iMac G5 20" Model A1076 Hard Drive Replacement
Views: 78K
View statistics:
Past 24 Hours:
3
Past 7 Days:
44
Past 30 Days:
202
All Time:
77,916
Comments: 6
5 comments on steps, 1 guide comment.
Go to guide comments
Completed: 149
149 people have marked this guide "completed." Will you be next?
Favorites: 15
15 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 15 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Upgrade your hard drive for more storage capacity.
Parts
Tools
    1. iMac G5 20" Model A1076 Hard Drive Replacement, Rear Panel: step 1, image 1 of 1
      • Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
      • Loosen the three Phillips screws securing the rear panel to the iMac.
      • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
      Ask FixBot
    2. iMac G5 20" Model A1076 Hard Drive Replacement: step 2, image 1 of 2 iMac G5 20" Model A1076 Hard Drive Replacement: step 2, image 2 of 2
      • Lift the rear panel slightly near the bottom of the iMac.
      • Pull the rear panel toward yourself and remove it from the iMac.
      Ask FixBot
    1. iMac G5 20" Model A1076 Hard Drive Replacement, Hard Drive: step 3, image 1 of 1
      • Remove the following three screws:
      • One shouldered 12.4 mm Phillips.
      • Two 7 mm T10 Torx.
      Ask FixBot
    2. iMac G5 20" Model A1076 Hard Drive Replacement: step 4, image 1 of 1
      • The following action is optional. If you skip this step, be very careful not to strain the thermal sensor cable as you disconnect the hard drive cables and transfer this bracket to your new hard drive.
      • Lift the hard drive slightly and disconnect the hard drive thermal sensor connector.
      Ask FixBot
    3. iMac G5 20" Model A1076 Hard Drive Replacement: step 5, image 1 of 2 iMac G5 20" Model A1076 Hard Drive Replacement: step 5, image 2 of 2
      • Insert the flat end of a spudger into the gap between the SATA data connector and the hard drive.
      • Twist the spudger to separate the SATA data connector from the hard drive, then disconnect it from the hard drive.
      • Repeat this process for the SATA power connector.
      Ask FixBot
    4. iMac G5 20" Model A1076 Hard Drive Replacement: step 6, image 1 of 1
      • Lift the hard drive out of the iMac.
      • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
      Ask FixBot
    1. iMac G5 20" Model A1076 Hard Drive Replacement, Hard Drive: step 7, image 1 of 1
      • Remove the two 15 mm shouldered T10 Torx screws from the hard drive and remove the bracket.
      Ask FixBot
    2. iMac G5 20" Model A1076 Hard Drive Replacement: step 8, image 1 of 1
      • Remove the two 6 mm T10 Torx screws from the hard drive and remove the hard drive bracket.
      • The hard drive bracket with the thermal sensor board is attached to the SATA connector side of the hard drive.
      Ask FixBot
149 other people completed this guide.
1 Guide Comment
Very helpful and easy guide. Thanks!
Bojan A - Reply Share
Past 24 Hours: 3
Past 7 Days: 44
Past 30 Days: 202
All Time: 77,916
