iHome iP21 Motherboard Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
69
All Time:
681
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Difficult
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. iHome iP21 Motherboard Replacement, Base: step 1, image 1 of 3 iHome iP21 Motherboard Replacement, Base: step 1, image 2 of 3 iHome iP21 Motherboard Replacement, Base: step 1, image 3 of 3
      • Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
      • Unscrew the four 11mm screws from the base.
      • Pry the base loose using the spudger.
      • Remove the base by hand.
      Ask FixBot
    2. iHome iP21 Motherboard Replacement, Housing: step 2, image 1 of 2 iHome iP21 Motherboard Replacement, Housing: step 2, image 2 of 2
      • Remove the two black 6mm screws connecting the main circuit board to the housing top.
      • Gently pull front housing from the back housing.
      Ask FixBot
    1. iHome iP21 Motherboard Replacement, Circuit board: step 3, image 1 of 1
      • Follow the prerequisite guide to remove the main housing.
      Ask FixBot
    2. iHome iP21 Motherboard Replacement, Circuit board mount: step 4, image 1 of 1
      • Remove the two 7mm screws from the circuit board
      Ask FixBot
    3. iHome iP21 Motherboard Replacement, Mounting Bracket: step 5, image 1 of 1
      • Remove the three 6mm screws to detach the circuit board from metal mounting bracket.
      Ask FixBot
    4. iHome iP21 Motherboard Replacement, Cables: step 6, image 1 of 3 iHome iP21 Motherboard Replacement, Cables: step 6, image 2 of 3 iHome iP21 Motherboard Replacement, Cables: step 6, image 3 of 3
      • Peel the glue from each of the three ribbon cable connections.
      • Remove the solder joints from the back of each ribbon cable.
      • Remove the ground wires by removing the solder joints on the back of the housing.
      Ask FixBot
    5. iHome iP21 Motherboard Replacement, Detach cables from circuit board: step 7, image 1 of 3 iHome iP21 Motherboard Replacement, Detach cables from circuit board: step 7, image 2 of 3 iHome iP21 Motherboard Replacement, Detach cables from circuit board: step 7, image 3 of 3
      • Remove glue from 3 ribbon cables from circuit board using fingers
      • Detach speaker cables from circuit board with soldering iron
      • Remove 3 ribbon cables with soldering iron
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 69
All Time: 681
