iHome iH8BR Scroll Wheel Replacement
    1. iHome iH8BR Scroll Wheel Replacement, Lower Case: step 1, image 1 of 3 iHome iH8BR Scroll Wheel Replacement, Lower Case: step 1, image 2 of 3 iHome iH8BR Scroll Wheel Replacement, Lower Case: step 1, image 3 of 3
      • Unplug the device from the wall outlet, and turn it over so that the buttons are on a flat surface.
      • Use your fingers to pinch the tab in the direction of the "Open" arrow until tab is loose. Pull the tab vertically to remove it.
      • Remove the battery cover and the batteries.
      Ask FixBot
    2. iHome iH8BR Scroll Wheel Replacement: step 2, image 1 of 2 iHome iH8BR Scroll Wheel Replacement: step 2, image 2 of 2
      • Slide a spudger under the two front rubber pads to expose two hidden screws.
      Ask FixBot
    3. iHome iH8BR Scroll Wheel Replacement: step 3, image 1 of 1
      • Remove the following eight screws:
      • Four 15.1 mm Phillips #2 screws near the front of the device.
      • Four 12.7 mm Phillips #2 screws near the back of the device.
      • The slots for the four 12.7 mm screws are very narrow, so you will need a slender, Phillips #2 screwdriver that does not feature replaceable heads in order to reach them.
      Ask FixBot
    4. iHome iH8BR Scroll Wheel Replacement: step 4, image 1 of 2 iHome iH8BR Scroll Wheel Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Turn the iHome 180 degrees so the speaker grille is facing you. Carefully lift the bottom case away from the rest of the body and tilt it as shown.
      • Be careful and do not yank the bottom case. A white ribbon wire is the only thing that connects the bottom case to the rest of the device.
      • Using a pair of tweezers, detach the white ribbon cable. Make sure to pull on the ribbon, not on the head.
      • The lower case can now be completely removed from the device!
      Ask FixBot
    1. iHome iH8BR Scroll Wheel Replacement, Motherboard Assembly: step 5, image 1 of 2 iHome iH8BR Scroll Wheel Replacement, Motherboard Assembly: step 5, image 2 of 2
      • Remove the four screws attaching the top of the case to the motherboard:
      • Two 9.5 mm Phillips #2 screws near the speaker grille.
      • Two 14.3 mm Phillips #2 screws that sit in recesses under the motherboard.
      • It is useful to use a screwdriver with a magnetic tip so that the screws don't get lost inside the device.
      Ask FixBot
    2. iHome iH8BR Scroll Wheel Replacement: step 6, image 1 of 2 iHome iH8BR Scroll Wheel Replacement: step 6, image 2 of 2
      • Turn the iHome 180 degrees and carefully pull up on speaker cases to pry them loose from the bottom case.
      • Prying the Motherboard Assembly from the Upper Case will require a good amount of force. Be very careful not to break the case, or yank on any of the ribbon wires attached to the underside.
      • Pulling outwards on the sides of the Upper Casing can help loosen the assembly.
      • If it seems too difficult to remove, chances are that a screw is still attached. Make sure you've removed every screw listed before proceeding to this step.
      • Pull the back adapter cover off.
      Ask FixBot
    3. iHome iH8BR Scroll Wheel Replacement: step 7, image 1 of 2 iHome iH8BR Scroll Wheel Replacement: step 7, image 2 of 2
      • Remove the four 6.4 mm Phillips #1 screws holding the adapter to the outer case.
      • Only remove the following screws if you are planning on taking apart the iPod Adapter later on:
      • Two 6.4 mm Phillips #1 screws near the center of the adapter. These screws have built in washers.
      • One 4.0 mm Phillips #1 screw near the center of the adapter.
      • The iPod adapter should now be separate from the upper casing.
      Ask FixBot
    4. iHome iH8BR Scroll Wheel Replacement: step 8, image 1 of 3 iHome iH8BR Scroll Wheel Replacement: step 8, image 2 of 3 iHome iH8BR Scroll Wheel Replacement: step 8, image 3 of 3
      Buy
      • With the back of the iHome is facing you, tilt the Motherboard Assembly upwards as shown.
      • Do not yank or jerk these ribbon cables. Make sure not to pull on the heads, but on the ribbons themselves.
      • Use tweezers to remove the 6 ribbon cables.
      Ask FixBot
    5. iHome iH8BR Scroll Wheel Replacement: step 9, image 1 of 1
      • Pull the speakers, motherboard, and iPod adapter up and away from the lower casing.
      • You have now separated your iHome's inner workings from its protective case!
      Ask FixBot
    1. iHome iH8BR Scroll Wheel Replacement, Scroll Wheel: step 10, image 1 of 3 iHome iH8BR Scroll Wheel Replacement, Scroll Wheel: step 10, image 2 of 3 iHome iH8BR Scroll Wheel Replacement, Scroll Wheel: step 10, image 3 of 3
      • Remove the three 7.9 mm Phillips #1 screws holding the scroll wheel circuit board in place.
      • Repeat for the other circuit board.
      Ask FixBot
    2. iHome iH8BR Scroll Wheel Replacement: step 11, image 1 of 2 iHome iH8BR Scroll Wheel Replacement: step 11, image 2 of 2
      • Firmly press on the center of each scroll wheel to remove them.
      • You have successfully removed the scroll wheels!
      Ask FixBot
6 other people completed this guide.
cfredric
70 Reputation
6 Guides authored
Cal Poly, Team 12-33, Amido Spring 2013 Member of Cal Poly, Team 12-33, Amido Spring 2013
CPSU-AMIDO-S13S12G33
4 Members
84 Guides authored
7 Guide Comments
where do you get the scroll wheels to replace the bad ones?
bnewell0568 - Reply Share
Wow you can do the same thing leaving the entire unit intact by prying the wheels out from the top with a plastic pry tool. They come out pretty easily. This was still a very informative guide to disassembling the ihome.
huff08 - Reply Share
I pried the scroll wheel off like said above, wiped off dust grime, replaced it - and now it works perfect.
Sgk Glass - Reply Share
I ended up opening the whole thing up, taking the scroll wheels off and cleaning them. I also blew into the encoders on the little circuit boards, and it fixed them. They’re behaving just like new now. Thanks! I think I could have gotten away with prying the wheels off from the outside without opening it up, but oh well. This was actually on an iH6 — the innards were very similar to this model.
Doug Brown - Reply Share
I did the same as Sgk Glass. Works fine.
mark b - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 22
All Time: 4,779
