iHome iBT84 Motherboard Replacement
  1. iHome iBT84 Motherboard Replacement, Motherboard: step 1, image 1 of 2 iHome iBT84 Motherboard Replacement, Motherboard: step 1, image 2 of 2
    • On the opposite side of the speaker should be a sticker, remove it with your fingers or the flat plastic iFIxit tool.
    • Use a Philip's screwdriver to take the screws out of the cover.
    Ask FixBot
  2. iHome iBT84 Motherboard Replacement: step 2, image 1 of 2 iHome iBT84 Motherboard Replacement: step 2, image 2 of 2
    • Once the screws are all out, the cover should come off revealing the motherboard.
    Ask FixBot
  3. iHome iBT84 Motherboard Replacement: step 3, image 1 of 3 iHome iBT84 Motherboard Replacement: step 3, image 2 of 3 iHome iBT84 Motherboard Replacement: step 3, image 3 of 3
    • You will notice that the triangular black volume piece is loose, make sure to take that off revealing the buttons.
    • Once that is done, the motherboard can be taken out. May require some wiggling.
    • Make sure none of the wires are damaged and that they are all connected.
    Ask FixBot
  4. iHome iBT84 Motherboard Replacement: step 4, image 1 of 1
    • The connections shown here can be taken off by pulling on the white plastic connector piece.
    • The same can be said about the white, paper like, connectors. Pull on them gently.
    • Once all connections are apart, the motherboard is safe to be replaced.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 42
All Time: 1,353
