Tools
Introduction
Go to step 1 ↓This guide instructs you to replace the screen in an iHome iPL8. The process includes using two sizes of screwdrivers.
Turn the device over to access the bottom panel.
Locate the 6mm Phillips #2 screw under the label "unscrew to open door."
Keeping your device upside-down, locate the four 6mm Phillips #2 screws near each corner.
Remove the four 6mm Phillips #2 screws.
Locate the green circuit board. This panel is clipped onto two black, circular-shaped columns at two corners.
Pull out the green circuit board on the two corners.
The green circuit board is attached to a black box at the bottom. Flip the panel and the black box together to open the device.
Look at the side of the device. You will see a green panel connecting to the black box by a white stripe.
Remove the four 2.5 mm Phillips #1 screws on the green panel.
Flip the green panel to reveal the front of the screen.
