Up to 20% off select tools
iMac 27" 2017 Thermal Paste Replacement
Views: 9.7K
View statistics:
Past 24 Hours:
7
Past 7 Days:
48
Past 30 Days:
245
All Time:
9,689
Comments: 4
4 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Community-Contributed Guide
Needs Transcription
This guide is in video form only. Help make it more accessible by transcribing each action of the procedure into a separate step and adding photos.
Parts
Tools
Introduction
Hi everyone, In this video guide, I gonna show you how to disassemble the iMac, clean it from dust and replace thermal paste. Use this guide to prevent your iMac from overheating.
Video Instructions
To reassemble your device, follow these instructions.
3 other people completed this guide.
Author
with
Arty
34,705 Reputation
110 Guides authored
4 Guide Comments
what is the thickness of the gaskets?
Andrey Kushnir - Reply Share
The GPU RAM Thermal Pads are 1.5 thick.
While Apple used a thicker gaping paste (white in color) as it was easier to used on a factory floor. It was not very effective in transferring the heat away. The quality of the thermal pad also plays a role here as well as the GPU's thermal paste. We need to move the heat from the GPU effectively as its heat ramp up can be quite fast, but we don't want to dump the heat sink heat to the RAM so we don't want to effective movement of heat transferring in the wrong direction. This is more so when heavy graphics are being run. It is advised to install a good thermal monitoring App watching once's thermals and ramping up the fans RPM to more aggressively cool the system during heavy work loads.
DanJ - Reply Share
I used the 1.5 mm Thermal pads and found them to be too thick, which caused alignment of the heat sink to be slightly different which caused the alignment of the hidden screw hole to not be in the correct position, which didn't allow me to insert and tighten the screw....I ended up using the old paste, but will need to open it up again to finish the job...
S. Baxter - Reply Share
I always measure the gap as Apple uses a few different venders. I’ve often need to use 1.0 mm. Don’t reuse the old paste stick with the pads.
DanJ - Reply Share
Past 24 Hours: 7
Past 7 Days: 48
Past 30 Days: 245
All Time: 9,689
