Up to 20% off select tools
iHome iPL8 Battery Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
51
All Time:
546
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide instructs you to replace the battery in an iHome iPL8. The process includes using screwdriver and removing bottom door of the device to detach the battery.
    1. iHome iPL8 Battery Replacement, Battery: step 1, image 1 of 1
      • Turn the device over to access the bottom panel.
      • Locate the 6mm Phillips #2 screw under the label "unscrew to open door."
      Ask FixBot
    2. iHome iPL8 Battery Replacement: step 2, image 1 of 1
      • Using a Phillips #2 screwdriver, unscrew the captive screw.
      • Keep turning until the screw and the door are loose.
      Ask FixBot
    3. iHome iPL8 Battery Replacement: step 3, image 1 of 1
      • Lift and remove the battery access panel.
      • The captive screw will remain attached to the panel.
      Ask FixBot
    4. iHome iPL8 Battery Replacement: step 4, image 1 of 2 iHome iPL8 Battery Replacement: step 4, image 2 of 2
      • Gently press on the rim of the 3V battery.
      • Remove the 3V battery.
      Ask FixBot
Author
with
Chen Zhong
569 Reputation
4 Guides authored
UC Davis, Team S18-G5, Lore Winter 2019 Member of UC Davis, Team S18-G5, Lore Winter 2019
UCD-LORE-W19S18G5
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 51
All Time: 546
