iMac G5 20" Model A1076 Fan Duct Replacement
Views: 10K
View statistics:
Past 24 Hours:
2
Past 7 Days:
33
Past 30 Days:
104
All Time:
9,984
Comments: 2
2 comments on steps.
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Easy
Introduction
Go to step 1 ↓
The fan duct directs air across the heat sink on the logic board.
Tools
    1. iMac G5 20" Model A1076 Fan Duct Replacement, Rear Panel: step 1, image 1 of 1
      • Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
      • Loosen the three Phillips screws securing the rear panel to the iMac.
      • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
      Ask FixBot
    2. iMac G5 20" Model A1076 Fan Duct Replacement: step 2, image 1 of 2 iMac G5 20" Model A1076 Fan Duct Replacement: step 2, image 2 of 2
      • Lift the rear panel slightly near the bottom of the iMac.
      • Pull the rear panel toward yourself and remove it from the iMac.
      Ask FixBot
    1. iMac G5 20" Model A1076 Fan Duct Replacement, Fan Duct: step 3, image 1 of 1
      • Remove the following two screws:
      • One 11 mm T10 Torx.
      • One 10.6 mm T8 Torx.
      Ask FixBot
    2. iMac G5 20" Model A1076 Fan Duct Replacement: step 4, image 1 of 1
      • Lift the fan duct out of the chassis.
      Ask FixBot
5 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 33
Past 30 Days: 104
All Time: 9,984
