iHome iBT230 Motherboard Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
87
All Time:
1,156
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide provides step-by-step instructions for replacing the main motherboard of the iHome iBT230. The main motherboard is responsible for allowing communication between the crucial electronic components of the iBT230, such as the central processing unit (CPU) , memory, also providing the connectors for other peripherals.
Tools
    1. iHome iBT230 Motherboard  Replacement, Motherboard: step 1, image 1 of 1
      • Remove the four 5.5 mm Phillips Head #00 screws from the bottom palate of the iBT230.
      Ask FixBot
    2. iHome iBT230 Motherboard  Replacement: step 2, image 1 of 2 iHome iBT230 Motherboard  Replacement: step 2, image 2 of 2
      • Grip the top of the iBT230 by placing your thumb on the back portion, where the USB port is located. Pull up, and you should notice various different colored wires, connected to the Main Motherboard.
      Ask FixBot
    3. iHome iBT230 Motherboard  Replacement: step 3, image 1 of 3 iHome iBT230 Motherboard  Replacement: step 3, image 2 of 3 iHome iBT230 Motherboard  Replacement: step 3, image 3 of 3
      • Unplug the connectors from all sides of the iBT230, and unplug the wire connected to the screen.
      • Make sure to note which wire goes where, you don't want to re-solder the wires into the incorrect ports!
      Ask FixBot
    4. iHome iBT230 Motherboard  Replacement: step 4, image 1 of 2 iHome iBT230 Motherboard  Replacement: step 4, image 2 of 2
      • On the bottom component where the green Main Motherboard is located, remove the two 5.5 mm Phillips #00 screws.
      • The old Motherboard will come free from the bottom of the iBT230.
      Ask FixBot
2 other people completed this guide.
Bilal Siddiqui
376 Reputation
3 Guides authored
UW Tacoma, Team S3-G6, Liner Spring 2017 Member of UW Tacoma, Team S3-G6, Liner Spring 2017
UWT-LINER-S17S3G6
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 87
All Time: 1,156
