iHome iPL8 Lightning Connector Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
13
Past 30 Days:
69
All Time:
1,082
Comments: 3
3 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide instructs you to replace the lightning connector in an iHome iPL8. The process includes using two sizes of screwdrivers.
Tools
    1. iHome iPL8 Lightning Connector Replacement, Battery: step 1, image 1 of 1
      • Turn the device over to access the bottom panel.
      • Locate the 6mm Phillips #2 screw under the label "unscrew to open door."
      Ask FixBot
    2. iHome iPL8 Lightning Connector Replacement: step 2, image 1 of 1
      • Using a Phillips #2 screwdriver, unscrew the captive screw.
      • Keep turning until the screw and the door are loose.
      Ask FixBot
    3. iHome iPL8 Lightning Connector Replacement: step 3, image 1 of 1
      • Lift and remove the battery access panel.
      • The captive screw will remain attached to the panel.
      Ask FixBot
    4. iHome iPL8 Lightning Connector Replacement: step 4, image 1 of 2 iHome iPL8 Lightning Connector Replacement: step 4, image 2 of 2
      • Gently press on the rim of the 3V battery.
      • Remove the 3V battery.
      Ask FixBot
    1. iHome iPL8 Lightning Connector Replacement, Lightning Connector: step 5, image 1 of 1
      • Keeping your device upside-down, locate the four 6mm Phillips #2 screws near each corner.
      • Remove the four 6mm Phillips #2 screws.
      Ask FixBot
    2. iHome iPL8 Lightning Connector Replacement: step 6, image 1 of 1
      • Remove the four round pads from the bottom of the device.
      • There are two additional 6mm Phillips #2 screws under the pads.
      • Using a Phillips #2 screwdriver, remove the two remaining screws.
      • Put your hand on the silver bottom case and gently pull it outward.
      Ask FixBot
    3. iHome iPL8 Lightning Connector Replacement: step 7, image 1 of 2 iHome iPL8 Lightning Connector Replacement: step 7, image 2 of 2
      • Locate the green circuit board. This panel is clipped onto two black, circular-shaped columns at two corners.
      • Pull out the green circuit board on the two corners.
      • The green circuit board is attached to a black box at the bottom. Flip the panel and the black box together to open the device.
      Ask FixBot
    4. iHome iPL8 Lightning Connector Replacement: step 8, image 1 of 2 iHome iPL8 Lightning Connector Replacement: step 8, image 2 of 2
      • Remove the two 2.5 mm Phillips #1 screws securing the lightning dock assembly to the device.
      • Remove the two screws and the black cover.
      • Gently remove the lightning dock assembly.
      • The lightning dock assembly is connected to wires.
      Ask FixBot
    5. iHome iPL8 Lightning Connector Replacement: step 9, image 1 of 3 iHome iPL8 Lightning Connector Replacement: step 9, image 2 of 3 iHome iPL8 Lightning Connector Replacement: step 9, image 3 of 3
      • Remove the two 2.5mm screws using a Phillips #1 screwdriver.
      • Remove the back cover.
      • Use your fingers to reposition the lightning connector.
      • Make sure ALL of the lightning connector is exposed.
      Ask FixBot
Chen Zhong
569 Reputation
4 Guides authored
UC Davis, Team S18-G5, Lore Winter 2019 Member of UC Davis, Team S18-G5, Lore Winter 2019
UCD-LORE-W19S18G5
3 Members
48 Guides authored
3 Guide Comments
where can I find the replacement lightning connector?
Bond 007 and a Half - Reply Share
Greetings, did you ever find the connector replacement? I am asking so that I can purchase. Thank you in advance for your reply.
Shawn Simmons - Reply Share
I’m trying to find the replacement part to buy too.
Wendy - Reply Share
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 69
All Time: 1,082
