Introduction
Go to step 1 ↓Like brain surgery? Use this guide to replace your logic board.
Tools
Spudger4.9
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Rotate each of the two RAM retaining arms away from the RAM chip.
Pull the RAM chip straight away from its socket.
Remove the three 8 mm brass Phillips screws securing the optical drive to the midplane.
Rotate the center Phillips screw on the bottom of the iMac clockwise until the rear panel clamp contacts the edge of the case.
Tool used on this step:Heavy-Duty Spudger$4.99
While depressing the connector lock, insert the flat end of a heavy duty spudger into the gap between the power supply connector and its socket.
Twist the heavy duty spudger to slightly separate the connector from its socket.
Disconnect the hard drive thermal sensor cable from the hard drive thermal sensor board.
62 other people completed this guide.
