 20" Model A1145 Display Replacement, Front Bezel: step 3, image 1 of 1
      • Remove the three T8 Torx screws securing the front bezel to the rear case along the lower edge of the iMac.
      Ask FixBot
    2. iMac G5 20" Model A1145 Display Replacement: step 4, image 1 of 2 iMac G5 20" Model A1145 Display Replacement: step 4, image 2 of 2
      • Turn the computer over.
      • Use your thumbs to press both RAM arms in past the front bezel for enough clearance to lift it off the rear case.
      Ask FixBot
    3. iMac G5 20" Model A1145 Display Replacement: step 5, image 1 of 1
      • While holding the RAM arms in with your thumbs, lift the lower edge of the front bezel enough to clear the rear case.
      Ask FixBot
    4. iMac G5 20" Model A1145 Display Replacement: step 6, image 1 of 3 iMac G5 20" Model A1145 Display Replacement: step 6, image 2 of 3 iMac G5 20" Model A1145 Display Replacement: step 6, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Re-orient your iMac so it sits upright on the stand.
      • Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
      • Push the card toward the top of the iMac to release the front bezel latch.
      • Pull the front bezel away from the rear case.
      • Repeat this process for the other side of the front bezel.
      • It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches.
      • If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
      • Alternatively, you can use a strong magnet by holding it to the front top left/right corner of the display. You will hear a snapping sound when the hatch is released.
      Ask FixBot
    5. iMac G5 20" Model A1145 Display Replacement: step 7, image 1 of 1
      • Lay your iMac stand-side down on a table.
      • Lift the front bezel from its lower edge and rotate it away from the rest of your iMac, minding the RAM arms that may get caught.
      • Lay the front bezel above the rest of the iMac.
      Ask FixBot
    6. iMac G5 20" Model A1145 Display Replacement: step 8, image 1 of 1
      • If necessary, remove the piece of kapton tape wrapped around the microphone and camera connectors.
      Ask FixBot
    7. iMac G5 20" Model A1145 Display Replacement: step 9, image 1 of 2 iMac G5 20" Model A1145 Display Replacement: step 9, image 2 of 2
      • Disconnect both the camera and microphone cables.
      Ask FixBot
    1. iMac G5 20" Model A1145 Display Replacement, Lower EMI Shield: step 10, image 1 of 1
      • Peel the lower EMI shield off the lower edge of the iMac and off the two vertical 4" sections on either side of the iMac.
      • It is not necessary to peel the lower EMI shield off the display.
      Ask FixBot
    2. iMac G5 20" Model A1145 Display Replacement: step 11, image 1 of 1
      • Tape the lower EMI shield up against the face of the display to keep it out of the way while you work.
      Ask FixBot
    1. iMac G5 20" Model A1145 Display Replacement, Display: step 12, image 1 of 1
      • Remove the two T6 Torx screws securing the display data cable connector to the logic board.
      Ask FixBot
    2. iMac G5 20" Model A1145 Display Replacement: step 13, image 1 of 1
      • To disconnect the display data cable, grab its connector's black tab and pull it away from the face of the logic board.
      Ask FixBot
    3. iMac G5 20" Model A1145 Display Replacement: step 14, image 1 of 1
      • Peel back the two EMI tape strips from the left and right edges of the display.
      • During reassembly, it is helpful to use several small strips of tape to hold the EMI shielding along the left and right edges of the display footprint out of the way before lowering the display into the rear case of your iMac.
      Ask FixBot
    4. iMac G5 20" Model A1145 Display Replacement: step 15, image 1 of 2 iMac G5 20" Model A1145 Display Replacement: step 15, image 2 of 2
      • Remove the four recessed T10 Torx screws securing the display to the rear case.
      • Bit drivers tend to be too short to reach these screws. Be sure to have a magnetic thin-shafted T10 Torx screwdriver on hand.
      Ask FixBot
    5. iMac G5 20" Model A1145 Display Replacement: step 16, image 1 of 1
      • Lift the lower edge of the display slightly out of the rear case.
      • Disconnect both inverter cables (shown in red) by pulling their connectors toward the bottom edge of your iMac.
      Ask FixBot
    6. iMac G5 20" Model A1145 Display Replacement: step 17, image 1 of 1
      • Lift the display until it is nearly perpendicular to the rear case.
      • Disconnect the remaining two inverter cables (shown in red) by pulling their connectors toward the top edge of your iMac.
      Ask FixBot
    7. iMac G5 20" Model A1145 Display Replacement: step 18, image 1 of 1
      • While holding the display perpendicular to the rear case, pull it upward to peel off the EMI shield stuck to its upper edge.
      Ask FixBot
11 other people completed this guide.
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 110
All Time: 17,156
