iHome iH27B Main Motherboard Replacement
  1. iHome iH27B Main Motherboard Replacement, Outer Case: step 1, image 1 of 1
    • Remove any iPod or apple music device connected to the iHome and unplug from any power source.
    • Flip the iHome so the speakers are laying on a flat surface, and you have the concealed battery areas facing you.
    Ask FixBot
  2. iHome iH27B Main Motherboard Replacement: step 2, image 1 of 3 iHome iH27B Main Motherboard Replacement: step 2, image 2 of 3 iHome iH27B Main Motherboard Replacement: step 2, image 3 of 3
    • Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic.
    • Remove the plastic slide from its location and set it aside.
    • These plastic slides are not interchangeable, so make sure each goes back to its original location in reassembly.
    • Remove all 4 AA batteries by placing your fingernail at one end of the battery and applying force upwards until the battery is freed from its holder.
    • Insert your fingernail or a prying tool under the notch of the plastic slide that is protecting the watch battery.
    • Set the plastic covering and the watch battery aside.
    Ask FixBot
  3. iHome iH27B Main Motherboard Replacement: step 3, image 1 of 1
    • Remove the following screws:
    • Eight 10 mm using the Phillips #0 on the bottom of your device.
    • Cataloging each screw by size in plastic bags or separate places on a flat surface will make them easier to find when reassembling.
    Ask FixBot
  4. iHome iH27B Main Motherboard Replacement: step 4, image 1 of 1
    • Use your fingers or a plastic opening tool to carefully pry apart the plastic connections still connecting the base to the top.
    • Be careful not to pry too hard. Cracking the plastic connections could make reassembly harder.
    Ask FixBot
  5. iHome iH27B Main Motherboard Replacement: step 5, image 1 of 1
    • Slowly lift the plastic base towards you and lay it on the flat surface. The base should still be connected to the rest of the iHome by a few wires.
    • You should have visible access to most of the components inside the iHome now.
    Ask FixBot
  6. iHome iH27B Main Motherboard Replacement, AV circuit board: step 6, image 1 of 1
    • Two 10 mm Phillips #0
    Ask FixBot
  7. iHome iH27B Main Motherboard Replacement: step 7, image 1 of 1
    • Pull out the AV circuit board and lift it up and out of the way to allow access to other components.
    Ask FixBot
  8. iHome iH27B Main Motherboard Replacement, Main Motherboard: step 8, image 1 of 1
    • Pull the speakers away and set them aside for now. They should still be connected to the rest of the iHome by two wires.
    Ask FixBot
  9. iHome iH27B Main Motherboard Replacement: step 9, image 1 of 1
    • Remove the following 6 screws:
    • Two 7 mm Phillips #0
    • Three 10 mm Phillips #2
    • One 9 mm Phillips #2
    • Set the screws aside, careful to not mix them up with your other screws.
    Ask FixBot
John Kraemer
76 Reputation
9 Guides authored
Cal Poly, Team 3-21, Amido Fall 2012 Member of Cal Poly, Team 3-21, Amido Fall 2012
CPSU-AMIDO-F12S3G21
4 Members
9 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 38
All Time: 1,211
