iHome iAVS16 Power Board Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
7
Past 30 Days:
47
All Time:
397
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide shows how to open the bottom of the iHome iAVS16 to gain access to the board housing the AC power and USB jacks.
Since the iHome iAVS16 is a compact device, any following replacement guide will use this guide as well in order to access the rest of the device.
Tools
    1. iHome iAVS16 Power Board Replacement, Power Board: step 1, image 1 of 3 iHome iAVS16 Power Board Replacement, Power Board: step 1, image 2 of 3 iHome iAVS16 Power Board Replacement, Power Board: step 1, image 3 of 3
      • Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
      • Lift up the bottom of the device.
      • Carefully lift the bottom of the device up as to not damage the ribbon cable connecting it.
      Ask FixBot
    2. iHome iAVS16 Power Board Replacement: step 2, image 1 of 3 iHome iAVS16 Power Board Replacement: step 2, image 2 of 3 iHome iAVS16 Power Board Replacement: step 2, image 3 of 3
      • Remove the two 1.7 mm Phillips #0 screws holding the white face place onto the inside of the device's bottom.
      • Using an iFixit opening tool on the side without the black adhesive, carefully lift up the white face plate.
      • Lifting too quickly could damage the ribbon cable still attached.
      Ask FixBot
    3. iHome iAVS16 Power Board Replacement: step 3, image 1 of 2 iHome iAVS16 Power Board Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Using the tweezers, lift up on the black tab holding the ribbon cable down.
      • Carefully pull the ribbon cable back and out of the slot.
      Ask FixBot
    4. iHome iAVS16 Power Board Replacement: step 4, image 1 of 3 iHome iAVS16 Power Board Replacement: step 4, image 2 of 3 iHome iAVS16 Power Board Replacement: step 4, image 3 of 3
      • Remove the two 1.7 mm Phillips #0 screws holding the power board in.
      • Carefully flip the board over.
      • Remove the red connector from its socket with a pair of tweezers.
      Ask FixBot
Ashley Famularo
181 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 47
All Time: 397
