iMac G5 20" Model A1076 RAM Replacement
Views: 25K
View statistics:
Past 24 Hours:
6
Past 7 Days:
30
Past 30 Days:
114
All Time:
24,507
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 31
31 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Instantly increase the speed of your iMac by upgrading the RAM.
Parts
Tools
    1. iMac G5 20" Model A1076 RAM Replacement, Rear Panel: step 1, image 1 of 1
      • Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
      • Loosen the three Phillips screws securing the rear panel to the iMac.
      • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
      Ask FixBot
    2. iMac G5 20" Model A1076 RAM Replacement: step 2, image 1 of 2 iMac G5 20" Model A1076 RAM Replacement: step 2, image 2 of 2
      • Lift the rear panel slightly near the bottom of the iMac.
      • Pull the rear panel toward yourself and remove it from the iMac.
      Ask FixBot
    1. iMac G5 20" Model A1076 RAM Replacement, RAM: step 3, image 1 of 2 iMac G5 20" Model A1076 RAM Replacement, RAM: step 3, image 2 of 2
      • Rotate each of the two RAM retaining arms away from the RAM chip.
      • The chip will partially pop out at the same time as the arms are pulled out to either side.
      • Pull the RAM chip straight away from its socket.
      • Repeat this process for the other RAM chip.
      • Be sure the RAM arms are rotated fully outward before installing new RAM chips.
      Ask FixBot
31 other people completed this guide.
2 Guide Comments
como se llama la cajita blanca que esta debajo de las memorias y que funcion tiene?
max sanchez - Reply Share
Easy as pie, instructions were right to the point, thank you.
Hemi Andersen - Reply Share
Past 24 Hours: 6
Past 7 Days: 30
Past 30 Days: 114
All Time: 24,507
