iLive IKBC384S Motherboard Replacement
  1. iLive IKBC384S Motherboard Replacement, Top Cover: step 1, image 1 of 2 iLive IKBC384S Motherboard Replacement, Top Cover: step 1, image 2 of 2
    • Make sure you remove all seven 3 mm screws before proceeding to the next step.
    Ask FixBot
  2. iLive IKBC384S Motherboard Replacement: step 2, image 1 of 2 iLive IKBC384S Motherboard Replacement: step 2, image 2 of 2
    • Use iOpener or heat gun on all sides except the front.
    Ask FixBot
  3. iLive IKBC384S Motherboard Replacement: step 3, image 1 of 2 iLive IKBC384S Motherboard Replacement: step 3, image 2 of 2
    • Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
    • The top of the device will be very difficult to remove because of the adhesive holding it together.
    Ask FixBot
  4. iLive IKBC384S Motherboard Replacement, Motherboard: step 4, image 1 of 1
    • After removing the top of the device, locate the screws on the motherboard. Gently unscrew all four of the 3.5mm screws on the motherboard.
    Ask FixBot
  5. iLive IKBC384S Motherboard Replacement: step 5, image 1 of 2 iLive IKBC384S Motherboard Replacement: step 5, image 2 of 2
    • Unplug the ribbon cable connected to the motherboard that stems from the disc drive.
    • Disconnect the two power connectors from the motherboard.
    Ask FixBot
  6. iLive IKBC384S Motherboard Replacement: step 6, image 1 of 1
    • You will need to desolder the antenna.
    • Be sure to desolder the piece connected to the motherboard not the wire.
    Ask FixBot
  7. iLive IKBC384S Motherboard Replacement: step 7, image 1 of 1
    • You will need to remove the speakers and power connector.
    • Once you have removed all of these from the motherboard, the motherboard can be removed
    Ask FixBot
Tracy Walts
201 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 40
All Time: 476
