iHome iBT84 Light Fixture Replacement
    1. iHome iBT84 Light Fixture Replacement, Motherboard: step 1, image 1 of 2 iHome iBT84 Light Fixture Replacement, Motherboard: step 1, image 2 of 2
      • On the opposite side of the speaker should be a sticker, remove it with your fingers or the flat plastic iFIxit tool.
      • Use a Philip's screwdriver to take the screws out of the cover.
      Ask FixBot
    2. iHome iBT84 Light Fixture Replacement: step 2, image 1 of 2 iHome iBT84 Light Fixture Replacement: step 2, image 2 of 2
      • Once the screws are all out, the cover should come off revealing the motherboard.
      Ask FixBot
    3. iHome iBT84 Light Fixture Replacement: step 3, image 1 of 3 iHome iBT84 Light Fixture Replacement: step 3, image 2 of 3 iHome iBT84 Light Fixture Replacement: step 3, image 3 of 3
      • You will notice that the triangular black volume piece is loose, make sure to take that off revealing the buttons.
      • Once that is done, the motherboard can be taken out. May require some wiggling.
      • Make sure none of the wires are damaged and that they are all connected.
      Ask FixBot
    4. iHome iBT84 Light Fixture Replacement: step 4, image 1 of 1
      • The connections shown here can be taken off by pulling on the white plastic connector piece.
      • The same can be said about the white, paper like, connectors. Pull on them gently.
      • Once all connections are apart, the motherboard is safe to be replaced.
      Ask FixBot
    1. iHome iBT84 Light Fixture Replacement, Light Fixture: step 5, image 1 of 1
      • Use the screwdriver to unscrew the screws on the left and right sides.
      Ask FixBot
    2. iHome iBT84 Light Fixture Replacement: step 6, image 1 of 1
      • Once unscrewed, use the metal spudge to lift the base of the light fixture.
      Ask FixBot
    3. iHome iBT84 Light Fixture Replacement: step 7, image 1 of 2 iHome iBT84 Light Fixture Replacement: step 7, image 2 of 2
      • Lift the base of the light fixture out with the lights.
      • Be careful. The light fixture's can be easily bent.
      Ask FixBot
    4. iHome iBT84 Light Fixture Replacement: step 8, image 1 of 2 iHome iBT84 Light Fixture Replacement: step 8, image 2 of 2
      • Pull gently on the individual light fixture that needs to be replaced.
      • Place new individual LED light strip.
      Ask FixBot
Joshua Lopez
101 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 27
All Time: 912
