Up to 20% off select tools
iHome iPL8 Buttons Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
13
Past 30 Days:
57
All Time:
683
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide instructs you to replace the buttons in an iHome iPL8. The process includes using two sizes of screwdrivers.
    1. iHome iPL8  Buttons Replacement, Battery: step 1, image 1 of 1
      • Turn the device over to access the bottom panel.
      • Locate the 6mm Phillips #2 screw under the label "unscrew to open door."
      Ask FixBot
    2. iHome iPL8  Buttons Replacement: step 2, image 1 of 1
      • Using a Phillips #2 screwdriver, unscrew the captive screw.
      • Keep turning until the screw and the door are loose.
      Ask FixBot
    3. iHome iPL8  Buttons Replacement: step 3, image 1 of 1
      • Lift and remove the battery access panel.
      • The captive screw will remain attached to the panel.
      Ask FixBot
    4. iHome iPL8  Buttons Replacement: step 4, image 1 of 2 iHome iPL8  Buttons Replacement: step 4, image 2 of 2
      • Gently press on the rim of the 3V battery.
      • Remove the 3V battery.
      Ask FixBot
    1. iHome iPL8  Buttons Replacement, Lightning Connector: step 5, image 1 of 1
      • Keeping your device upside-down, locate the four 6mm Phillips #2 screws near each corner.
      • Remove the four 6mm Phillips #2 screws.
      Ask FixBot
    2. iHome iPL8  Buttons Replacement: step 6, image 1 of 1
      • Remove the four round pads from the bottom of the device.
      • There are two additional 6mm Phillips #2 screws under the pads.
      • Using a Phillips #2 screwdriver, remove the two remaining screws.
      • Put your hand on the silver bottom case and gently pull it outward.
      Ask FixBot
    3. iHome iPL8  Buttons Replacement: step 7, image 1 of 2 iHome iPL8  Buttons Replacement: step 7, image 2 of 2
      • Locate the green circuit board. This panel is clipped onto two black, circular-shaped columns at two corners.
      • Pull out the green circuit board on the two corners.
      • The green circuit board is attached to a black box at the bottom. Flip the panel and the black box together to open the device.
      Ask FixBot
    4. iHome iPL8  Buttons Replacement: step 8, image 1 of 2 iHome iPL8  Buttons Replacement: step 8, image 2 of 2
      • Remove the two 2.5 mm Phillips #1 screws securing the lightning dock assembly to the device.
      • Remove the two screws and the black cover.
      • Gently remove the lightning dock assembly.
      • The lightning dock assembly is connected to wires.
      Ask FixBot
    5. iHome iPL8  Buttons Replacement: step 9, image 1 of 3 iHome iPL8  Buttons Replacement: step 9, image 2 of 3 iHome iPL8  Buttons Replacement: step 9, image 3 of 3
      • Remove the two 2.5mm screws using a Phillips #1 screwdriver.
      • Remove the back cover.
      • Use your fingers to reposition the lightning connector.
      • Make sure ALL of the lightning connector is exposed.
      Ask FixBot
    1. iHome iPL8  Buttons Replacement, Buttons: step 10, image 1 of 3 iHome iPL8  Buttons Replacement, Buttons: step 10, image 2 of 3 iHome iPL8  Buttons Replacement, Buttons: step 10, image 3 of 3
      • Locate the light brown, rectangular button board. Remove the five 2.5 mm Phillips #1 screws, four along the perimeter and one in the center.
      • Remove the brown button board.
      • There is a foam sheet underneath the button board. Use your hand to take it off and put it aside.
      Ask FixBot
    2. iHome iPL8  Buttons Replacement: step 11, image 1 of 2 iHome iPL8  Buttons Replacement: step 11, image 2 of 2
      • There are two rows of buttons clipped on to the small, circular, black columns.
      • Gently unclip the two rows of buttons and remove them.
      Ask FixBot
Author
with
Chen Zhong
569 Reputation
4 Guides authored
UC Davis, Team S18-G5, Lore Winter 2019 Member of UC Davis, Team S18-G5, Lore Winter 2019
UCD-LORE-W19S18G5
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 57
All Time: 683
