iHome iH3L Speakers Replacement
    1. iHome iH3L Speakers  Replacement, Speakers: step 1, image 1 of 3 iHome iH3L Speakers  Replacement, Speakers: step 1, image 2 of 3 iHome iH3L Speakers  Replacement, Speakers: step 1, image 3 of 3
      • Locate all screws on the back of the iHome. Each screw can be located by the arrows on the iHome.
      • Two Countersunk 9.7 mm Phillips #2 screws in the middle.
      • Two 15.9 mm Phillips #2 screws.
      • Six 13.9 mm Phillips #2 screws.
      • Some screws are located under the black sticky pads. Gently remove the black sticky pads and it will expose the screws.
      • Two 11.8 mm Phillips #2 screws.
      Ask FixBot
    2. iHome iH3L Speakers  Replacement: step 2, image 1 of 2 iHome iH3L Speakers  Replacement: step 2, image 2 of 2
      • Remove all screws indicated in the previous step.
      Ask FixBot
    3. iHome iH3L Speakers  Replacement: step 3, image 1 of 3 iHome iH3L Speakers  Replacement: step 3, image 2 of 3 iHome iH3L Speakers  Replacement: step 3, image 3 of 3
      • Slowly tilt the bottom cover of the iHome up.
      • Do not yank the cover off, there is a wire connecting the cover to the circuit board.
      • Disconnect the wire just by pulling on the connector gently.
      Ask FixBot
    4. iHome iH3L Speakers  Replacement: step 4, image 1 of 2 iHome iH3L Speakers  Replacement: step 4, image 2 of 2
      • Disconnect the next connector pin after slowly opening the lid more.
      Ask FixBot
    5. iHome iH3L Speakers  Replacement: step 5, image 1 of 3 iHome iH3L Speakers  Replacement: step 5, image 2 of 3 iHome iH3L Speakers  Replacement: step 5, image 3 of 3
      • Disconnect the final connector pin series and carefully set your lid behind the body of the iHome.
      • The tiny speaker will not be disconnected for this repair, but you can easily remove it from the lid by means of a paperclip from the outside. While not necessary, this can help prevent damage to your device.
      Ask FixBot
    6. iHome iH3L Speakers  Replacement: step 6, image 1 of 2 iHome iH3L Speakers  Replacement: step 6, image 2 of 2
      • Remove the seven screws that are holding the motherboard in place:
      • Six 14 mm Phillips #2 screws.
      • One 14 mm Phillips #2 screw with two rubber washers on it.
      Ask FixBot
    7. iHome iH3L Speakers  Replacement: step 7, image 1 of 3 iHome iH3L Speakers  Replacement: step 7, image 2 of 3 iHome iH3L Speakers  Replacement: step 7, image 3 of 3
      • To remove the motherboard, gently lift up from opposite sides.
      • Be careful when lifting the motherboard. There are wires still connected to it on the backside.
      Ask FixBot
    8. iHome iH3L Speakers  Replacement: step 8, image 1 of 3 iHome iH3L Speakers  Replacement: step 8, image 2 of 3 iHome iH3L Speakers  Replacement: step 8, image 3 of 3
      • Carefully tilt the motherboard up from the front.
      • Disconnect the 8 connections by gently pulling on them. Starting from the front and work your way backwards.
      • All 8 connectors disconnected.
      Ask FixBot
    9. iHome iH3L Speakers  Replacement: step 9, image 1 of 2 iHome iH3L Speakers  Replacement: step 9, image 2 of 2
      • Unscrew the screws holding the speakers onto the body. One on each side:
      • Two 14.3 mm Phillips #2 screws.
      Ask FixBot
    10. iHome iH3L Speakers  Replacement: step 10, image 1 of 3 iHome iH3L Speakers  Replacement: step 10, image 2 of 3 iHome iH3L Speakers  Replacement: step 10, image 3 of 3
      • To remove the speakers from the iHome, gently lift up the back of the speaker and pull towards you. These are very secure so minor shaking may help release the speaker.
      • Repeat for the other side.
      • Be careful yanking on them, the speakers are connected together.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 26
All Time: 674
