iLive IKBC384S Disk Drive Replacement
    1. iLive IKBC384S Disk Drive Replacement, Top Cover: step 1, image 1 of 2 iLive IKBC384S Disk Drive Replacement, Top Cover: step 1, image 2 of 2
      • Make sure you remove all seven 3 mm screws before proceeding to the next step.
      Ask FixBot
    2. iLive IKBC384S Disk Drive Replacement: step 2, image 1 of 2 iLive IKBC384S Disk Drive Replacement: step 2, image 2 of 2
      • Use iOpener or heat gun on all sides except the front.
      Ask FixBot
    3. iLive IKBC384S Disk Drive Replacement: step 3, image 1 of 2 iLive IKBC384S Disk Drive Replacement: step 3, image 2 of 2
      • Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
      • The top of the device will be very difficult to remove because of the adhesive holding it together.
      Ask FixBot
    1. iLive IKBC384S Disk Drive Replacement, Disk Drive: step 4, image 1 of 2 iLive IKBC384S Disk Drive Replacement, Disk Drive: step 4, image 2 of 2
      • Remove all four screws(13.5 mm in length) that are securing the device
      Ask FixBot
    2. iLive IKBC384S Disk Drive Replacement: step 5, image 1 of 2 iLive IKBC384S Disk Drive Replacement: step 5, image 2 of 2
      • Remove both of the connected cords on the motherboard.
      • Also remove the flat ribbon cable that is connected to the motherboard.
      • Once you have removed all screws and cables connected to motherboard the disk drive can be easily removed
      Ask FixBot
Allen Dover
401 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 18
All Time: 658
