iHome iBT16 Motherboard Replacement
  1. iHome iBT16 Motherboard Replacement, Base Plate: step 1, image 1 of 2 iHome iBT16 Motherboard Replacement, Base Plate: step 1, image 2 of 2
    • Make sure to flip the device over to get into the correct orientation
    • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
    • Make sure to keep these screws in a safe location so you don't lose them
    Ask FixBot
  2. iHome iBT16 Motherboard Replacement: step 2, image 1 of 2 iHome iBT16 Motherboard Replacement: step 2, image 2 of 2
    • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
    • Using a lever like motion, push the opening tool down thus lifting the plate
    • You will need to use your fingers to lift the base plate off the main body of the device
    • The motherboard is directly underneath the base plate
    Ask FixBot
  3. iHome iBT16 Motherboard Replacement, Motherboard: step 3, image 1 of 3 iHome iBT16 Motherboard Replacement, Motherboard: step 3, image 2 of 3 iHome iBT16 Motherboard Replacement, Motherboard: step 3, image 3 of 3
    • Connect the ground strap to earth ground and put it around your wrist.
    • Unscrew the two 10mm silver phillips screws holding the motherboard in place on the inside of the device.
    • Use the plastic opening tool to pry the motherboard out of the device housing.
    Ask FixBot
  4. iHome iBT16 Motherboard Replacement: step 4, image 1 of 2 iHome iBT16 Motherboard Replacement: step 4, image 2 of 2
    • If you are unfamiliar with soldering and unsoldering components, see the Soldering Skills Guide.
    • Unsolder the red and black wires connecting the speaker to the motherboard.
    • Flip the motherboard over.
    • Unsolder the red and black wires connecting the battery to the motherboard.
    • When reassembling your device, be sure to connect the speaker and battery with correct polarity.
    Ask FixBot
  5. iHome iBT16 Motherboard Replacement: step 5, image 1 of 1
    • Remove the plastic cover from the power switch actuator on the motherboard.
    Ask FixBot
Joseph Hazel
353 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 28
All Time: 1,525
