Up to 20% off select tools
iHome iM71SC Base LED Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
83
All Time:
614
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will walk you through replacing the LED at the bottom of the speaker.
    1. iHome iM71SC Base LED Replacement, iHome iM71SC Disassembly: step 1, image 1 of 1
      • Push down and turn the top of the speaker clockwise. This will release the clips and expand the speaker.
      Ask FixBot
    2. iHome iM71SC Base LED Replacement: step 2, image 1 of 1
      • Use a #000 Phillips screwdriver to remove the four 1 mm screws from the bottom half of the speaker.
      Ask FixBot
    3. iHome iM71SC Base LED Replacement: step 3, image 1 of 1
      • Flip the speaker over and use a #000 Phillips screwdriver to remove three 1mm screws . Unscrew these to unfasten the top.
      Ask FixBot
    4. iHome iM71SC Base LED Replacement: step 4, image 1 of 1
      • Remove the now unfastened coverings to expose the internals of the speaker.
      Ask FixBot
    1. iHome iM71SC Base LED Replacement, Base LED: step 5, image 1 of 1
      • Locate the LED on the circuit board.
      Ask FixBot
    2. iHome iM71SC Base LED Replacement: step 6, image 1 of 2 iHome iM71SC Base LED Replacement: step 6, image 2 of 2
      • Desolder the three connections to the old LED to remove it from the board.
      • Check out this awesome guide for soldering & desoldering instructions.
      Ask FixBot
To reassemble your device, follow Steps 1-4 in reverse order.
Author
with
Sarah Brown
301 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 83
All Time: 614
