iHome iH3L Dock Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
7
Past 30 Days:
49
All Time:
817
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The iHome dock found at the top of the device is unresponsive when connected to an iPod/iPhone. The iHome dock may also be bent or broken and will need to be replaced in order to connect an iPod/iPhone.
Tools
    1. iHome iH3L Dock Replacement, Speakers: step 1, image 1 of 3 iHome iH3L Dock Replacement, Speakers: step 1, image 2 of 3 iHome iH3L Dock Replacement, Speakers: step 1, image 3 of 3
      • Locate all screws on the back of the iHome. Each screw can be located by the arrows on the iHome.
      • Two Countersunk 9.7 mm Phillips #2 screws in the middle.
      • Two 15.9 mm Phillips #2 screws.
      • Six 13.9 mm Phillips #2 screws.
      • Some screws are located under the black sticky pads. Gently remove the black sticky pads and it will expose the screws.
      • Two 11.8 mm Phillips #2 screws.
      Ask FixBot
    2. iHome iH3L Dock Replacement: step 2, image 1 of 2 iHome iH3L Dock Replacement: step 2, image 2 of 2
      • Remove all screws indicated in the previous step.
      Ask FixBot
    3. iHome iH3L Dock Replacement: step 3, image 1 of 3 iHome iH3L Dock Replacement: step 3, image 2 of 3 iHome iH3L Dock Replacement: step 3, image 3 of 3
      • Slowly tilt the bottom cover of the iHome up.
      • Do not yank the cover off, there is a wire connecting the cover to the circuit board.
      • Disconnect the wire just by pulling on the connector gently.
      Ask FixBot
    4. iHome iH3L Dock Replacement: step 4, image 1 of 2 iHome iH3L Dock Replacement: step 4, image 2 of 2
      • Disconnect the next connector pin after slowly opening the lid more.
      Ask FixBot
    5. iHome iH3L Dock Replacement: step 5, image 1 of 3 iHome iH3L Dock Replacement: step 5, image 2 of 3 iHome iH3L Dock Replacement: step 5, image 3 of 3
      • Disconnect the final connector pin series and carefully set your lid behind the body of the iHome.
      • The tiny speaker will not be disconnected for this repair, but you can easily remove it from the lid by means of a paperclip from the outside. While not necessary, this can help prevent damage to your device.
      Ask FixBot
    6. iHome iH3L Dock Replacement: step 6, image 1 of 2 iHome iH3L Dock Replacement: step 6, image 2 of 2
      • Remove the seven screws that are holding the motherboard in place:
      • Six 14 mm Phillips #2 screws.
      • One 14 mm Phillips #2 screw with two rubber washers on it.
      Ask FixBot
    7. iHome iH3L Dock Replacement: step 7, image 1 of 3 iHome iH3L Dock Replacement: step 7, image 2 of 3 iHome iH3L Dock Replacement: step 7, image 3 of 3
      • To remove the motherboard, gently lift up from opposite sides.
      • Be careful when lifting the motherboard. There are wires still connected to it on the backside.
      Ask FixBot
    8. iHome iH3L Dock Replacement: step 8, image 1 of 3 iHome iH3L Dock Replacement: step 8, image 2 of 3 iHome iH3L Dock Replacement: step 8, image 3 of 3
      • Carefully tilt the motherboard up from the front.
      • Disconnect the 8 connections by gently pulling on them. Starting from the front and work your way backwards.
      • All 8 connectors disconnected.
      Ask FixBot
    9. iHome iH3L Dock Replacement: step 9, image 1 of 2 iHome iH3L Dock Replacement: step 9, image 2 of 2
      • Unscrew the screws holding the speakers onto the body. One on each side:
      • Two 14.3 mm Phillips #2 screws.
      Ask FixBot
    10. iHome iH3L Dock Replacement: step 10, image 1 of 3 iHome iH3L Dock Replacement: step 10, image 2 of 3 iHome iH3L Dock Replacement: step 10, image 3 of 3
      • To remove the speakers from the iHome, gently lift up the back of the speaker and pull towards you. These are very secure so minor shaking may help release the speaker.
      • Repeat for the other side.
      • Be careful yanking on them, the speakers are connected together.
      Ask FixBot
    1. iHome iH3L Dock Replacement, Dock: step 11, image 1 of 3 iHome iH3L Dock Replacement, Dock: step 11, image 2 of 3 iHome iH3L Dock Replacement, Dock: step 11, image 3 of 3
      • Remove the four screws from the mounting bracket.
      • Two 11.7 mm Phillips #2 screws.
      • Two 12 mm Phillips #2 screws with metal washers attached to them.
      Ask FixBot
    2. iHome iH3L Dock Replacement: step 12, image 1 of 2 iHome iH3L Dock Replacement: step 12, image 2 of 2
      • Lift out the bracket and rotate it towards you.
      Ask FixBot
    3. iHome iH3L Dock Replacement: step 13, image 1 of 3 iHome iH3L Dock Replacement: step 13, image 2 of 3 iHome iH3L Dock Replacement: step 13, image 3 of 3
      • Unscrew the two 10 mm Phillips #2 screws and remove the dock and chip.
      • The wiring harness is loaded through the bracket, so be careful when removing the chip.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 49
All Time: 817
