iMac G5 20" Model A1076 Rear Panel Replacement
Views: 12K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
106
All Time:
11,844
Comments: 1
1 comment on steps.
Completed: 13
13 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Remove the rear panel to gain access to the innards of your iMac.
Tools
    1. iMac G5 20" Model A1076 Rear Panel Replacement, Rear Panel: step 1, image 1 of 1
      • Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
      • Loosen the three Phillips screws securing the rear panel to the iMac.
      • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
      Ask FixBot
    2. iMac G5 20" Model A1076 Rear Panel Replacement: step 2, image 1 of 2 iMac G5 20" Model A1076 Rear Panel Replacement: step 2, image 2 of 2
      • Lift the rear panel slightly near the bottom of the iMac.
      • Pull the rear panel toward yourself and remove it from the iMac.
      Ask FixBot
13 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 106
All Time: 11,844
