Up to 20% off select tools
iHome iD95 iPod Adapter Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
22
All Time:
2,402
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 50 minutes - 1 hour
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
Replace your iPod adapter if it's broken so you can charge your iPad/iPod/iPhone or play songs on the iD95.
    1. iHome iD95 iPod Adapter Replacement, Backup Battery: step 1, image 1 of 1
      • Before taking apart the iD95, disconnect the AC cord from the wall socket and AC adapter from the DC jack. Remove any iPods, iPhones, and iPads attached to the device.
      • Flip over the iD95 so the bottom cover is visible and the LCD screen is facing you.
      Ask FixBot
    2. iHome iD95 iPod Adapter Replacement: step 2, image 1 of 1
      • Remove the 10 mm-length, 5 mm-head screw using a Phillips #1 screwdriver.
      Ask FixBot
    3. iHome iD95 iPod Adapter Replacement: step 3, image 1 of 1
      • Use a plastic opening tool to take out the backup battery.
      Ask FixBot
    1. iHome iD95 iPod Adapter Replacement, Bottom Cover: step 4, image 1 of 1
      • Unscrew five 17 mm-length, 6 mm-head screws using a Phillips #1 screwdriver.
      Ask FixBot
    2. iHome iD95 iPod Adapter Replacement: step 5, image 1 of 2 iHome iD95 iPod Adapter Replacement: step 5, image 2 of 2
      • The bottom cover is attached to the back cover by two plastic clips. Don't use excessive force.
      • Insert a plastic opening tool between the edge of the bottom cover and the main body.
      • Gently pry the bottom cover from the body. Start anywhere along the front side of the iD95 and work your way around.
      • Grip the bottom portion of the device and gently lift the front part of the bottom cover a couple centimeters up.
      Ask FixBot
    3. iHome iD95 iPod Adapter Replacement: step 6, image 1 of 2 iHome iD95 iPod Adapter Replacement: step 6, image 2 of 2
      • Potential for device damage: Be careful not to use too much force or you might break the plastic rings holding the side panels in place.
      • Lift up the bottom cover. Pull the side panel up first, out, and away from the device.
      • The side panels have plastic rings that will need to be lifted up and off the cylinders they are placed around.
      Ask FixBot
    4. iHome iD95 iPod Adapter Replacement: step 7, image 1 of 2 iHome iD95 iPod Adapter Replacement: step 7, image 2 of 2
      • Apply the same techniques from the previous step to remove the remaining side panel.
      Ask FixBot
    5. iHome iD95 iPod Adapter Replacement: step 8, image 1 of 3 iHome iD95 iPod Adapter Replacement: step 8, image 2 of 3 iHome iD95 iPod Adapter Replacement: step 8, image 3 of 3
      • Locate the two plastic clips holding the bottom and back cover together.
      • Which clip you remove first is up to you. Rotate the device 90 degrees either left or right. Insert the flat end of a spudger horizontally between the back speaker and the back cover.
      • Place the flat end of the spudger behind one clip and pry it open. This may take repeated attempts.
      • This is the hardest step because the angle is awkward and the visibility is poor. If possible, have someone hold the device or provide lighting.
      • Once a clip has been removed, hold the bottom cover open so the clip will not fall back into place. One clip remains to be removed; you are almost there!
      Ask FixBot
    6. iHome iD95 iPod Adapter Replacement: step 9, image 1 of 2 iHome iD95 iPod Adapter Replacement: step 9, image 2 of 2
      • Use the same steps to remove the remaining clip.
      • The bottom cover is still connected to the motherboard by wiring.
      Ask FixBot
    7. iHome iD95 iPod Adapter Replacement: step 10, image 1 of 2 iHome iD95 iPod Adapter Replacement: step 10, image 2 of 2
      • Use a plastic opening tool to pry off the white ZIF connector joining the wires to the motherboard.
      • Don't pull the wires. Take your time using a plastic opening tool.
      Ask FixBot
    1. iHome iD95 iPod Adapter Replacement, Speakers: step 11, image 1 of 1
      • Take out four 14 mm screws using a Phillips #1 screwdriver.
      Ask FixBot
    2. iHome iD95 iPod Adapter Replacement: step 12, image 1 of 3 iHome iD95 iPod Adapter Replacement: step 12, image 2 of 3 iHome iD95 iPod Adapter Replacement: step 12, image 3 of 3
      • Use a plastic opening tool to lift the two speaker zip connectors from the logic board.
      • Do not pull on the speaker wires directly. Continue to use a plastic opening tool.
      Ask FixBot
    3. iHome iD95 iPod Adapter Replacement: step 13, image 1 of 1
      • Lift and remove both speakers.
      Ask FixBot
    1. iHome iD95 iPod Adapter Replacement, iPod Adapter: step 14, image 1 of 2 iHome iD95 iPod Adapter Replacement, iPod Adapter: step 14, image 2 of 2
      • Flip the logic board over.
      • Use a plastic opening tool to pry and lift the iPod adapter zip connector from the logic board.
      Ask FixBot
    2. iHome iD95 iPod Adapter Replacement: step 15, image 1 of 2 iHome iD95 iPod Adapter Replacement: step 15, image 2 of 2
      • Remove two 4 mm-head 12 mm-length screws using a Phillips #1 screwdriver.
      • Pull the iPod adapter from the top cover.
      Ask FixBot
    3. iHome iD95 iPod Adapter Replacement: step 16, image 1 of 2 iHome iD95 iPod Adapter Replacement: step 16, image 2 of 2
      • Use a Phillips #1 screwdriver to take out the two, 12 mm-length 4 mm-head, screws holding the iPod adapter to its casing.
      Ask FixBot
Author
with
Vincent Chan
19 Reputation
6 Guides authored
Cal Poly, Team 12-37, Amido Spring 2013 Member of Cal Poly, Team 12-37, Amido Spring 2013
CPSU-AMIDO-S13S12G37
4 Members
84 Guides authored
1 Guide Comment
Great article. I have an iHome iDL95 and would like to swap the Lightening adapter with a 30-pin adapter so that I can utilize my iPod 5.5 Classic. Is this possible? If so, where do I obtain the required 30-pin replacement adapter? Thanks.
P. Matt - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 2,402
