iHome iH5 Charging Dock Replacement
    1. iHome iH5 Charging Dock Replacement, Charging Dock: step 1, image 1 of 1
      • Remove the eight 5/16 inch screws with a #2 Phillips screwdriver.
      Ask FixBot
    2. iHome iH5 Charging Dock Replacement: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to unplug the three wires connected to the circuit board. If the wires are tight pliers might work better.
      Ask FixBot
    3. iHome iH5 Charging Dock Replacement: step 3, image 1 of 1
      • Remove the five 5/16 inch screws from the circuit board.
      Ask FixBot
    4. iHome iH5 Charging Dock Replacement: step 4, image 1 of 2 iHome iH5 Charging Dock Replacement: step 4, image 2 of 2
      • Flip the circuit board over.
      • There are capacitors all over the back side of the board. Be careful not to touch these capacitors (blue cylinders) as they can discharge—giving you a shock.
      • Unplug the eight wires attached to the circuit board with tweezers. If the wires are tight pliers might work better.
      • There is on wire in the orange box.
      • There are two wires in the yellow box.
      • There are five wires in the green box.
      Ask FixBot
    5. iHome iH5 Charging Dock Replacement: step 5, image 1 of 1
      • Remove the following four screws securing the iHome iH5 charging dock.
      • Use a #2 Phillips screwdriver to remove the four screws.
      Ask FixBot
    6. iHome iH5 Charging Dock Replacement: step 6, image 1 of 1
      • Gently remove the charging dock from the iHome iH5 by pulling it up.
      Ask FixBot
    7. iHome iH5 Charging Dock Replacement: step 7, image 1 of 1
      • Remove the final screws connecting the iH5 charging dock to the plastic holding platform
      • Use a #2 Phillips screwdriver to remove the 3/8 inch screws.
      Ask FixBot
    8. iHome iH5 Charging Dock Replacement: step 8, image 1 of 1
      • Replace the old iH5 charging dock with new iH5 charging dock.
      Ask FixBot
Dustin Lamb
103 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 28
All Time: 1,390
